Question about Mitsubishi WD-57734 57" HDTV
I changed the bulb and it shut off in ten minutes the vender suggest I use the reset button on front panel. is this safe?
LG washing machine shuts off randomly, why?
only suggestion, next time it happens, unplug like you've done and then hold in power button for 15 seconds to see if that resets it.
Aug 30, 2015 | LG WM3470HWA Front Load Washer WM3470HWA
I have a Mitsubishi WD 60738 and the stand by light on the front of the tv was staying on and was orange. I removed the power supply and blew out all the dust and reinstalled the power supply and now the...
Hello Jeff;
If the TV does not turn on or off, does not respond to the remote
control or the control panel buttons, or has audio but no video:
1.) Press and hold the POWER button on the control panel for ten seconds. The TV will turn off.
2.) Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost.
If the TV does not respond to the remote control or to the control-panel buttons and TV will not power on or off.
• Unplug the AC power cord for 10 seconds.
• Press and hold the POWER button on the control panel for 10
seconds to perform a system reset.
If the TV turned itself off and the light on the front panel started to flash:
• Momentary power fluctuation can cause the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again.
• If the TV does not stay on, press the POWER button on the
control panel for ten seconds to perform a System Reset. If this happens frequently, obtain an AC line power conditioner/surge protector.
• An unusual digital signal may have been received, triggering a
protection circuit. Wait for the light to stop flashing and turn TV
on.
If the TV will not power off, press the POWER button on the control panel for ten seconds to perform a System Reset.
Should you still have problems, call for assistance at 1(800) 332-2119
I would not recommend using compressed air or any other method that would blow dust around- since the dust could make its way into the set's circuitry via the grille or vents and cause problems. Use a vacuum cleaner with a brush attachment instead.
Mar 12, 2015 | Mitsubishi Televison & Video
Reset Water Filter Button; Stays Red after changing filter on Frigidaire Refrigerator/SideBySide LGUS2642L
Thank you for your inquiry, John Sodt!
From what you have described your Frigidaire refrigerator's filter display is not changing back to green after the filter has been changed. This could be a miscommunication within the control panel and to clear out any miscommunications I would suggest performing a reset on your refrigerator. The best way to reset your refrigerator is to unplug the power cord for roughly ten minutes. If that does not help your issue you may want to speak with a professional technician. Good luck. -Matt
Feb 11, 2015 | Frigidaire Refrigerators
Light for filter does not turn green
Hi friend, thanks for your post!
I see that your filter light is not turning green on the panel of your Frigidaire refrigerator. If you have recently changed your filter I would suggest pressing and holding the filter reset button. Should that not correct the issue I would perform a reset on your refrigerator and you can do that by unplugging your power cord or flipping the household circuit breaker off for roughly ten minutes. I hope this has been beneficial. -Matt
Oct 10, 2014 | Frigidaire Refrigerators
Frigidaire LEQ1442ES1 will run only a few minutes. Heats up runs aprox 3-4 minutes then shuts off, starts beeping and lights on the right side of the panel blink rapidly. Pushing cancel stops it and y
Good Morning friend, thank you for your post!
From my understanding your Frigidaire dryer, LEQ1442ES1, will run and then shut down after three or four minutes. I would recommend a reset on your dryer which you can do by unplugging your power cord for roughly ten minutes.
If that does not correct the issue it sounds like a potential problem with your control panel or a sensor. I would suggest having a professional come out and repair your appliance to avoid any unnecessary part purchases. -Matt
Oct 10, 2014 | Frigidaire Dryers
Control panel not working
It might just need a reset. Press the Pause and off button, then pull the plug from the wall.
Wait ten minutes and power it up again. Check the door very carefully, make sure it is shutting correctly.
Try a restart.
Mar 18, 2014 | Hotpoint First Edition WMA20 Front Load...
Mitsubishi big screen model vs-50604. i hit a button on the front of the tv and now all i have on the screen is a caption that says installng guide plus data now. is there a reset on the tv anywhere. i...
Open the front panel. Just to the left of the RCA imputs is a small button that says reset. You may need to use a pen or paper clip to press it. Press that and the system will reset .That should fix your issue, or do like me and get a Sharp. LOL. My bulb went out 2 times and I got irritated with it.
Nov 07, 2013 | Mitsubishi VS-50605 50" Rear Projection...
I just purchased my Mitsubishi WD52628 projection television used as it only needed the bulb replaced. I replaced the bulb, however now it will only run for a couple of minutes then the remote and all...
it sounds like the bulb is causing it to overheat make sure the fans are running and that no of the air vents are clogged or blocked. Also did you buy a cheap alternative or authorised bulb for it?
Feb 28, 2011 | Televison & Video
Error 5400
Solution: Press ON/OFF switch and wait a few minutes before powering back on the device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear an error, power off the printer and power it back on. Before powering back on the printer, wait five to ten minutes.
  1. On the operator panel, press the <ON/OFF> button. (The display will go blank.)
    Note: On rare occasions, it may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately five to ten minutes and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
FYI - There is a firmware update for this unit as well
Apr 29, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Mitsubishi WD-57734 57" HDTV Logo
37 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
