Question about Kenmore Front Load Washer
Capacity of this washer? - Kenmore Front Load Washer
Hello, what is the capacity of Kenmore washer 110.28803890 in kilograms? Thanks
As a rule of thumb, 12 pounds of laundry is appropriate for a standard capacity top load washer, 15-18 pounds for a front-load washer, and 20-22 pounds for an extra large capacity front load washer. 1 lb.is .4536 kg so 15*.4536 is 6. kg. 18*.4536 is 8.17 kg.
Mar 13, 2018 | Kenmore Washing Machines
What is capacity in cubic foot?
  • How to Calculate the Capacity of a Washer Tub - About.com Home laundry.about.com > ... > Selecting a Clothes Washer 2016-04-14 · Video embedded · How to calculate the capacity of a washer tub ... your washing machine ... listed in cubic feet. A regular capacity machine is between 3.1 ...
  • Washer buying guide - CNET www.cnet.com > Appliances > Washing Machines 2013-09-12 · Washer buying guide. ... They have a smaller wash capacity, averaging at 1.5 cubic feet, ... What washing machine capacity do I need?
  • Washing machine capacity in cubic feet ... - Yahoo Answers https://answers.yahoo.com/question/index?qid=20121014130558AA2ph3V
    • RESOLVED
    • 3 POSTS
    • 2 TOTAL ANSWERS
    2012-10-14 · Washing machine capacity in cubic feet what does this mean? ... What does DOE stand for in regards to a washing machine's cubic feet?
  • Washing Maching Buying Guide - Warners Stellian ... www.warnersstellian.com/washer-buying-guide washer buying guide: ... Most conventional top load washers range between 3.2 and 3.5 cubic feet. ... The majority of washing machines are 27? wide, ...
  • What Should I Know About Washing Machine Capacity? www.wisegeek.org/what-should-i-know-about-washing-machine-capacity.htm What Should I Know About Washing Machine Capacity? ... A load of synthetic fleece sweaters will take up many cubic feet while not weighing as much.
  • What is the cubic foot capacity of my Kenmore washing ... www.shopyourway.com > Manage My Life > Questions 2009-09-21 · What is the cubic foot capacity of my Kenmore washing machine, model number 110.82984110? Report This by Manage My Life. September 21st, 2009.
  • Geeks On Home: What Is the Standard Cubic Feet for a ... www.geeksonhome.com/info_12199449_standard-cubic-feet-washer-dryer... What Is the Standard Cubic Feet for a Washer & Dryer?. ... What Is the Water Capacity for a Washing Machine? How to Measure Cubic Feet. How to Find the Capacity ...
  • Geeks On Home: Washing Machine Capacity Guide www.geeksonhome.com/info_12116692_washing-machine-capacity-guide.html Washing Machine Capacity Guide. Washing machines turned the chore of washing clothes by hand into an ... They typically have between 3 to 3.8 cubic feet of washing ...
  • May 04, 2016 | Washing Machines
    WWRE5240D1WW. What is capacity in cubic feet?
    On the GE appliance support site, they list a WWRE5240DWW washer with a 3.5 cubic foot capacity. There is also a WWRE5240DCC with the same capacity. Based on the parts list for various GE washers with similar model numbers, the WWRE5240D1WW is also a 3.5 cubic foot washer and is minimally different from the other washers.
    I hope this helps.
    Jan 24, 2016 | GE Washing Machines
    Capacity frigidaire fwt445ges2 load
    Good Afternoon Friend,
    I understand you want to know the capacity of your Frigidaire washer, model# FWT445GES2. After researching your model, I found that the capacity of your washer is 4.5 cubic feet. Hope this is helpful.
    -Best Regards-
    WP
    Jul 05, 2014 | Frigidaire GLTF2940ES Front Load Washer
    Whirlpool Ultimate Care II LSQ9564J Top Load Washer Sm8525079 what is the capacity of this washer and what is the capacity of the matching dryer?
    Hello.
    The capacity of your washer is 3.2 cu ft and the dryer is 6.0 cu ft. This is pretty much a standard for newer top load washers and dryers. You can get bigger but it is not that much bigger.
    Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    What is Cubic Ft Capacity of Washer?
    It's in the model number, and it's 4.4 cft. Which is one of the largest capacity washers available.
    May 27, 2009 | Frigidaire Washing Machines
    What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
    Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
    May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
    On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
    Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Kenmore Front Load Washer Logo
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
