Question about DeLonghi (284748) Kitchen Hood
Why when there is power to rangehood but only lights are working all wires seem ok
Tappan Electrolux tmv151fs microwave/rangehood. turntable and cavity light intermittent (but work/fail in unison), all else work ok
Either a wiring problem or worn contacts on the relay that powers the two would be possibilities.
Nov 24, 2016 | Microwave Ovens
Unit has no power. Circuit breaker OK. Is there a fuse somewhere in the hood?
Very likely the power supply unit is faulty or the controller itself. The parts list shows no fuse internally. The power is directly going to the control board (item 3). Make sure you turn power to the rangehood off at circuit breaker before working on it.
JENN AIR Vent Hood Hood components complete Parts Model JXT5830ADS
Sep 06, 2014 | Jenn-Air JXT5830AD Kitchen Hood
Lights not working in Technika Rangehood (900m Model - D8900HASS)
TECHNIKA Pty. Ltd. 77 FILLO DRIVE, SOMERTON, VICTORIA 3062 PH 03 9948 4500 TOLL FREE
ABN 38 069 686 326 PO BOX 543, SOMERTON, VICTORIA 3062 FA X 03 9948 4555 1800 649 969
Online customer care contact for support: http://www.technika.com.au/contact
Dec 05, 2013 | Dryers
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
Baumatic rangehood bah9005 the switch pushes in and the lights dont work , motor works when electrical switch at wall is on
Thank you for using FixYa. It sounds like there is obviously power getting to the rangehood ( the motor works) and I would suspect that it is just the bulbs that have blown.
Mar 16, 2011 | Microwave Ovens
The lights on the under side of the rangehood do not work .i have replace the bulbs ,the exhaust fan works ,is their a re set switch
could be a blown transformer to supply the correct power to the lights or a loose connection on the light holders.
Aug 23, 2010 | Ovens
How to replace light globe in Chateau Grange rangehood
I have a 600mm Chateau range hood with the same problem. To access the globe chamber, you need to first remove the plastic diffuser from the underside of the rangehood. Located at one end of the diffuser will be a small slot approx 10 mm long. Insert a small flat blade screwdriver into this slot and carefully depress the plastic tongue of the diffuser by gently pushing the head of the screwdriver away from the diffuser. As the tongue disengages from the frame you should be able to grasp the edge of the diffuser and pull it away from the frame. Once the diffuser has been removed from the frame, you will be able to change the globe.
To reinstall the diffuser, insert the plain end of the diffuser into the frame of the the rangehood (above the globe) and gently push the clip end back to its flush position.
Nov 17, 2009 | Kitchen Ranges
Rangehood lights not working
I have a Fabyka Range Hood and know three other people who have had this exact problem (i.e both lights go out simulatneously but fan works fine). In my case I was able to pin it down to the transformer used by the halogen lights. This is an electronic transformer so it is less tolerant of power surges and such.
In the case of Fabyka the transformer is a black box connected to the inside of the hood with sticky tape with a black and white wire and two red wires. It is only used for the lights.
It is connected to the AC power via a black and white wire. you can disconnect this and us an LED power tester (about $2-$5 at most hardware stores) and see if you have power when you hit the switch.
In my case it is a 70W 120v to 12v halogen transformer. You can by a replacement off Amazon for about $12 including shipping or you can by a new one from Fabyka for about $30. I would suggest getting a slightly higher wattage transformer (I bought a 105watt for a dollar more).
You will need to disconnect the power before replacing but it is an easy fix.
1. Disconnect the AC power connector (black and white wires.)
2. The red wires coming out are the 12volt lines. If there is a connector, you can disconnect this, if not, you may need to cut these off.
3. Pull the tranformer off the back of the inside of the hood.
4. Cut the connectors off the old transformer. (Unless you buy Fabyka's.)
5. Connect them to the new transformer using wire connectors or crimps. (Make sure you connect black to black, white to white, and red to red.)
6. Make sure you have no exposed wires.
7. Connect to the corresponding connectors inside the hood. Connect the AC connector last.
8. Verify that the lights work properly.
9. Use sticky tape (or Gorilla tape) to attach the connector to the inside of the hood.
10. Enjoy the light.
Jul 17, 2009 | Kitchen Ranges
Fan Not Working
Sounds like a motor problem...but not necessarily. Cut power to the unit. Expose the motor assembly. Turn the fan by hand...if it is jammed or hard to turn...replace that motor. Not that? There is likely a motor connector. Get a test light at the hardware store. Disconnect the motor and then probe the wires coming to the connector from the power side (with the power on again) to see if the tester glows. Yes...bad motor. No, find the bad connection. It is possible that this unit uses a multi switch...if that's the case, there will be three wires coming out of it...One is power in...the others go to the light and the fan. Then, the switch will be the culprit. Hope this helps.
Dec 05, 2007 | Faber Cristal HC 598041 Kitchen Hood
DeLonghi (284748) Kitchen Hood Logo
73 people viewed this question
Top DeLonghi Kitchen Ranges Experts
JP Services
JP Services
Sal DeAngelo
Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
