Hi there, I have a toshiba satellite M60-BK3 Laptop. Is only four years old and from couple of days my LCD display is going on standby mode very fast. I try pressing and releasing that little switch which turn off the screen when I close the laptop, but the screen it was on for couple of minutes at the beginning, but now is off. So the computer is working but I cannot see anything on the display. Do you know the cause? Do I have to replace the LCD display or is something else. Thank you for your help.
  • neacsu Jun 23, 2009
    I did started in a safe mode but still nothing come up on the screen, I can hear windows starting but no image though, so I think is the back lite, I do not have a separate monitor so I can plug in.
    I am using a macintosh now.
    Thank you
    Thank you very much!
    Appreciated a lot!
    Sorry I cannot chat with the other guys!
    For some reason my typing did not go through.
  • 3,940 Answers
A couple things to try, 1 is boot the system in the safe mode (F8 menu at boot) and see if the LCD turns off there. You can also attach an external monitor and see if the external looses video too.
If the system looses video in the Safe mode and doesn't loose video with an external monitor, then the LCD backlight is likely failing
LCDs run about $100 to $150 on ebay
Posted on Jun 23, 2009
F buttons description
F1 - Security System
Press and hold the "Fn" key on the lower left-hand corner of your Toshiba keyboard.
Press the "F1" key to activate the security system.
Your laptop's screen will go blank so others can't see what you are working on or accessing.
Sponsored Links
Computer Repairs (Melb)
No Fix, No Fee. Same Day or Free. We Come To You - 1300 723 628
www.thepcdoctor.com.au/melbourne
Press any key or touch the touchpad to exit the security mode.
F2 - Power Save Mode
Press and hold the "Fn" key.
5
Press the "F2" key to activate the Power Save mode and make changes to how your laptop handles operating on battery or AC power.
6
Press "Fn" and the "F2" key again to exit the power save mode.
F3 - Standby Mode
7
8
Press the "F3" key to place your laptop in Standby mode.
The Standby dialog box will appear.
9
Verify you want to enter Standby mode. Press the power button on your Toshiba laptop to exit Standby mode.
F4 - Hibernation Mode
10
11
Press the "F4" key to activate the Hibernation mode and save whatever documents and files that are open to your hard drive.
12
Verify you want to enter Hibernation mode. Press the power button on your Toshiba laptop to exit Hibernation mode.
F5 - Active Display Device/F6 and F7 - Toshiba LCD Screen Brightness
13
14
Press the "F5" key to change your laptop's active display device from the laptop screen to an external monitor.
15
Click on the display configuration you want: displaying on both the laptop and external monitor; only on the laptop; only on the external monitor; or a specific screen resolution.
16
Press and hold "Fn" and "F5" to accept the new display settings. Press and hold "Fn" and "F5" again to return to your laptop's display only.
17
18
Press the "F6" key to decrease your laptop's screen brightness. Press the "F7" key to increase the brightness.
F8 - Wireless Connection/Bluetooth
19
20
Press the "F8" key to select the wireless Internet or Bluetooth connection you want to use.
21
Press and hold "Fn" and "F8" to make your selection. Release the keys to confirm your selection.
F9 - Touchpad Control
22
23
Press the "F9" key to enable your laptop's touchpad.
24
Press and hold "Fn" and "F9" again to disable the touchpad.
F10 and F11 - Numeric Keypad/F12 - Scroll Lock
25
26
Press the "F10" key to enable your Toshiba laptop's numeric keypad.
27
Press and hold "Fn" and "F11" to enable the cursor control keys on the numeric keypad.
28
Press and hold the "Fn" and "F10" or "F11" key to disable the numeric keypad or cursor control keys.
29
30
Press the "F12" key to lock your cursor on a specific line of text. Press and hold "Fn" and "F12" to turn scroll lock off.
hope this helps
Sep 25, 2012 | Toshiba Satellite A100-S8111TD Notebook
Toshiba m60-104 screen dark new screen new iverter
Have you tried an external monitor?
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the display shows on the external monitor that proves your video card is ok and your lcd screen is the issue. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If is shows on the external monitor, then you would have to question if the new screen and lcd inverter is bad. Just because they are new don't mean they work. Are you sure you purchased the lcd screen and inverter that is for your model?
May 23, 2012 | Toshiba Satellite M60 Notebook
The monitor on my Toshiba P25-S5093 does not have any display of any kind; all black. I have display using external monitor.
Does the display show anything before you enter windows? If yes, then press the key to transfer video back to your original screen once you enter windows. It should be the function key "Fn" + F5 - F8. looks for the icon which shows a monitor or says "CRT/LCD".
If it doesn't show anything before you enter windows I'm afraid your screen needs to be replaced. Good luck.
Mar 08, 2011 | Toshiba Satellite P25-S5093 Notebook
Multiple squiggly lines fill the LCD screen, after
Sounds to me like your inverter has gone bad. Typically it's situated just below your LCD. To get to it you will have to take out the screws around the LCD bezel. It's a long, skinny circuit board that the LCD plugs into. You can usually find a replacement on Ebay. Just be sure that you're ordering the correct part, otherwise it may not fit or work properly. I've also had times when the entire LCD was going bad and the display was full of squiggly lines. It's hard to say which one is the cause. I would try replacing the inverter first. That part is usually much cheaper than the LCD is.
Apr 10, 2010 | Toshiba Satellite M60 Notebook
Toshiba Satellite Laptop refuses to allow Dual Monitors
I have an A105 set up on dual screens, and it works great. As I recall, you have to do the dual screen setup in the control panel, display, settings.
Mar 17, 2009 | Toshiba Satellite A105-S4074 Notebook
Toshiba A60 startup problem
You see some problem with hardware use to be logical sometime now that some technical expact has examine it over there, i will advice you get another screen and try it with it if still not display then you get another laptop.
Nov 18, 2008 | Toshiba Satellite A60 Notebook
Toshiba Laptop Stuck in Sleep/standby Mode
maybe u got problem with the flex cable that connect the lcd to keboard/mouse
Aug 27, 2008 | Toshiba Satellite A135-S2386 Notebook
Toshiba Satellite A45 Series won't load Windows
HELLO. THE FIRST THING YOU NEED TO DO IS . TURN IT OFF. THEN START IT UP AND HOLD DOWN ON THE CTRL BUTTON AND TOGGLE BETWEEN THE (F8,F9,F10) BUTTON'S AND IT SHOULD START UP. "GOOD LUCK" LET ME KNOW IF THIS HELP'S YOU.
Jul 23, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Computers & Internet Logo
116 people viewed this question
Alun Cox
David Payne
David Payne
