Question about exhart Battery Operated Silver Shimmer Hanging Chandelier
Why lite comes on for 30 sec's & goes out immediately (repeatedly) -won't stay on (brand new batteries)
V # 8020 have new battery & cord. displays comes
if you still seeing the backlight of the display, your lcd maybe bad in shape. the display assembly needs to be replaced. or maybe some other problem causing it too. if you still needs help on your verifone8020, call (775)358-2922 look for randy and maybe we can help you. thanks
Jul 12, 2011 | VeriFone VX510
This my sec trans and the d4 light cont to blink, replace tcm (brand new) now the car stays in sec. gear & d4 light is on but not blinking. so I place old tcm back in and the car drove d4 still remain...
you have problem with your transmission computer located under your dashboard behind your radio comparment i had the same problem replaced that for a used one or rebilt one and solve
just make sure they sincronized again with transmission
May 04, 2011 | 1992 Honda Accord
Why does pilot light turns on gas burner only to have it go out about 10 seconds later? 30 to 40 sec later repeats,without lighting. What is problem? once in awhile, it will light..not often. The burner...
Hello
Sounds like the thermocouple is going bad.The thermocouple is a thin tube that runs from the pilot lite to the gas valve.
What it does is it sences the heat from the pilot lite and keeps the gas valve open to allow the pilot to stay on.
This can be easily repaird by shutting off power and gas to your heater and removeing the thermocouple from the gas valve,then unclip or unscrew it from the pilot lite area.
Any plumbing supply store or home depot or lowes should have these.
Once you get a new one,install to gas valve and pilot lite area then turn on power and gas to heater and follow pilot lighting procedure,you may need to hold gas on for 60 seconds.
Here is a picture of the thermocouple so you know what to look for.
http://thermocatalytic.com/Thermocouple.JPG
http://homerepairgeek.com/wp-content/uploads/2010/12/furnace-thermocouple.jpg
Feb 10, 2011 | Honeywell Programmable Thermostat Heater
On power up the green light is on for 2 sec.
problem with the main board inside of the DS Lite. Its not staying on with the voltage being provided. To verify this. Plug your DS Lite into a working outlet and see if it stays on.
If it doesn't stay on then take the battery out and only hook up the ac adapter to it and see if it stays on.
At that point if it doesn't stay on, try to use another AC Adapter to see if it stays on, if it doesn't then you know for sure the main board is bad and you would need to get a new ds lite.
Jan 01, 2010 | Nintendo DS Lite Console
Ds lite will not power on, screen blinks for 1sec then power soff
sounds like a bad battery or the battery is not getting a charge.
Dec 27, 2009 | Nintendo DS Lite Console
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
1994 gp 3100 ,wont start, turn key getting all the dash lites but starter not engaging, security lite is flashing, the car was drove to my hse i know it runs any ideas, battery is new, key is a #7.with key...
You need to set the parking brake, Turn the key on let it sit like that for 10 mins. the sec light will either start flashing or will stay on or go off when done (This will reset)
REPEAT 3 times!
Then you should be able to start the car after the 3rd time!
Apr 19, 2009 | 1994 Pontiac Grand Prix
exhart Battery Operated Silver Shimmer Hanging Chandelier Logo
410 people viewed this question
Top exhart Toys Experts
Andrew Taylor
Andrew Taylor
Are you an exhart Toy Expert? Answer questions, earn points and help others
