Question about Operating Systems
Cleaaring my harddrive
I have been trying to clear my hard drive for some time now using the F11 key however it just doesn't do it. I am trying to get the pc back to the manufactures settings.
  • 208 Answers
Re: cleaaring my harddrive
You mean if u have a dell with xp you're trying to do ctrl f11.. if your dell has a blue bar up top with it should work. if its vista its just f8 to get repair my computer. im a dell ex technician on the phones. to fix xp version of dell restore u need dsrfix from
if its vista and u ran the anytime upgrade and now wont let you restore u have to run a command with imagex.. its in dell support forums
Posted on Nov 05, 2007
  • 4 Answers
Find out the make of your hard drive, and do a format from a bootable cd, at that point you will be able to restore your os
  • 47 Answers
What OS do you have?? You might need the restore cd.
0 characters
3 Points
Operating system not found on tough book 29
Your hard drive is failed, or the boot sector has been corrupted.
Lets try the cheap fix first... watch this tutorial to rewrite the boot sector to the hard drive... and read my entire post. First.
To get your toughbook to boot to the rcovery console, boot the machine and press the F2 key repeatedly when the machine starts to boot. If that combo does not work, reboot again and try <ctrl>f11 (repeatedly). A third possibility is the F8 button. Reboot again, of course.
Good luck
Remember to BACK UP YOUR DATA FIRST!!!!!
How, you say? On another computer, download Ubuntu 14.04 LTS and burn the ISO file to a dvd. Then boot your computer from the disk and choose the "try" NOT the "install" option. Connect a usb Hard drive large enough to hold all your data. Using the Ubuntu file manager (second icon down on the totem on the left side of the screen) copy all your important files to the external harddrive. The drag and drop functions are very similar to windoze.
Btw.... I have been using Ubuntu since version 6.
Good luck
Sep 22, 2014 | Operating Systems
Recovery disk for presario cq58-150SL windows 7 home premium
You may not need recovery discs to recover the software on your computer. HP provides a recovery solution on a separate area of the hard drive. If the hard drive is still functional, you can still perform an HP system recovery from the hard drive as long as the recovery information has not been destroyed or corrupted.
To do a software recovery from the hard drive, turn on the computer and repeatedly press the F11 key until "Windows is loading files..." displays on the screen. If your computer originally came with Windows XP or earlier, press F10 to enter recovery instead of F11.
More info here:
Sep 07, 2013 | Microsoft Operating Systems
My toshiba laptop will not boot since the last windows update. The power light goes on but nothing happens, no post, screen stays black, but the fan starts up. I am hesitant to try to use the restore disc...
Try removing and refitting the battery. If the system doesn't even POST I don't think you'll be able to use the restore disc. Also you might remove the covers on the underside and make sure the memory and hard drive look like they're snug. I hope that works for you. Post back if not.
Dec 23, 2011 | Microsoft Operating Systems
Flashing cursor - HP 6710b vista laptop Hi, Ive got a HP 6710b laptop with a flashing cursor and a black screen. Tried the vista repair disc to restore and do a a startup repair and reset bios to...
Hi yancart,
I see that you are having issue booting into windows on your machine and that you are getting black screen and a blinking cursor.
The issue you are experiencing can be a Hard Drive issue not being detected on the machine or possible something else is wrong with the system to be able findo ut we try doind some steps to check the machine.
>First turn the Machine OFF.
>Turn the Machine ON again then Keep on tapping F12 on your system to boot into the Boot Menu, or if it shows on the screen Press F11 Boot Menu then you should press F11 if your system uses F11 but in regular machine F12 is the Boot Menu.
>Once you have the Boot Menu Screen it should give you options from your Hard Drive to the DVD drive on your machine.
> Select you Hard Drive it should be the first on the list highlighted in Blue then press Enter on it to boot into your Hard Drive.
>Check if this will boot into your Hard Drive if it does not then, possible your Hard Drive is nto detected.
>If you can try to reseat your Hard Drvie from the machine just to see if it went loose, then try restarting the system again and see if it will boot into windows.
>If still the system will still not boot into windows then try setting the BIOS to defaults then restart the machine agian if still the issue is the same then most probably your Hard drive may need replacing.
