Question about Soleus Heating & Cooling
Does the filter cover on the back need to stay off when using the air
When I use the air part of it it is leaking all over the floor what do I need to do. Don't have a user guide and not sure if there is a drain that I am missing or what
5 Suggested Answers
luker711
  • 91 Answers
SOURCE: Unit is leaking at the back towards the wall.
Sometimes the pan that catches the water rusts through and leaks no matter what you do with the drain. If the leak spot is accessible you can fix it when its clean and dry with some JB weld or some other epoxy;' many times though its totally unreachable, and needs to be replaced. In that instance call a reputable HVAC to repair. Sometimes leaks come from the unit being out of level. I'm assuming this a split system unit. This sometimes can be re-leveled by way of some wooden shims or adjusting the support. Also you can slightly shim the unit to where the condensation runs forward to the drain, avoiding the leak in the back. Good luck
Posted on Jul 14, 2009
james3751
  • 614 Answers
SOURCE: Air Handler leaking
First make sure unit is level. Drain pan may be dirty. On the rheem or Ruud unit the back of the pan gets stopped up. Ithas small holes that let the water by and they get stopped up. Now even though your drain is clean you may have a stopped up dain pan. Check this > These are problems you can take care of your self. Open up the top panel of your unit and you can look down on the drain pan. Check for dirt and stoppage near the outlet of the drain pan. You amy also have a cracked drain pan but I doubt it. Rus
jdhnmi
  • 143 Answers
SOURCE: I have a seven year
you could use a little food die and trace where the water is going to there seems to be a hole somewhere
Posted on Jun 11, 2011
  • 230 Answers
SOURCE: My amcor air conditioner is
Dehumidifying is a product of AC, that is a good thing, water on the floor is not. Do you have the ability to drain the water away to a floor drain or somewhere? Or just drain the catch pan, on what ever schedule it takes to prevent over flow. You obviously have a very high humidity, if your house is tight you should start to see the condensate water slow down.
Posted on Jul 06, 2011
Replaced blade and now oil coming air filter
If you have tipped the machine on its side rather than tipping back on the handles, the engine oil will spill from the engine breather and be fed into the back of the air filter box, you now need to remove the filter cover and filter, run the engine until the smoke clears, if the air filter ia a paper cartridge yo will need to replace with a new filter.
Jun 13, 2013 | Husqvarna Garden
5.3 vortec using oil not leaking
How dirty is your air filter? Sometimes a dirty air filter will make it pull up oil if it can't pull in air. The other thing to check would be the PVC valve. PVC valves are cheap and I would just replace it.
Jan 05, 2012 | Chevrolet Silverado Cars & Trucks
Changed the air filter and now the check engine light stays on. Other then that the car runs just fine.
The cover on the air filter box is not on correctly,you
have air leaks.
What code do you have as a result of the check light?
That is where you start
Nov 24, 2010 | 2005 Ford Taurus
Need to change fuel filter on 97 chevy lumina
Follow the steps care fully
Open the hood and relieve the fuel system pressure. On the fuel rail, right before the first fuel injector, locate the Schrader valve-similar to a tire air valve-on the inlet fuel line. Using a small screwdriver, depress the stem inside the valve while covering the valve with a shop rag to catch the squirt of fuel.
Raise the back of the vehicle using a floor jack and support it safely on jack stands.
Locate the fuel filter along the frame rail-passenger side-of the vehicle, near the fuel tank.
Unplug the quick-connect fuel inlet line on the back of the filter by pressing the lock tabs. Push the connector towards the filter and then pull to disconnect the fuel supply line.
Disconnect the outlet fuel line from the filter-the line going toward the engine-by using a backup wrench to hold the line nut while disconnecting the lock nut on the filter with a tube wrench.
Remove the filter from its mounting bracket and install the new filter in place, making sure the arrow on the side of the filter case points toward the engine.
Install the outlet fuel line. Tight the lock nut finger tight, then hold the fuel line nut with the backup wrench and tight the lock nut with the tube wrench. Make sure not to over tighten the nut to prevent fuel leaks.
Press the fuel supply line fitting against the small tube at the back of the filter until the lock tabs snap in place.
Lower the vehicle, start the engine and check for leaks.
Oct 20, 2010 | 1997 Chevrolet Lumina
My car is leaking drops of oil and eats alot of gas what could it be?
You will have to map the oil leak on the floor with clean floor or a piece of cardboard to find out where it is coming from. Could be the rocker covers, drain plug, oil filter, etc. Once you find out where it is coming from, you can get to it and fix it. The gas eating is, a dirty air filter, soft tires, oxygen sensors, computer gone bad, dirt in the intake. all can be taken care of when found. Take your car to a parts store and put it on the scanner and see what comes up. You might be missing something, your car isn't telling you. Plug wires, spark plugs, idle air control, mass air flow, inlet air temp, etc, there are a bunch of things that would cause poor mielage. Check it out, hope this helps.
Sep 17, 2010 | 2003 Nissan Altima
MY WINDOW UNIT LEAKS WATER ALL OVER MY FLOOR AND BLOWS WARM AIR. I CLEANED IT AND IT STAYED COOL FOR A WEEK AND IT FLOODED AGAIN.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Your unit is freezing up...check the air filter...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 03, 2010 | Premier Heating & Cooling
Looking for answers concerning my portable ac
Contact sharp for the replacement remote. As for the water the drain should discharge to a pan through a tube or a cap covers the drain hole. When it gets full it leaks out onto the floor. Also when it ices inside through prolonged use and can leak out through the edges to the bottom.
Jul 14, 2010 | Sharp CV-P10MX Air Conditioner
Cabin air filter on a 2006 subaru outback limited
The cabin air filter is behind the glove box. The first thing you need to do is empty the glove box. (2) you need to remove the side panel that runs along the side of the shifter, it is a long panel and has on clip near the firewall, the clip will have a phillips head on it, just back it out and remove this panel. Then remove all the bolts (10MM) holding the glove box on, The glove box is will stay up because it has two hings that run into the sides of dash. All you need to do is squeeze the glove box untill it pops out and the glove box will be out. There is no need to unhook the wiring for the light bulb just let the glove box hang on the floor. Now you will see a black cover that is held on by 4 small metal clips, remove these and pull the cabin air filter out. when you reinstall the new one, make sure you put it in with the air flow arrows pointed in the right direction or else you will cause blockage. reinstall and enjoy your new heppa filter
Jun 19, 2009 | 2006 Subaru Outback
How to change air conditioning filter chrysler crossfire 2005
I found a chrysler blog. Pull back carpet on passenger foot well, remove white styrofoam computer protector. Remove cardboard cover (remove two screws) from bottom of glove box. On Left side see a slot with plastic cover and two sliding latches. Open and remove and replace filter. Follow reverse to finish up. It is tight fit and hard to get to for normal sized man.
Nov 22, 2008 | 2005 Chrysler Crossfire
Water leak right front under dash
make sure there is a rubber seal over the cabin air filter and that is is securely in place when you put the plastic cover back on. the rubber seal is about a foot long, looks like weatherstripping. HTH.
Nov 02, 2008 | 2003 Buick Regal
Heating & Cooling Logo
21 people viewed this question
Top Soleus Heating & Cooling Experts
Chris Hall
Chris Hall
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
