Question about Amcor AL10000E Air Conditioner
Is there a fuse or circuit breaker on this model?
Had a power surege and unit stopped operating. Wonder if a fuse burned out or a breaker can be reset. Model is AF11000E
4 Suggested Answers
  • 358 Answers
SOURCE: no power to portable air condition
If the filters are clogh with dirt , the unit breaker will shut it off ,it's avery common problem , but if after the filters were cleaned it keeps shutting off , could be a bad fan motor or the compressor itself could be grounded.
Posted on Oct 25, 2009
SOURCE: AMCOR 24,000 BTU split system.
I had this same problem. I disconnected the thermostat wire out side at the condenser and reconnected it and it started working. A couple days later it blew the breaker again this time I found the bus where the L1, L2. GR wire connect at the condenser had melted. I wire nutted all 3 wires instead of the using the bus everything is working right again. Hope this helps.
Tim
Posted on Aug 28, 2010
Testimonial: "I checked the outside wiring, and the two power leads from the wall had shorted against the metal grounded plate. Used sealed connectors and all OK!"
Daniel S
  • 4323 Answers
SOURCE: Model AF11000E I will turn
Hi
This means you would need to clean the filter, to clean it turn the unit off and unplug it, then clean the filter completely. After cleaning if the issue returns then replace the filter.
Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 22, 2011
My 12000btu spliter air condition start and stop in 5 seconds
24
EN
TROUBLESHOOTING
CAUTION
If any of the following conditions occur, stop the air conditioner immediately, turn off the main power switch and contact the
dealer.
• The indicators flash at short intervals (5 Hz). Reset the circuit breaker 2 to 3 minutes after the power main switch is turned
off.
Despite the resetting operation, the indicators still continue turning on and off.
• The main power fuse often blows, or the circuit breaker is often activated.
• Foreign matter or water has fallen inside the air conditioner.
• Any other unusual conditions are observed.
Before asking for servicing or repairs, check the following points.
Recheck
Inoperative
• The power main switch is turned off.
• The circuit breaker is activated to cut off the power supply.
• The main power fuse has blown.
• The electric current has stopped.
• The batteries in the remote controller used up.
• The ON timer is set.
• As a protective mechanism for the air conditioner, it does not operate for 3 minutes
immediately after restarting operation or turning on the main power.
Poor cooling or heating performance
• The air inlet or outlet of the outdoor unit is blocked.
• Doors or windows are opened.
• The air filter is clogged with dust.
• The louver is not at the correct position.
• The fan speed is set to low.
• The air conditioner is set
to the DRY or SLEEP MODE.
• The temperature setting is too high (during cooling operation).
• The temperature setting is too low (during heating operation). (heat pump models)
Feb 01, 2015 | Samsung AS18A6RB Air Conditioner
My jmc7000 jenn-air blew a circuit breaker. No power to the unit. There is power to the recepticle. I'm wondering if it blew a circuit breaker, does that mean the problem is most likely a big problem...
Yau say a few conflicting things. First you wonder if it blew a breaker, and then say you have power to the receptacle. If you have poer to your receptacle your breaker if not tripped. There are NO breakers Inside of the Microwave. Only 1 time fuses. So, if your init is dead it has probably blown a fuse inside of the unit. If that is the case. Probably shorted HIgh volt capacitor would be my first guess. If it is jsut dead. it can be other things than just a blown fuse. bad thermal protectors, bad low voltage transformer on main circuit board. Burnt wires. Anything that will cause it to lose power inside the unit. From bad parts to bad connections.
Aug 16, 2017 | Jenn-Air JMC7000 Microwave Oven
The under unit light burned out and tripped the circuit breaker. Replaced bulb and reset breaker but light doesn't work. I see there is an internal fuse. Could this be the problem as there is no power...
These remarks are not make and model specific.
Did you test the new light bulb?
I would not normally expect a burned out light to trip a breaker.
You may have a blown fuse. I suspect the fuse you see is to protect the oven. If you popped a breaker, you may have blown a fuse. I'd be looking for a short somewhere, maybe in the wire that powers the light, maybe in the hardwire that supplies the oven.
Make sure you turn the power off before you go poking around. And, above all, avoid the silver can inside, it IS lethal.
Let me know if this helps.
A
Sep 21, 2009 | Maytag MMV1153A Microwave Oven
Maytag Atlantis electric dryer Model
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 08, 2009 | Dryers
No heat in dryer model # 96591420
2. Heating element
3. Thermal fuse
Jul 31, 2009 | Kenmore Dryers
Our Kenmore model 96292810 clothes dryer has stopped heating. What is the likely problem?
1. No power to the dryer(If you have power, skip to the next possible issue)
2. Heating element
3. Thermal fuse
Jul 18, 2009 | Dryers
I have a Whirlpool dryer Model # LGR7648K20 that just stopped heating. THE DRUM TURNS BUT IT WILL NOT HEAT.
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to Good luck
Regards:
VOTIT
Dont forget to rate:
Jul 01, 2009 | Whirlpool Dryers
Amcor AL10000E Air Conditioner Logo
20 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
