Question about Maytag MMV1153A Microwave Oven
What does error code 5E mean?
How can it be fixed?
My kenmore over the range microwave is showing an error code of 5E or SE . . . What does that mean?
it's the touchpad, you have to stick a new one, call a technician or buy the touchpad corresponding to your microwave oven model
https://www.applianceblog.com/mainforums/threads/51787-Kenmore-Elite-SE-error-code
Nov 05, 2017 | Kenmore Microwave Ovens
An error code 5E is on my Samsung microwave? What does this mean and how do I fix the problem?
SE means it has a shorted membrane switch on the keypad, or at least it thinks it does. Unplug the oven for 30 minutes to see if that clears the code. If not, you might actually have a bad switch.
Jul 31, 2016 | Samsung Microwave Ovens
Model # JMV8208BAS
On a GE or Hotpoint, it usually means the keypad is defective. On some other brands, it means there's a sensor error.
May 16, 2016 | Microwave Ovens
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
-se- is displayed on the screen, what does it mean?
Usually means "Sensor error". The problem is usually associated with the circuit board for your touch pad on the front of microwave. More than likely a bad contact/connection on one of the plugs in the back of that panel.
Just type the following in your search engine and the video explains it all. "samsung microwave se (5e) error fix". Hope this is your fix and that you are OK with taking it apart. MAKE SURE ALL POWER IS REMOVED BEFORE GETTING IN THERE!! good luck!
Oct 08, 2015 | Samsung Microwave Ovens
What does 5E on microwave mean?
I think that's supposed to be an "SE" error code which means shorted keypad on Samsung microwave ovens.
Oct 19, 2014 | Samsung Microwave Ovens
I have a se or 5e code what is it
Thank you for your post, friend!
I understand that your Frigidaire microwave is displaying the error code "SE" or "5E". I have researched and the error code seems to be "SE" which means keypad is stuck. In order to remove the error code the keypad would need to be replaced.
Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this helps to some degree. -Matt
Sep 26, 2014 | Frigidaire Microwave Ovens
I have a Kenmore microwave with an error code SE or 5E model No: 401.80082700
The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
Not really a DIY job. Microwaves can retain up to 2200V even when unplugged.
control panel frame assembly ("control") , which comes with a new keypad already installed lists for $59.99 fyi.
Feb 22, 2018 | Microwave Ovens
Recently purchased this microwave (4-5 months ago) 5E error light comes on. Unplugged worked for short period - lights came on and off, things started beeping and the 5E came back on. Have repeated this...
"SE" means you have a shorted membrane keypad. It's not uncommon for it to be intermittent or partially operable.
Since it's under warranty, I would contact Samsung for a free fix. See your owner's manual.
Jul 06, 2011 | Samsung SMH9151ST Stainless Steel 1000...
Maytag MMV1153A Microwave Oven Logo
19 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
