Question about Video Game Consoles & Games
5.5.4 I'M PICKING UP GOOD VIBRATIONS - Video Game Consoles & Games
Hi, my car starts vibrating at 2800 RPM and vibrations dissapears at 3000 RPM.
does it have the same acceleration at that speed, if it does not accelerate so well it is called a flat spot and will almost certainly need a good mechanic to sort it out
If acceleration remains as good in this range as through the rest of the rev ange add detail and please resubmit
Jun 04, 2015 | 2007 Toyota avensis 1.6
How to operate an acoustic fender electric guitar Fishman tuner
If it's the same as mine, the tuner has a little clothespin clip. You clip that on to your guitar's headstock and turn it around till you can see the screen while picking strings. The tuner picks up vibrations through the headstock and with it's microphone and it tells you what it hears. The little needle tells you the note and if the string you're plucking is below that note, above that note or right on. You have to figure out if you're in the right octave on your own.
Dec 30, 2014 | Fender Music
2001 Mercury Grand Marquis random vibrations...
if your lucky might just be wheel balance so get ALL wheels rebalanced but more likely to be wear in the steering/suspension but try the wheel balance first as cheaper option then have steering etc inspected good luck
Mar 25, 2014 | Cars & Trucks
I have a bad vibration on my 94 fxdlonly6 when i am slowing down or at a certain rpm but it is totally fine at a steadypace or when accelerating
Ok, the Dyna series bikes have rubber mounted engines but the mounts have a tendency to only absorb the higher frequency vibrations. When the engine is idling or running at RPM's lower than about 2000, you can feel the engine vibrations. I have a 1994 FXDWG and it does the same thing. This is normal for all engines with rubber motor mounts. However, since the bike has quite a number of years on it, it would be a good idea to check the mounts and the stabilizers to see if they might need replacement.
Good Luck
Steve
Apr 30, 2011 | Harley Davidson FXDL Dyna Low Rider...
Ion profile pro -- recording picks up background sound
If you're picking up background (room) sounds the TT pickup is acting as a microphone. Isolate it physically from air- and room-borne vibrations. Turn your speakers down so they don't add to the problem, or use headphones while recording.
Feb 14, 2010 | Audio Players & Recorders
Noisy Blower Motor
could be trash leaves acorns ect in housing that the blower is picking up then dropping when the unit is off. try cleaning the housing the motor fits into
Aug 04, 2009 | Buick LeSabre Cars & Trucks
Reciever not picking up guitar
make sure the batteries are good..try turning it off and on. some recievers have a reset button or it could be on the guitar. good luck
Aug 01, 2009 | Activision Guitar Hero Wireless Les Paul...
Slowness and Audio Vibrations
firstly, your startup is slow more than likely because you have too many unecassary programmes running on start up, so download the excellent free ccleaner programme from the link below and analyse the system and run a clean up and also click the tools tab and startup tab, here you will see all the programmes running on satrtup, you can delete them in this programme from the startup, althogh this doesnt delete the entire programme, only the start up. http://www.filehippo.com/download_ccleaner/ the noise from the audio files needs to be explained a little better, unless you mean the vibration from the dvd drive, if so this is common on some drives when they have difficulty reading files, or if you mean files that are on your pc are causing vibrations, the only thing i can think is that maybe your onboard mic volume or boost is set too high and is picking up the sound and reverbing.
Jun 04, 2007 | Sony VAIO VGN-FS980 Notebook
Video Game Consoles & Games Logo
41 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
