Question about Samsung Office Equipment & Supplies
Samsung clx-4195 paper feed problem causing paper jam
ghassun
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
  • 92 Answers
SOURCE: Samsung CLX 2160 "paperjam2" problem
Hi ...
IN CLX 2160, paper jams usually occur in three areas of a printer. The following error messages indicate the area in which the jam has occurred:
  • Jam 0 indicates the paper failed to pass through the first sensor.
  • Jam 1 indicates the paper failed to pass through the second sensor and has jammed around the toner cartridge.
  • Jam 2 indicates the paper failed to pass through the second sensor and has jammed near the fuser.
Your error shows paper jam2 but i am giving you directions to fix the paper jams indicated by each error message so that you can handly any kind of paper jam issue with your printer.
Paper Jam 0 When your printer displays Jam 0, paper has failed to pass through the first sensor.
To remove the jammed paper, follow these steps:
  1. Power your printer off.
  2. Open the cover of your printer.
  3. Gently pull the paper toward you to remove it from the printer. Note: If you do not remove the paper slowly, you can damage the printer and the printer will require service.
  1. After removing the paper, make sure there is no additional paper in the paper path.
If your printer still displays Jam 0 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Paper Jam 1 When your printer displays Jam 1, the paper has failed to pass through the second sensor and has jammed around the toner cartridge.
If your printer still displays Jam 1 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Paper Jam 2 When your printer displays Jam 2, the paper has failed to pass through the second sensor and has jammed at the fuser.
If your printer still displays Jam 2 after you turn on the printer, unplug the printer, and then repeat the steps above. Make sure all paper has been removed and the printer's rollers are in their correct positions. Before turning your printer back on, make sure all the cover doors are fully closed.
Please vote if this helps ... Cheers :)
Posted on Jul 29, 2009
SOURCE: CLX-2160N Paper Jam?
my printer Samsung CLX-2160 give me the message "paper jam", but I checked a lot of times inside and there is no paper. What's the real problem? How can I solve?
Posted on Sep 07, 2010
  • 670 Answers
SOURCE: Paper keeps jamming on Samsung CLX-3160 FN. How do
Paper jams are typically caused by the rubber rollers inability to put paper through the machine. Try cleaning the roller with damp rag to see if that improves performance. If the roller is badly worn, it will need to be replaced.
Posted on Oct 04, 2010
Testimonial: "This solution worked for me. Thanks for the worthwhle advice!!"
mariolands
  • 2296 Answers
SOURCE: I have a paper jam
If the paper is jammed inside the machine follow these steps:
1. Open the front cover and pull the toner cartridge out, lightly pushing it down.
2. Remove the jammed paper by gently pulling it straight out.
3. After removing the jammed paper, make sure there is no additional paper in the paper path.
4. Insert the toner cartridge and close the front cover.
If the paper is jammed in exit are follow these steps:
1. Open and close the front cover. The jammed paper is automatically ejected from the machine.
2. Gently pull the paper out of the output tray.
- If you do not see the jammed paper or if there is any resistance when you pull, stop and go to the next step.
3. Open the rear cover.
4. Carefully remove the paper by pulling in the direction.
- If the paper tears, make sure that all of the paper fragments are removed from the printer.
5. Close the rear cover. Printing automatically resumes.
Posted on Nov 17, 2010
Samsung clx-3150 paper jam. it will only feed 20wt paper from bottom tray. anything else stops and i get a paper jam 0 error message
Check the specs operators manual or go to the Samsung web site look up the specs for your machine. The weight of your paper may be greater then the machine can handle.
Nov 17, 2015 | Samsung Office Equipment & Supplies
Why will printer not pull paper all the way from paper feed, it only pulls around 2" and then says paper jam?
sounds like the feed tires are dirty try cleaning them or try the bypass feed to see if that helps.
Aug 08, 2014 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
My samsung clx 3170 keeps jamming up after every copy. You can see where the paper is trying to roll thru. because there is a slight indentation in the paper about a third of the way on each piece of...
Use this link and you will have all the information on your printer you should ever need
http://www.samsung.com/au/consumer/print-solutions/print-multifunctions-copiers/colour-multifunction/CLX-3170FN/XSA/index.idx?pagetype=prd_detail&tab=support
good luck
Nov 29, 2010 | Samsung CLX-3170FN All-In-One Laser...
Paper keeps jamming on Samsung CLX-3160 FN. How do I prevent this from happening?
Oct 04, 2010 | Samsung CLX 3160fn All-In-One Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
Samsung color laser MFP CLX-3175FW. Paper jams after the first page is printed and continues to jam each subsequent page. This is the third printer we have tried. Using a MAC computer. Suggestions...
clean the pickup roller that feeds the main tray.
This is an ongoing problem with this printer, even in the single function printers.
I used a toothbrush and water, scrubbing horizontally.
Jul 05, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
Mar 04, 2009 | Samsung CLX-2160N All-In-One Printer
CLX-3160FN Paper Jam when there is no paper jam.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung 6210 paper jam
open access(load area) check feed roller take a q tip and use rubbing alcohol and clean photo eye that detects paper be sure all jammed paper is removed
most jams are at the exit and there may be some paper obstructing that area
insert card stock through the paper path
insert ine
Dec 30, 2008 | Nikon COOLPRINT Thermal Printer
322 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
