Question about Plasti Dip Multi-Purpose Rubber Coating 14.5 Oz - Black
Plasti dip Spray tech apex 1920 - Plasti Dip Multi-Purpose Rubber Coating 14.5 Oz - Black
HOW DO I GET AN ANSWER FROM YOU PEOPLE
by asking the right question. If you ask a vague question you have a good chance of getting a vague answer .
as previously vaguely expained you have to do an auto scan
and let it complete.
This is based on your tv being connected to an antenna and being the model Apex Digital Apex LD4088 40 Class LCD HDTV - 1080p, 1920 x 1080, 16:9, 60Hz, 1800:1
You have to press menu button on your remote control when you see the message you saw on the tv screen.about Auto Scan. Then use the left and right arrows to select tv mode. Press the down arrow to select Air/Cable. Press the left or right arrow to select Air if antenna and Cable if it is a cable service. Once you have selected Air or Cable press the down arrow to select auto scan . If air then press right arrow on the remote (if cable then press enter on the remote)
This is explained on page 18 of the tv user manual
http://data.manualslib.com/pdf/1/84/8384-apex_digital/ld4088.pdf?0fa28d37b4d5ca4a9f59538bc95467d9
Jan 13, 2015 | Apex Digital Apex LD4088 40 Class LCD HDTV...
How do I stop it from running the auto scan
Once the unit finds the channels it will stop scanning.
Apex HDTV board burned out
Why not get a repair/replace estimate from the TV tech?
Mar 22, 2014 | Apex Digital Televison & Video
Interior scratches
Plasti dip, or reupohlstery.
Aug 23, 2013 | 2012 Hyundai Elantra
How to plastic dip
use some painting tape just tape off the windows and the parts u dont want plasti dip spray paint on. You can buy that stuff for like at most 4.00 dollars at home depot. Different colors. After u plasti coat wait 20 min just to make sure its dried then with ur r/c car, carefully get a knife or razor and cut softly around the windows
Apr 01, 2013 | Audio Players & Recorders
Will plasti dip paint work on chrome rims?
It will go on and adhere as it is drying but once it's fully cured it won't take much pressure to make it start peeling off a chrome surface. Chrome is very hard and very, very smooth. Because of these properties, the Plasti Dip will coat it and dry properly but will have a very hard time ashearing to the chrome after it dries completely.
Jun 28, 2012 | Plasti Dip Multi-Purpose Rubber Coating...
Century bob
Cheap plastic nipples are stripped out! Moving it while Bob is still attached & kids jumping on Bob's shoulders did the same to mine... I am going to try short bolts & nuts after dipping in plasti-dip/rubber product of some sort.
Nov 21, 2011 | Century "Bob" Body Opponent Bag
Dishwasher replacement part
Instead of replacing it you might try re-coating the rack with Plasti-dip. Available at some hardware stores.
Nov 15, 2009 | Dishwashers
GX 08 spray gun problem
drain your system of pressure. remove your air cap and nozzle from the gun. slowly increase fluid pressure till it comes out of gun. this will clean out debri from gun. reduce pressure so you don't wast anymore fluid.
clean nozzle properly / completely
clean aircap. properly / completely
inspect needle tip for abnormal wear.
if cleaned properly you will find your gun works much better.
Oct 17, 2009 | Wagner GX08 Airless Spray Gun
No nozzle for my can of spray paint.
Take it back to the store. It should have the nozzle in it already.
Mar 20, 2009 | Air Tools & Compressors
Plasti Dip Multi-Purpose Rubber Coating 14.5 Oz - Black Logo
27 people viewed this question
Top Plasti Dip Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Plasti Dip Air Tool and Compressor Expert? Answer questions, earn points and help others