May 19, 2011 | Operating Systems
When i boot hte computer the ntldr is misssing???
you might have accidentaly deleted th ntldr boot application. one way to solve this without formating your harddrive is; take out your harddrive and put it in to the computer as a slave drive with same operating system and copy the ntldr file. this file actually located at the C:\ drive and is actually hidden. just tick all show hidden file under folder options then VIEW TAB inorder to view and copy this file to your harddrive. once done, take our your harddrive and set again the jumper settings to Master then put it in to your computer. power on the computer and it should be working after this procedure. Else fails, you need to use the recovery disk that came with the system and restore the computer back to its factory setings.
thanks and have a good day!
Apr 06, 2010 | Microsoft Windows XP Home Edition
I have oem vista home premium and need to format
most computer makers put the restore on a partition of the hard drive that is accessed using an F-key on bootup. You should see f-key options displayed (very quickly) on booting up and one will be "restore". For example, on an HP machine, it'll be F11 you hit on boot up to go into the restore partiton.
Feb 07, 2010 | Microsoft Windows Vista Home Premium with...
I want to be able to Mirror or RAID-1 on 2 different drives, then break the mirror and mark the second drive as an active boot drive. After looking around online, I realize that this process is more...
I understand now, and appreciate your taking the time to clarify.
1.Make a backup disk of the current harddrives contents. This is a Restoration Disk.
Has the basic needed files for the Windows O/S, (Repair), but will also allow for a Full Installation.
2.Desktop, not laptop:
Install two harddrives, put them in a RAID1 configuration. Forget about the 'mirror' image program. Leave them both in there in case of a harddrive failure.
3.Laptop, not desktop:
A.There are some laptops that you press a key, or certain keys, when installing a new harddrive, when the old one has hardware issues, or viruses render it unusable. These key/s are pressed, BEFORE the old harddrive is removed. Allows replacement of that harddrive.
There are some laptops that Do Not! There is a workaround.
The above is to replace that harddrive, and may be used to upgrade to a larger harddrive, IF, certain criteria is met.
B.Use an external enclosure, insert the new 2.5" harddrive. Connect the external enclosure to the laptop via the USB port.
Now use an image 'mirror' program such as DriveImage XML, (Free), to copy over the image of the old harddrive to the new one.
Insert the new harddrive into the laptop. You can use the old harddrive in the external enclosure as a Slave drive.
Still only allows THOSE harddrives, to be used on THAT laptop.
Don't be surprised if you have to Re-Activate the O/S on that harddrive. (New one)
C.RAID configuration on a laptop = No
You only have one interface connection for a harddrive, Generally.
(Some gamer laptops use two hardrives internally. These are already configured in a RAID 0 configuration. More storage space. However, if one harddrive goes kaput, all information is lost. I do not believe you are referring to one of these)
The above is only for reference. I have no working knowledge of this program, just know of it's existence.
Sep 23, 2009 | Microsoft Windows XP Professional
I need to reformat a dead harddrive
Hi there !!
Method 1: Perform a clean install of Windows XP loadTOCNode(2, 'resolution'); A clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base: 313348 ( ) How to partition and format a hard disk in Windows XP To perform a clean installation of Windows XP, follow these steps:
  1. Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
  2. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  3. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  4. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  5. Read the Microsoft Software License Terms, and then press F8.
  6. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  7. Follow the instructions on the screen to complete the Windows XP Setup.
If you have successfully installed Windows XP, you are finished. If these steps did not help you install Windows XP, go to the "Next Steps" section.
Here's the link that contains the screen shots as well:
Try these steps & hopefully you will be able to format the Harddrive.
Anurag Shukla
Sep 03, 2009 | Microsoft Windows XP Professional With...
Corrupt harddrive
You state that you have pulled the pins out of your harddrive. If the harddrive is physically damaged then the data cannot be recovered economically. Do not try to take the disks out and put it in another drive: you will loose another one in the process.
I suggest you take the drive to a computer repair shop and see if the drive board can be changed.
Once the drive is working then install it as a slave on a working system, copy all your files to another location and format you old drive.
After formatting you have a choice to discard it (if it is old) or reinstall windows on it.
Aug 12, 2009 | Microsoft Windows XP Media Center Edition...
Hard drive not opening
Can you say virus ???
try a system restore to a previous date in the time which it was working
download and use avg free anti virus
download and run super anti spyware (free edition)
download and run TuneUp Utilities 2008
if after you follow the above instructions and it fails
Please format your harddrive and reinstall everything..
Feb 21, 2008 | Microsoft Windows XP Home Edition
Operating Systems Logo
50 people viewed this question
Top Operating Systems Experts
Brian Sullivan
Brian Sullivan
Are you an Operating System Expert? Answer questions, earn points and help others
