Question about Vulcan Ovens
What causes a vulcan vc4ed oven to not heat right,
Or when it is not heating fast enough
bigg t
  • 640 Answers
SOURCE: vulcan oven chatter
Sounds like your losing the voltage to the coil on the contactor.Are you handy with a multimeter?I can step you through it.
Posted on Feb 12, 2009
grandadfixer
  • 99 Answers
SOURCE: replace the upper heating element
hi E mail me model no can proberly sort it. regwoolleu@uwclub.net
Posted on Jun 11, 2009
  • 1144 Answers
SOURCE: Vulcan SG4D convection oven is shutting off.
http://www.vulcanhart.com/manuals/F-35626.pdf
Since you were lacking a few specifics, go to this web site and it will have the service manual on your unit.
Hope this helps
Posted on Jul 25, 2009
garing
  • 998 Answers
SOURCE: Oven heats, but does not get to correct
when you first turn it on both elements should come on(your top element may be burned out)if so turn breakers off just take out the screws on the mounting plate pull out and take wires off and replace
Posted on Aug 25, 2009
heatman101
  • 43501 Answers
SOURCE: oven not properly heating
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 07, 2010
What causes a duke E101 convection oven to not cook evenly?
If it's getting hot, but it isn't cooking as fast as normal, your convection blower/fan may be out. If you can hear the fan running, but the oven isn't getting hot enough, then you most likely have a heat element or thermostat problem.
Fan and blower problems tend to be a bit more common with convection ovens.
Jul 19, 2014 | Duke E101E E Series Single Convection Oven...
Oven does not come up to Heat as Oven control denotes
It is probably the thermistor in the oven cavity top right hand corner sometimes these get scraped by sheet pans or scrape the wires
Nov 17, 2010 | Vulcan SG4D Gas Single Oven
Kenmore 790.75738892 won't heat up enough or fast enough what can I do to fix the problem?
most likely justneed a temp sensor. there is a rod that comes through back of oven. you will find it inside oven on back wall.
Aug 01, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
F8 code ?
your oven is not heating up fast enough
make sure the blower motor is working right and then check the high limit thermostat it is located on the back left of the oven
Jan 21, 2010 | TurboChef TORNADO Electric Oven
Looks like our church just received the Vulcan VC4ED convection oven - 208 volts 60 amp. We have the 60 amp breaker but what gauge wire from the breaker to the oven do you recommend? I have to run about 35...
use 3 -- 6 gauge copper wires, you could get by with 2--6 gauge wires for the two hot phases and 1--8 gauge for the neutral connection,but with that long a run use all 6 gauge so you don't experience any voltage drop,also in your community you may need to check the local codes on grounding and need to add a separate grounding wire,which you can use an 8 gauge for this wire connection, if you use aluminum wire(which I highly DO NOT reccomend) you will need to get one gauge larger as in 3--4 gauge aluminum to carry the same current as copper wire
Dec 08, 2009 | Vulcan VC4ED Electric Single Oven
Oven will not ignight
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Nov 08, 2009 | Vulcan SG4D Gas Single Oven
No heat to the oven
if the heating element "rod" doesn't turn orange (hot) when it's on it's bad so; remove the heating element and get a new one from an appliance parts site on the web and install it don't forget to unplug the range first!
Apr 20, 2009 | Vulcan ECO2D Electric Single Oven
Vulcan oven chatter
Feb 12, 2009 | Vulcan ECO2D Electric Single Oven
Ovens Logo
48 people viewed this question
Top Vulcan Ovens Experts
John Tripp
John Tripp
Treefrog15
Treefrog15
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
