Question about Troy Bilt Tb70ss Gas Trimmer
TRIMMER RUNS UNTIL PUT UNDER LOAD, THEN JUST DIES
  • glen285 Jun 23, 2009
    This is a new trimmer, just out of the box. Fuel mix is correct. It starts on the first pull, and will rev to full throttle, but as soon as it is put under load, it dies.
  • 65 Answers
The fuel to oil ratio your using may be wrong. The usual mix to 40 parts of gas to 1 part oil. This works to be about 1 1/4 gallons of gas to 3.2 fl. oz of 2 cycle oil.
You should also clean the air filter on the trimmer.
Posted on Jun 23, 2009
  • aN_Nihilated Jun 26, 2009
    Is there a starting sequence that you follow?
    Because my trimmer won't run proper unless i follow the sequence properly step by step.
I have a Troy Bilt trimmer model TB675EC...4 cycle engine. Problem that has arisen is that it dies at high speed and under load. Starts up and runs at idle well.
Fuel starved, carb should have an idle adjustment which sounds like it is fine. Look for the second adjustment
Jul 17, 2017 | Troy Garden
Troybilt 2840 snowblower runs 5 or 10 minutes than dies
fuel tank not venting and the float levels falls to low
Nov 06, 2017 | Motorcycles
FC540v Kawasaki john Deere 265, bugs down under load,emitting black smoke & then dies. Works fine without air filter.Carb cleaned, Compression check has 80 lbs
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Thanks for your attention to this matter.
Aug 29, 2012 | Cars & Trucks
Chainsaw dies under load
how much use has it had and is the bore scored its probably worn needs new piston Rings
Jun 30, 2012 | Garden
Feather lite trimmer only runs on half throttle and idle dies on full throttle. unit is new
When I bought a new poulan gas trimmer, I had the same problem. Solution was to return it and get another one. They come with problems, even new. Just keep returning them until you get one that works correctly. Mine works great, but like I said, had to return it and get one that was right.
Jul 01, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Homelite trimmer dies every time I squeeze the handle
remove the muffler,disassemble it,you will find a spark arrester screen in it.it is either clogged up with carbon or partially clogged,clean all carbon off,reassemble and try again
May 28, 2009 | Homelite Mighty Lite Lawn Trimmer
It acts like it is flooded, starts with choke off and throttle depressed. runs until carb runs out of gas then dies
Yes, Your carburetor sounds like it needs cleaned. Or you may possibly need to purchase a carb. kit for your trimmer if the cleaning doesn't do any good. When cleaning the carb. use a Den Tek Brush, (teeth cleaning brush), to clean the small ports. Also, check the small screen in carb. Can get clogged easily.
Jim
May 28, 2009 | Garden
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Troy Bilt Tb70ss Gas Trimmer Logo
487 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
