Bangla Word 1.9 installing problem On Windows 7
How To Install Bangla word 1.9 On Windows 7 ? There is a problem showing me Windows Could Not opened 'oleaut32.dll'. Plz Solve This i am Trying Many Tips
    Master:
  • 576 Answers
Try downloading it from another source .. Sometime cd's are corrupted.
http://bengali.indiatyping.com/index.php/downloads
Posted on Sep 04, 2015
ginko
  • 19396 Answers
SOURCE: not,able,to,run,any,programs.dynamic,link,library,failed,oleaut32.dll,cant,start.error,by,widows,explorer,c06d007eh,in,module,sens.dll
If you have Win 98/ME you can try downloading and registering the DLL, this solution usually does not work on 2000/xp/Vista, and may also not work on 98 (usually works fine on Win 95).
Here is how to for first method.
Here comes the second solution , that if done properly works.
You will probably need to make a backup of all your data for example using an external hard disk drive.
I suggest also taking a screenshot of installed hardware from control panel/system, or writing details for sound card, video card, modem and network card (if any).
Then reinstall Windows as new installation, using either Windows setup disk or the set of recovery disks provided with computer (if any).
After this you will have to reinstall all drivers and software for your PC.
Here is how to for second solution
Here is complete tutorial
Regards
Posted on Apr 25, 2008
  • 162 Answers
SOURCE: deleted dll
Option 1:
Boot from your CD and follow the directions to start Recovery Console. Then:
Attrib -H -R -S C:\Boot.ini
DEL C:\Boot.ini
BootCfg /Rebuild
Fixboot
Option 2:
Boot from your CD and follow the directions below to start Recovery Console.
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD.
When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console.
When prompted, type the Administrator password. (if you didn't create one try pressing enter).
At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
Most likely you will need to expand the file from the CD. The command would be expand d:\i386\hal.dl_ c:\windows\system32\hal.dll. Substitute d: for the drive letter of your CD. Once you have expanded the file type "exit" to exit the Recovery Console and restart the computer.
Posted on Dec 01, 2008
JLBeertender
  • 56 Answers
SOURCE: windows error ... \system32\hal.dll. Please re-install a copy of the above file!
Use the recovery disks that came with your computer to do a repair installation. Put the disk in your cd / and or dvd rom, restart computer and select repair installation from the prompt.
Posted on May 02, 2009
SOURCE: Blue screen on Windows 7 RC shutdown. ati2dvag.dll
this made no sense u ******.
Posted on Jun 08, 2010
thinktech09
  • 177 Answers
SOURCE: error unitialized corrupt boot structure detected
try repairing the file system using chkdsk with /f switch. However, it is strongly recommended to run this tool only if you have a full data backup
. To do so, click \'Start\' and then \'Run\'. You can then type \'chkdsk /f <drive name>\' in the \'Open\' box and click OK. Here, the drive name should be exactly what is appearing in error message. Alternatively, you can opt for deleting the corrupt partition provided the backup is available. If no good backup exists, you should consider to use a Windows Data Recovery utility. These are powerful and valid Windows partition recovery utilities built to scan the corrupt or deleted partitions and safely recover the lost data. The applications are easy to install and use.
Posted on Jun 11, 2010
I had Windows 8.1 istalled in my Pc but it showed problem now i want to install windows 7. I have windows 7 bootable USB and want clean instalation. i booted from USB and opened stup and formatted my
Simply formatting the hard drive does not remove all residual traces of the previous installation. When you get to the step for formatting, go to the advanced button and delete the partition that contained windows 8. Then create a new partition in the space, format, and install windows 7.
Aug 05, 2014 | Computers & Internet
Tip
Install Unsigned Drivers on Windows 7 & Vista with Driver Signature Enforcement...
Every time when we try to install any hardware drivers which are not signed by microsoft, Windows shows a warning of Unsigned driver dialog box. The reason of showing warning message is to protect the stability of your Windows operating system as such drivers are not passed in Microsoft windows driver compatibility test.
In Window XP you can still install unsigned drivers but in Windows Vista SP 1 and Windows 7 Microsoft has introduced very restricted module of driver signature enforcement which doesn’t allow us to install any incompatible unsigned drivers.
If you want to bypass or disable Unsigned Driver warning message then Here is small freeware utility Driver Signature Enforcement Overrider which allows you to install and load unsigned drivers dynamically on your Windows 7 and Vista.
Supported Operating System
1. Windows Vista 32-bit & 64 bit
2. Windows 7 32-bit & 64-bit
Download Drive Signature Enforcement Overrider 1.3b
Please Note: User Account Control (UAC) must be disabled in-order to use this tool.
on Jan 10, 2010 | Computers & Internet
How do i solve the problem?
I think this is a typing software used to adapt your PC for Bangla language. Either uninstall it from the Control Panel or download and re-install.
May 25, 2014 | Microsoft Windows 7 Ultimate for PC
Cannot open ascddmi.dll
When I look at the ASUS site to download drivers for Windows 7 - there are none. So if you are trying to install drivers from the CD, you do not need them for Windows 7. There is a utility which you can install - check this site.
https://www.asus.com/Monitors_Projectors/VK248H/HelpDesk_Download/
Apr 10, 2014 | Microsoft Windows 7 Home Premium With...
Asus 53 n laptop
1. option - Removing Windows 8 by installing Windows 7 over it*:
Go to the disc where you have the Windows 7 installer.
Then right click, click on Mount, when done, click on the Setup file and install Windows 7 over your current system.
2. option - Keeping Windows 8 and installing Windows 7 alongside it**:
Restart the Windows 8 system, before Windows logo shows up, keep pressing F12, then choose the disc you have Windows 7 .iso file on.
3. option - Running it from a DVD, but keeping/removing*** Windows 8:
a) go to the disc where you have the Windows 7 .iso file installer.
b) move the .iso file to a easily accessible place like Desktop.
c) then right click on the .iso file and click on Burn disk image, choose the DVD you want to boot from ( You need a readable DVD), and then check the checkbox which says " Verify disc after burning ".
d) click on Burn.
e) when that is done, close all open programs or/and windows and restart your computer, before Windows logo shows up, keep pressing F12, then choose the disc you have Windows 7 installer on.
Note - please read everything carefully. I suggest you to use the 3. method.
* - when in the setup, you have no option to go back to Windows 8.
** - this step might not work, because not all computers support that.
*** - you can choose to either create a new partition on which you will install Windows 7 or install it over Windows 8 by either kepping or not keeping your personal files.
Please reply to this solution: did it help you or not and what improvements in my solutions do you want, and rate my solution from 0-5.
Jan 12, 2013 | Computers & Internet
Bijoy not supported
bijoy bangla is a free software supported by window 7
Feb 05, 2010 | Microsoft Windows 7 Ultimate for PC
Need to intsill windows pro xp
To reformat & install Windows do this.
1.) Make sure the Win CD in in the cdrom.
2.) Power on the PC & start pressing the F8 key every two seconds. This will open Windows Boot menue.
3.) Using your keyboard's up & down arrow keys high lite the cdrom & press enter.
4.) Xp will load it's install window. Choose to install windows.
5.) Xp will show if there is another installation & also show all partitions. Choose to delete these partitions.
6.) Choose to do a quick format.
7.) Install windows.
More questions? Just post back.
please vote...
Feb 19, 2008 | Computers & Internet
Computers & Internet Logo
1,042 people viewed this question
David Payne
David Payne
