Question about Flat Panel Televisions
HDMI Socket not working on Samsung LCD
Recently bought a new Onkyo Reciever with upconversion to HDMI.
Connected Chord Silver Plus HDMI lead to Samsung LCD HDMI input, for the first 2 weeks of operation everything worked fine, unfortunetly had to disconect everything for arrival of new av stand...reconnected all leads but now the Samsung LCD HDMI is not recognising any connection to the socket. I have to point out that the Chord Silver Plus HDMI lead is heavy duty and not that flexible, could this have put to much strain on the socket welds.
If this is the case could you give me any idea how much it would cost to repair approx!
At the point of just using the Samsung as a large PC monitor and buying a new tv.
Your help would be appreciated!!!
SOURCE: Connecting laptop audio to tv
i had the same issue with a thinkpad T61 which i was connecting using VGA and a audio jack going straqight from the headphone socket to the back of tv.
I had picture but no sound and i found that once connected the issue could be solved by rotating the projection setting on the laptop(Fn+F7). Basically switched back to laptop only display, then back to laptop and projector display again and teh sound just kicked in.
i think it's related to the projector setting on the laptop rather than an issue with the tv.
Posted on Nov 01, 2007
SOURCE: no sound through ps3 hdmi
on ps3 go to settings sound and change sound out put to hdmi you will see 3 different options
Posted on Nov 07, 2008
  • 4 Answers
SOURCE: HD set top box to PC via HDMI
it should be an HDMI Output, you should be able to hook up to a monitor with no problems but directly to a PC, not so much. In what way will you be using this application, that may help
Posted on Apr 29, 2009
SOURCE: samsung 610 46'' lcd - hdmi input not working
why hdmi input wont show up
Posted on Dec 22, 2009
  • 10 Answers
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
Posted on May 11, 2010
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Posted on Jun 03, 2011
0 characters
1 Points
Ps3 doesnt give out a surround sound output
In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option.
If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver.
After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.
Aslo the following setting in PS3
Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..= DIGITAL OUTPUT (OPTICAL)
May 21, 2012 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Samsung LN-S3251D intermittent sound problem
Try to check the connection from your HD reciever it could be a loose signal from the reciever that why the sounds cut out..
Tell me more.
Feb 19, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
Samsung LE32R51BD HDMI connection not working. Have connected the sky+HD box to another HD tele using the lead and it works ok but not with the Samsung
Have had the same fault with mine. Out of warranty so took back off and HDMI socket fell out of the PCB!!!!! Never had a plug in it. Too small to solder back in. Needs a new signals board. Waiting for Samsung to come back with a price.
Nov 03, 2009 | Flat Panel Televisions
PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Feb 26, 2009 | Samsung Flat Panel Televisions
Older Onkyo Compatability with newer HDTV
Hi rmccormick,
That Tv with the PS3 is a fantastic setup, The tv has one of the best picture quality ratings and the 4ms response time is great for fast action video and video games. The PS3 is a good decision for the Blu-Ray player, for the price you get a great game console along with the player, the drawback is that the PS3 runs alot hotter than a stand alone player, it will need to be well ventilated.
Your reciever will work but you won't be able to watch Blu-Ray in 1080p and that is the pupose of the PS3, you have to use the HDMI output on the PS3 to get 1080p and I doubt your reciever has HDMI, if it does your set if not I would buy a newer model with Dolby 5.1 and HDMI support, or if you want the best go with Dolby TrueHD.
You will need HDMI cables.
Let me know if this helps and please rate this solution. Lone99star
Jan 19, 2009 | Samsung LN52A650A LCD TV
I have the same TV & I've tried connecting it through "component" & the DVI but neither work & a Virgin media tech says only an HD TV will work 'the boxdoesn't recognise component
May 05, 2008 | LG RZ32LZ50 32 in. LCD Television
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Flat Panel Televisions Logo
1,480 people viewed this question
Top Flat Panel Televisions Experts
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
