SOURCE: my old trane air conditioner
Sounds like either a relay or start capacitor has failed, Sorry, but, this is a problem only a tech should approach. For safety reasons.
SOURCE: Trane XE1200 Fan Motor
Most likely problem with a not-so-old motor is the run capacitor for the fan.
Some units have fan & compressor capacitor combined into one -- others are separate.
The capacitor can be tested with a multi-meter with an MFD setting -- it should read reasonably close to the specs marked on the capacitor.
Charlie
SOURCE: We require condenser fan motors for Interclisa
Hi, this is an odd voltage 380 volts. Is it a 3 phase unit? To get a 220 volt 50hz condenser fan motor, you will have to go through a refrigeration/air conditioning parts house and order this. 60hz you would have no problem finding one in stock. Carrier is a good unit, and have been around for many years. You shouldn't have any problems locating one.
Sincerely,
Shastalaker7
PS You will need to go through a wholesale parts house.
SOURCE: Why is my fan motor on my trane air conditioner
Check the capacitor for the fan. Has the fan been replaced recently? If so make sure the start lead is connected to the capacitor.
AireCo, United Refrigeration, online, electric motor shop.
