Question about Miele CVA4070 Coffee Maker
The grinder is not working. Only water is coming out
I have coffee beans in the container. When I hit coffee... The grinder is not grinding.
SOURCE:
Master_Tech
  • 770 Answers
SOURCE: No coffee coming out
sounds like you have a bean jam post your model i will send you the guide on how to fix this it is too long to type here
Posted on Aug 20, 2008
  • 18 Answers
SOURCE: I placed ground coffee instead coffee beans in
Bean grinders expect to grind whole beans as you have just found out. The grounds have clogged the entrance of the grinder. Use a wood chop stick to try and loosen up the 'caked' coffee and remove the coffee with a vacuum hose attachment. Try to **** out as much of the coffee as you can. Please note that this should all be done with the machine unplugged. Try grinding again but don't let it 'Hum' too long if it's not grinding. You can also try to adjust the grinder 'coarser' to give more room for the burrs to clear. Good Luck!
Posted on Feb 17, 2010
  • 75 Answers
SOURCE: grinder is not grinding. no error message or
SOunds like either the grinder is totally jamed with a small stone ( sometimes found in coffee beans) or the motor has died or the logic control of the motor operation has failed.
If mechanically minded, REMOVE POWER CORD, take all beans out of machine hopper - plug back in and see if you can detect any grinder movement. If not, UNPLUG again and see if you can see anything jammed in between the gringing discs. If so try and remove it even loosen up the amount of the grind as that may free up the jam.
Still no go, then you could test the motor but unless you are ELECTRICALLY competent DON"T ATTEMPT as it may be either a AC or DC motor and it could be running at low or DANGEROUS voltages.
Best to have it serviced if after checking for a jam it still is no go. Better to lose a few dollars than a life by attempting electrical repairs.
Posted on Jun 09, 2010
SOURCE: How do you remove coffee bean container from Miele
There is set-screw that holds the cofee bean container from pulling all the way out. Loosening almost all the way out (or removing) the screw, will allow the cofee bean container to slide all the way out. However, when sliding it out, put a container under the edge of the machine housing to catch any residual beans and keep them from falling all over the floor. Here's how to do it: with the door open, look (or feel with your fingers) directly at the (closed) coffee bean container. Coming up from the bottom, all the way on the right side is the set screw. It's a black phillips screw that you can easily miss if you don't look carefully or use a flashlight as it blends in with the housing. Good luck.
Posted on Nov 13, 2010
  • 128 Answers
SOURCE: Fault F 17 appears when in use. Starts grinding
f 17 is no water flow. It usually occurs when the brew unit has not been cleaned regularly, when the coffee grind size is set too fine, or when oily beans are used. You can try to soak the brew unit in hot water for a while, and run water through it in the sink. Unfortunately, most cases require brew unit replacement. A properly cleaned and maintained brew unit should last the life of the machine.
Posted on Feb 24, 2011
How do i fix my esam 3400 coffee grinder quantity?
I have change grinding from 7 to 1 ( it depends from coffee beans) and quality of coffee get much better (knob located inside the bean container).
Mar 09, 2016 | DeLonghi ESAM Coffee Makers & Espresso...
Why won't it brew?
Think the grinding mechanism is jammed with something. Disassemble unit and look for same.
Sep 03, 2017 | Saeco Vienna Plus Black Super-Automatic
The bean grinder doesnt grind, only water comes out
If it is working before, probably the coffee chute is clogged up. You can remove the bean hopper and see where the coffee drop into the brew unit.If the chute is still attached just clean the blockage, if it is broken you will have to remove the grinder and replaced it.
Jan 17, 2010 | Saeco Odea-Giro Espresso Machine
Saeco magic comfort coffee machine grinder
Make sure you not get any water in the grinder, if you got water in the grinder then you have to clean it.
You can try to set grinding to coarse and try to make 3 cup of coffee.
Jul 22, 2008 | Saeco Magic De Luxe Espresso Machine
Won't grind
the container were the coffee bean go .remove the bean, in the hole were the coffee goes you see the grinder wheel clean the grinder wheel with a brush you may have coffee residue on the wheel thanks for using fixya pierre
Feb 07, 2008 | Cuisinart DGB-300 Coffee Maker
Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Jul 15, 2007 | Saeco Magic De Luxe Espresso Machine
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Jul 23, 2006 | Saeco Caffe Charisma Espresso Machine
Miele CVA4070 Coffee Maker Logo
167 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Pierre Laplante
Vincent G
Vincent G
Jerry Greenberg
Jerry Greenberg
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
