Question about Smartpool Nitro Robotic Cleaner and Caddy
Why wont it move - Smartpool Nitro Robotic Cleaner and Caddy
2010 sx4 stopped and red light and when light turned green, car wont move.when move gear to reverse, wont move either. Car is running just wont move
breaks jammed on .check the sliders to each brake .remove and clean them.and grease them .to stop them sticking.
Nov 24, 2013 | Cars & Trucks
2005 honda rincon wont move
Check transmission fluid level. If it's ok need to have trans fluid pressure checked. Need schematic, but should be a port on the side of trans for this. If to in depth then take it to a repair shop. Could just have a clogged trans filter.
Jul 11, 2013 | Cars & Trucks
Incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
May 08, 2012 | Exercise & Fitness
It moves into gear but wont move
transmission has gone out also check tranny fluid
Mar 14, 2010 | 1986 Cadillac Seville
Wont move
well the first thing is to make sure it has enough trany oil in it. if it does then you may have a bad trany.hope this helps.
Jan 27, 2010 | 1999 Mitsubishi Eclipse
John deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Jul 14, 2009 | John Deere Garden
John deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
May 26, 2009 | Garden
Smartpool Nitro Robotic Cleaner and Caddy Logo
90 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
