Question about Canon PIXMA MP530 All-In-One InkJet Printer
When I tried to print a page it jammed. When I looked inside, a small felt piece about 9 inches long appeared partially. On instinct, I just removed the felt piece. How do I put it back and remove the jammed piece of paper? Jim
    President:
  • 2,306 Answers
If its a spongy rubber piece it goes on the bottom of where the printhead travels. You match up the little square pieces to the cutouts in the frame. An index card can help you push this piece back into the machine if you push gently from the front. This piece catches ink when you print borderless, and can be left out without a problem.
Posted on Jun 23, 2009
Brother mfc 8670 paper jam duplex
remove the small, or scratch into pieces inside the duplex to clear the paper jam.
Feb 10, 2014 | Brother MFC-8670DN - 30 PPM Multifunction...
Paper jam
Follow your manufacturer isntructions to removing jams and to the locations of possible jams. Other than that, just look for any evidence of jams. Open doors, remove trays, remove cartridges all in an effort to see if there are any pieces of paper inside. Using a small flashlight will help detect small traceds of paper
Mar 19, 2011 | Epson Computers & Internet
My panaboard UB5815 error j but there is no paper jammed in the unit
Hi John, there may be the smallest piece right down in the throat area. Occasionall there can be some also completely rolled up in the paper shoot behind the rolls of film. I always remove the paper and turn it around prior to printing. At the end of each printing session, the next piece is drawn in and partially curled for 4cm. This will cause it to roll up inside at the next printing attempy- 9 times out of 10- Ross
Clear the error by turning off for 30 seconds.
Mar 05, 2011 | Panasonic Panaboard UB-5815
Hi, how do fix a paper jam? 1st page printed ok, 2nd page jammed. I pulled it out backwards but the centre of the page was torn and a small piece missing. I can't see where I can clear that small piece of...
Unplug the power cord and open the cover and remove the TONER and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Feb 11, 2010 | Brother HL 1240 Printer
My 3175 is jamming on the paper rollers each time I try to print. The paper feed through partially and then jams; with the printing done half way down the page. I have had a good look inside at the front...
That model has a problem with the exit sensor, it gives false jam errors. It is in the upper left side above the fuser. The part number is 0604-001393 and I believe www.precisionroller.com has the part.
Feb 04, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Small paper jam
Unplug the power cord and open the cover and remove all the cartridge and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Feb 04, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Paper jam while printing on BROTHER MFC-290C all-in-one
hey
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 03, 2009 | Brother MFC-290C Printer
Printer is creating a crease and smudge down center of page.
There sounds like there is somthing in the path of the printhead. Using a flash light, remove back cover of machine and look for a small piece of paper,etc. Be careful not to jam anything in to th machine. It may take running a thick piece of paper through manually with your hands to remove the object.
Feb 12, 2009 | HP LaserJet 1012 Printer
Paper jam notification after printing one page, no paper jam
try this
alternative :
Nov 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
Small piece of paper caught inside printer
Here you will find a video and step by step instructions for clearing paper jams for your printer. Hope this helps. Please remember to rate this information.
Thanks
Nov 15, 2008 | HP Photosmart C6180 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
51 people viewed this question
old marine
old marine
