Omega MARS-22 Remote Vehicle Starter with Keyless Entry Logo
A
Anonymous Posted on May 13, 2014
What would cause my truck to start and then immediately die when using remote start?
When it does this it tries to start two more times but dies both times
paper7559
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Aug 14, 2014
paper7559
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
6773
Points
31
Here is the link to download and print the Mars Manual.
You may find your answer in it.
  • paper7559 Aug 14, 2014
    Here is the link to get the manual.
1helpful
2001 explorer sport , fuel pump? vacuum leak? 619 scan tool data provided, any suggestions/solutions
The fuel pump is suspect but I believe there's also a fuel filter inline on the underside of the drivers side chassis. Fuel works off pressure so if the filter is clogged, the pressure remains between the fuel tank and the filter. Once the fuel has siphoned off between the filter and injectors, it dies but because there's positive pressure at the fuel pump, it won't come on until the pressure slowly seeps past the clog after hours. It's worth a look!
97 ford ranger 4cyl starts and immediately dies. Has some fuel pressure, but haven't put a pressure gauge on it
If it dies immediately when you remove the starting fluid the issue has to be with fuel delivery.
Friends car, he has not got a computer. It usually runs as sweet as a nut. Engine starts then cuts out. Sometimes runs for 20 minutes, then cuts out.
car starts then cuts out after 2 seconds, please help!!? ' Yahoo ...
https://answers.yahoo.com/question/index?qid...
Mar 22, 2010 - Car starts then cuts out after 2 seconds, please help! ... I went to start it this morning, it started up fine but only for literally 2 seconds then it just cuts out. .... In every after how many kms we should engine oil in the motor bike?
Engine fires up, but cuts out. - Gassing Station - PistonHeads
www.pistonheads.com/gassing/topic.asp?t=1128508
PistonHeadsMar 23, 2012 - When the engine is cold it needs a bit more fuel to stop it cutting out(sort of like ... If you can't do it yourself then you shouldn't need to take the car to your ... Also, starting with your foot on the throttle seems to cause all sorts of ...
What is the problem if the car starts and then dies almost ...
askville.amazon.com > Transportation > Automotive
Nov 22, 2010 - Askville Question: What is the problem if the car starts and then dies almost immediately? ... I waited for my kids, and when I tried to start it back up, theengine turned over but then died immediately. ... 1. out of gas, or bad gas
fuel system - Engine starts but almost immediately cuts out 3 ...
mechanics.stackexchange.com/.../engine-starts-but-almost-immediately-c...
Jun 26, 2014 - When I start the car the engine catches but then dies almost immediately. I have to restart the car 3 or 4 times like this until the engine starts ...
Car starts, then cuts out straight away!! - boards.ie
2answers
1helpful
Vehicle starts cold but runs only for about 45 seconds, then dies. No reving just before it dies. Subsequent starts die immediately.
SOUND LIKE PROBLEM IS IN THE FUEL SYSTEM AND TIMING OFF.CHANGE FUEL FILTER HAVE FUEL PRESSURE CHECK.IT SHOULD RANGE FROM 34 - 40 PSI AND 53 - 59 PSI.SHOULD BE NO LOWER.IF FUEL PRESSURE GOOD.HAVE TIMING CHECKED.MAKE SURE PLUGS + WIRES GOOD ALSO CAP AND ROTOR.HAVE INJECTORS CLEANED.ALL THIS COULD CAUSE THE PROBLEM YOU HAVING.
1helpful
2answers
While driving the engine dies
If engine dies while driving and locks trigger then program your remote not to lock/unlock when turning on/off ignition. My car did that for a while before i figured it out and now my car actually runs 100% better and I've had no problems since.....
Top Omega Juicers Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you an Omega Juicers Vehicle Part and Accessory Expert? Answer questions, earn points and help others
