Question about Samsung WF328AAW Front Load Washer
Why does samsung dv400ewhdwr/aa DRYER beep every 30 seconds?
I have misplaced my manual. I have a Samsung Moisture Sensor dryer. the power works but the it wont tumble. Model #DV400EWHDWR/AA SERIAL # Y6915AEFB00979F. PLEASE HELP.
Samsung has the manual and a trouble-shooting guide on the product support page: http://www.samsung.com/us/support/owners/product/electric-dryers-dv400ewhd . The direct link to the manual is currently http://downloadcenter.samsung.com/content/UM/201501/20150120165209818/HUDSON_DRY_DV456_DC68-03170A-09_AA.pdf .
Usually if the drum won't tumble, the problem is with the belt, the drum rollers, bearings or shaft that the connect the drum to the motor or the motor.
Can you turn the drum by hand easily? Then look closely at the belt. Replace it if it is damaged. If the drum won't turn, disconnect the belt and check if the drum turns. If it doesn't, check the drum support rollers for wear. Replace all of the support bearings at once if any are faulty. Check the support rollers and shaft at the back of the drum for damage. If you hear a lot of noise as you turn the drum, then the bearings are possibly bad. Check that the plastic slides that stabilize the front of the drum are fine.
Finally check the motor. Replace this if it is faulty. To see a parts diagram and price lists for any parts, see http://www.appliancepartspros.com/parts-for-samsung-dv400ewhdwr-aa-0001.html . Other sites also have the parts for the dryer.
I hope this helps.
Aug 12, 2017 | Samsung Dryers
Why would a Samsung gas dryer, model DV400GWHDWR-AA cutout and show a FE code after about three seconds after pressing the start button?
Samsung Dryer Error Code = FE
Error Condition = Power supply out of range (frequency)
Check and or Repair = If the dryer is getting the power it requires then replace the electronic control panel board.
Parts For Replacement = Electronic Control Board
Sep 26, 2016 | Samsung Dryers
HOW do I get rid of a code on my dryer or is it EL8,what part repairs this code.
Good Afternoon Butchie111, thank you for your post!
From the information you have provided your Frigidaire dryer is displaying an error code of "EL8" and it will run for 30 seconds then beep the code. I am showing that "EL8" is an invalid code. It could be a possible miscommunication error so I would suggest performing a reset on your dryer and you can do that by disconnecting power from your dryer for roughly ten minutes. If that does not help your issue could you please provide me with the new error code or inform me if your dryer still displays "EL8"? I look forward to your response. -Matt
Feb 22, 2015 | Frigidaire Dryers
Dv218aew Samsung dryer shuts off itselft after 30 seconds
Bad venting causing overheat? bad thermostats hi limit and cycling? thermal cutt off. bad moister sensor in the drum? giving wrong reading and cuting it off?
Sep 04, 2014 | Samsung DV218AEW Electric Dryer
Dv218aew Samsung dryer shuts itselft after 30 seconds
If it starts ok but system says somethings wrong.would guess its a sensor gone bad on you
This Samsung AA-PB9NS6B battery maked with Hi-Quality battery cells, which is guaranteed to meet OEM specifications. All Samsung AA-PB9NS6B laptop batteries on sale have passed the strict quality control...
Samsung gets their batteries from a supplier, just as newbattery gets them from their source. The OEM or original equipment manufacturer set the specifications and thus the battery was made accordingly. 30 day warranty is standard and after that, your on your own.
Mar 05, 2014 | Samsung DLP HL-P5663W 56" TV
Dryer turns off after 30 seconds and beeps six times (over and over.....)
other than a good lint cleaning by dissasemble and if not then replace the motor
Jun 23, 2008 | Frigidaire FEQ1442ES Electric Dryer
Beeping
The beeping is as a result of low power. I found several articles on-line about this, and you are not alone. The best solution I saw was to use NiMH Rechargable batteries. They say it takes the life from 30 shots, to 30 days worth of shots if you get the correct rechargable AA Batteries.
If it is not power, then I am sorry, but I am of no help.
Many people complain about the life of batteries, and this beeping though, best to try it, and see.
Apr 23, 2008 | Samsung Digimax D53 Digital Camera
Samsung WF328AAW Front Load Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
