Question about Proform Pro - Form Treadmill 705 CST
Lime Pro Equipment error E03
My treadmill will briefly start then stop after about 3-5 seconds with error code E03 on screen. Please help
4 Suggested Answers
SOURCE: I just put a new belt on my Pro-Form treadmill.
Hi there
sanjay treadmill repair professional from india
you have done some mistake when you fixed the new belt.
You have a speed sensor problem.
CHECK
1.Front roller sensor usually a magnetic one for broken wire or for larger space between the magnet and the sensor.
i) Sensor is Usually 2 wire and magnet is fixed on to the roller.
ii) Magnet can dislocate from its place check the magnet for attraction by taking a screw driver.
iii) Chcec gap between the magnet and the sensor on the frame. Gap should be betwwen 3mm to 5mm.
2. If roller sensor is not present then there is alternative sensor on the motor ususlly a multi holed plate revolves between the sensor.
i) It is usually has 3 wires.
Check for the connections on the motor control board.
If not solved then mail me on sanjay_phil@yahoo.co.in
Posted on Oct 02, 2009
SOURCE: proform 725 treadmill error code
I have the same error "E21" any help out there?
Posted on Jan 08, 2010
  • 28 Answers
SOURCE: treadmill pro-form 705 not starting
All that I can think of is to check that the motor is getting power.
Posted on Sep 19, 2012
Shows an error of E03
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Precor Error Code 03 E03 EEPROM Test Error
Oct 03, 2015 | Exercise & Fitness
Reebok z8 error E03
I can not adjust my tension on my machine
Feb 27, 2014 | Exercise & Fitness
Treadmill error codes 3
please follow the steps and fix it.
E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire is NOT working, change the magnet wire or reset the magnet. Please clean it too.
See the diagram attached.
God bless you
Dec 02, 2013 | Exercise & Fitness
Carl lewis mot566 treadmill error code e03
please adjust the REED switch, see the diagram attached. Clean it +test it for open or faulty+tight the connector very well.
However if the problem persist error code 3, this is a problem with the PCA memory location, RAM. the solution is to replace the PCA.
Try to RUN the software calibration for easy diagnostic, and fix it
God bless you
Jun 22, 2013 | Exercise & Fitness
How to reset treadmill T630
Dear Sir:
I will try to help you.
    • 1
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
    • 2
Press the "ENTER" button three times to access the treadmill's error log.
    • 3
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
    • 4
To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
    • 5
To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted
If you need further assistance, please reach me, sincerely.
God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 24, 2011 | Exercise & Fitness
Unlock the code on Precor treadmill?
Dear Sir:
Please try with this Reset system for Code:
    • 1
    • 2
    • 3
    • 4
    • 5
To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
If you need further assistance, please reach me. sincerely. God bless you.
E.CUADRA
Oct 23, 2011 | Exercise & Fitness
My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
2.Press the "ENTER" button three times to access the treadmill's error log.
3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
I hope you find it very helpful.
Sep 04, 2011 | Exercise & Fitness
Carl Lewis MOTC66 E03 error HELP !
Check the motor brushes if they are find then I would go back to the board regardless if its new it could be defective
May 04, 2010 | Exercise & Fitness
Proform Pro - Form Treadmill 705 CST Logo
794 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
