Question about Optics
I need a repair manual for Swift 846 20X80 BWCF binocular
Need 1 rubber eye shield for swift ferret model 747
Regards, Tony
May 10, 2011 | Swift Kestrel 826 (10x50) Binocular
Can you change a 3200 swift mono head with a binocular head and where can i find one
Yes, or providing they still make it. The monoc head is just held on with a thumb screw, and you can usually buy just the binocular head itself. You will most likely have to get the part through one of Swift Optical Instruments many distributors or dealers, but if you call Swift directly they will be able to direct you in the right direction: (877) 967-9438
Jan 27, 2011 | Swift M4002D Binocular Microscope
I hace a pair of swift ultra light binoculars and have lost 2 screws in one of the eyepieces. Where can I get replacements>
i would take one out of the other side and take it to a hardware store and see if i could match it up with some thing.
Nov 03, 2009 | Swift Ultra-Lite 762 Binocular
Missing eyecup
Do you mean the Swift Audubon 8.5x44? If so, for the new model 820 contact Swift Sports Optics. If it's the older model 804 ask around in the forums such as Cloudy Nights. The new model 820 is rubber coated. The old models have a grey crinkle finish.
Jul 18, 2009 | Nikon Team Realtree Binocular
I have a Swift model 802, 7X35 binocular. The
at the bottom hindge there is a nut you can remove . then take a long thin screwdriver and take off the screw that holds the eyepiece focus shaft. turn center wheel till eyepiece xbars come off body,carefull not to touch lenses. gl larry@reichinstruments.com
Jun 23, 2009 | Swift Audubon 804ED BWCF Binocular
I would like to know how to dis-assemble an old Swift Vega Binoculars. It is a Nighthawk 7X50, model #788. The inside of the lens need to be cleaned and maybe the mirrors, but I am not sure how to take it...
the old swift nighthawk is a nice bino, has lasted all these years and is well worth repair ...the problem is if you do it yourself you will only make it worse as there will be more more dust inside than when you started unless you have an air hose to blow off optics after polishing,also once you disturb the optics you will certainly put it out of alignment. have repaired many of these thru the years, actually worked for swift in boston years ago. why mess it up ...larry 5088331232
Jun 04, 2009 | Swift Optics
Lenses not synched
tghere are usually a couple of grub screws under the rubber covering of the prism housings, these adjust the prisms to align each side of the binocular relative to each other.
Mar 30, 2009 | Swift Audubon 804ED BWCF Binocular
Eyecups are sticking on my Swift ultra light binoculars
The rubber outer ring of the eyecups can be peeled off of the metal ring underneath. This exposes the three tiny screws and their channels that allow the eyecups to move in and out. Clean any debris out of the channels, tighten or replace the screws if necessary, and fit the rubber covers back onto the rings.
May 21, 2008 | Swift Ultra Lite 929 Binocular
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
