Question about Frigidaire Affinity ATF7000E Front Load Washer
How do you replace the timer on a frigidaire frontload washer
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I understand you are trying to replace the timer on your Frigidaire Affinity washer, model# ATF7000E. If it is just the selector knob you are replacing, you should only have to snap the new knob on. If it is anything other than the selector knob, typically it is not a do it yourself repair. I do suggest contacting your local authorized technician for further assistance. They have been trained on your specific appliance, and will be able to better assist, and replace the timer on your washer. Hope this is helpful.
-Best Regards-
WP
Posted on May 16, 2014
3 Suggested Answers
kevin_getz
  • 1031 Answers
SOURCE: My Frigidaire frontload washer (model #LTF7000EG0) wont start because Door luck button comes on saying it won't lock. Please Help??
My guess is that being that the lock is electronic, either the lock is defective or there is a problem in the control board in that it's not telling the lock to lock the door. I would have a tech check the board.
Posted on May 09, 2012
SOURCE: frigidaire frontload washer filling up constantly
do not set knob to open position and open door ....I did this and flooded new construction. What happened to me is that my contractor took out the screens to the inlet hoses and this allowed small chunks to get through and lodge in solenoide valve causing it to stick open and allow for constant water flow......simple disassemble, clean, and PUT SCREENS BACK IN! they are there for a reason...
Posted on Dec 19, 2012
How to remove top of front loading washer
Thank you for your post, friend!
I understand that you want to remove the top off your Frigidaire frontload washer. Some of these intricate part replacements do require precision and patience, therefore when replacing such components or removing them from your appliance, I would suggest seeking professional assistance. One must be very careful as there certain replacement parts could result in potential harm. Best regards. -OOS
Oct 20, 2014 | Frigidaire Washing Machines
How do i replace the control panel on a front load frididaire washer
I appreciate your post, friend!
I see you would like to replace the control panel on your Frigidaire frontload washer. Regrettably this is not a simple DIY job. I would suggest you speak with a professional technician for proper removal of the part as well as installation of the new one. This can help to avoid any future issues. -Matt
Sep 12, 2014 | Frigidaire Washing Machines
417.39022890 Frigidaire Gallery Frontloader won't spin
Does it move at all in the spin cycle? If it does, try to open the door during the spin cycle and tell me if the door opens or stays locked.
Nov 20, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Frontload Washing machine Model GLTF2940FS1 will not spin out the water all the way and the clothes remain soaked with water. The drum does a few rotations in both directions but then shuts off...
Good Morning Lydia,
Based on what you have described and since you have already replaced the pump and checked for any possible kinks, at this time I would recommend reaching out to a professional to proceed further. The washer may possibly be experiencing an issue with the door lock assembly, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, a diagnoses is highly recommended.
Thank you for allowing me to assist you in some small way!
Sep 08, 2013 | Frigidaire ATF6000ES Front Load Washer
My frontload washer will not stay on
Hi - Either you have a communication error from the main control board or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. Contact a professional to accurately diagnose the washer.
Oct 16, 2012 | Frigidaire ATF6000ES Front Load Washer
May 08, 2012 | Frigidaire Washing Machines
My washer sounds like it's dying, but the dryer is fine. Can this be unstacked so all I have to do is buy a new washer?
Welcome to FixYa.
To answer your question, as long as it is indeed a frontload washer with the dryer on top, yes they can be replaced individually.
The model number provided is only partial, therefore I can`t verify the unit is frontload or an Kenmore integrated "laundry center" built by frigidaire.
You can reply with a model number, but as I alluded to if it is frontload, no problem.
Good luck going forward. Thank`s for choosing FixYa. Let me know if you require further assistance.
Macmarkus :)
Aug 25, 2010 | Kenmore 43142 Front Load Washer
FSE747GESI Frigidaire frontload dryer brown stains
I have the feeling that faded from the clothes .. so that there are brown marks .. or .. we have washing machines ber rust .. until that happens
Jun 16, 2009 | Frigidaire FTF2140FS Front Load Washer /...
you dont need to buy the shaft, "spider".it has a lifetime warranty on the inner tub and should be replaced by frig. what you need is the entire tub as the shaft is not available seperately. if you cant get this under warranty then i would suggest buying a new unit as the outertub and bearings are what is worn causing your noise in spin. you may have to pay a warranty dealer to get the tub covered, but the whole job is very labor intensive and most people cant do it, even if you are good with tools. call frigidaire and see if they will cover the repairs first.
Dec 28, 2008 | Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
