I have save patterns to a flashdrive. When I plug the flashdrive in to my ellure plus, the pattern name shows on the screen but not the pattern. It tells me to pick a pattern but I don't know how.
SOURCE: Baby Lock Embroidery Sewing Machine
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
SOURCE: I am trying to use the "Place and Stitch embroidery" software
You have to have the computer program to merge patterns.
SOURCE: I have a fairly new Baby Lock Ellure Plus and when
Hi Lisa, I have the same machine. When I had that problem I was told that the design I was trying to do was to large for the machine. Basically it needs to be about a 5" x 7" design. When I put a smaller design in the machine was able to read it. Hope this helps! I'm still learning too.
SOURCE: Placing a space between words on the lcd screen.
Go to the end of the alphabet and use the underscore.
This will leave a space and not actually stitch the underscore.
Source: Linda's 15.000 Embroidery Design
