Question about Garden
Removal of f935 pto clutch - Garden
4 Suggested Answers
SOURCE: cannot remove pto clutch assy
You can use an impact wrench, but more than likely the bolt is unscrewed and you will need to get a set of pulley pullers to pull the clutch.
Posted on Apr 04, 2009
  • 6 Answers
SOURCE: drive pulley won't come off engine shaft
put the nut back on were it is even with the stud and hit with a hammer while pulling on the pulley
Posted on May 27, 2009
  • 523 Answers
SOURCE: how to remove the pto clutch on a snapper model # LT180H48DBV2
Posted on May 05, 2012
I have a cub cadet ags2130 that stalled with the pto engaged. Now the engine will not start due to the pto not disengaging. How do I disengage the pto.
Sounds the clutch may have failed but try just unplug it just it an electrical problem. Also check to see any of the v-belt cords came loose and wrap themselves up in the clutch. I had one a couple years that this was the problem.
Another thing you could do is completely remove the PTO clutch to see you have a bearing failure in it.
Oct 23, 2014 | Garden
How do you remove the center bolt on the pto clutch
The easiest way to remove one is an impact wrench; otherwise, you would block the flywheel of the engine so it won't turn and use a pull bar.
You will need block the flywheel upon installing as you will need to torque the center bolt to about 55 ft lbs and don't forget to burnish in the PTO clutch.
Jul 30, 2014 | John Deere Garden
How do i get pto cluch to engage
If this has a lever activiated PTO make sure it is engaged all the way- and the fluid level is good; if it is electrically activated, check that you have power to the switch. If now power at switch- check fuses- if theer is power at switch, the switch is bad.
May 20, 2014 | John Deere Garden
How can i get pto cluch to ingage?
This problem needs more information provided.
Look for safety interlocks that have not been engaged, or possibly broken. The switch under the seat will not allow the PTO to engage if it does not detect someone in the seat.
If the PTO is electric, look to see if the plug is loose at the PTO.
Check to make sure that the PTO mounting bolts are still secure.
Remove clutch
I'm assuming you're referring to the PTO clutch on the bottom of the engine shaft. There's a 5/8" bolt that goes up through the clutch into the shaft. Remove it, but then turn it back in about 10 turns and use a wheel puller to start getting it off. You might have to c-clamp the PTO/clutch top and bottom together to get both pieces off. Once the assembly starts coming down the shaft, you can probably remove the wheel puller, remove the bolt completely, and pull the PTO/Clutch off by hand. Be sure to unplug the PTO/clutch before removing it. Also, many of these have a spacing washer on top of the PTO/Clutch that comes off in the process. BE SURE to put it back on before replacing the PTO/Clutch. DO NOT hit anything with a hammer to try to break it loose - you'll most likely NOT get the part off and most probably WILL damage necessary parts.
Jul 29, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
How to remove pto clutch on cub cadet model 2186
unplug it remove the center bolt and remove the bolt that stops the clutch from rotating
Apr 23, 2012 | Oregon Scientific Electric PTO Clutch for...
I have a John Deere L-130 and the electric PTO appears to be engaged even when the switch is turned off and the wiring to the PTO is disconnected. I can start the engine (with the wiring disconnected) and...
Good diagnostic work, uncleparroth! By removing power to the PTO, you've proven that the PTO clutch has stuck/frozen mechanically. If you are mechanically inclined, you can remove the PTO clutch assembly and disassemble it. You could luck out, find something as simple as a broken spring and save a lot of money. Nothing to lose but your time. On the other hand it might not be repairable and you'll have to 'spring' (sorry for the pun) for a new PTO clutch which will cost about $200. Good luck!
Aug 08, 2010 | John Deere Garden
MOWER blades WILL NOT SHUTOFF
sounds like a electro clutch engage type system
maybe your electro-clutch engage switch is faulty or a wire is connected the wrong way
was the clutch replaced recenlty and was is compatiable ?
or maybe you have a faulty clutch to test try
remove plug lead from plug
disconnect wires @pto clutch and apply 12 volt directly to clutch then remove voltage - if clutch engages then disengages the clutch is good it should click on then off if it does then its a switch fault
replace pto switch
cheers paul
hope its helps
Aug 08, 2010 | Oregon Scientific Electric PTO Clutch for...
How do i get the upper pulley above the pto clutch
I've yet to remove these in one piece...even when I smeared anti-seize all over it. You can try a 3 jaw puller, but you'll most likely end up just bending the pulley. The pulleys are about 25 dollars locally in my area. Honestly, i just air chisel them off, and buy new every time i change drive belts.
Jun 09, 2010 | Oregon Scientific Electric PTO Clutch for...
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
