Question about IBM 05K9567 14.1 in. Flat Panel LCD Monitor
I have a smashed LCD screen on an IBM T21. Can you provide the instructions for replacing this with a new one?
Gerard Connolly
Re: IBM0A55 TFT LCD XGA panel
Thanks for you help, I will try that. It does not look as though that you are going to give me the nuts-and-bolts of taking it apart.
Posted on Nov 04, 2007
  • 93 Answers
Re: IBM0A55 TFT LCD XGA panel - IBM 05K9567 14.1 in. Flat Panel LCD Monitor Computer Monitors
Are you in possesion of the new screen ?
0 characters
3 Points
Were is the CMOS battery on IBM Thinkpad 1830 R51?
The cmos battery for your model of computer should be just under the bottom shell cover, you may even be able to get to it from one of the covers on the underneaf or else you going to have to take the whole of the bottom of the shell off of the laptop.
it should be either yellow or blue with a little cable on it.
Hope this is of help to you.
Sep 22, 2012 | IBM Thinkpad R51 1836 Laptop Lcd Screen...
The picture is scramble
I see the pictures, you need new screen, the LCD panel is cracked, sorry for the bad news! The screen will cost more tahn the new monitor.
Jun 07, 2010 | Gateway 24" Widescreen Flat Panel TFT LCD...
Can i replace my Gateway laptop tft screen with a new lcd screen?
The screen resolution is a combo of:
  1. the screen's capability
  2. the video card's capability
  3. the driver's settings
If the above screen is made for this laptop (as it appears to be), then the settings you had should still be there.
Jul 29, 2009 | Toshiba LCD TFT Monitor
Monitor Blackout
Here is a website that provides instructions to repair the inverter on a similar model:
Feb 23, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E171FPb 17" TFT LCD Flat Panel Monitor Problem
The LCD and or the LCD inverted has failed. it is an unfortunate fact of life that nowdays it is cheaper to replace that monitor that to aquire parts for repair
Here is one on Ebay:
You can buy a new 19 for about the same price
Jan 21, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Spotting on IBM R40 TFT Screen
you can get a screen replacement cheaply on ebay/craigslist
Aug 31, 2008 | IBM 11P836402 for ThinkPad R40 Monitor
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Dell e171fpb lcd monitor
The driver tabs between the LCD panel and it's controller board have failed.
These are very fragile and not repairable for anything in the cost effective range.
Best option is to either find a new panel to replace it, or get a new monitor.
Sep 10, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell 1703 FPi 17" TFT LCD Flat Panel
you have snap frame around the screen itself use flat screw driver fine edge, theres about four locations that snap into slots work them away and remove frame, then remove screws on back will seperate ,you will have to remove monitor button panel board to, once inside, four screws around screen itself once in side,this will lead you to power connection inside main screen frame, the board and the connections
Sep 06, 2007 | Dell 1703FPt 17" TFT LCD Flat Panel...
IBM 05K9567 14.1 in. Flat Panel LCD Monitor Logo
582 people viewed this question
Top IBM Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you an IBM Computer Monitor Expert? Answer questions, earn points and help others
