Question about Panasonic KXDT343 Phone
How can I determine what the extension number is for my KXDT343 phone .
I want to make a change to my phone extension, but I can't determine what extension number mine is.
3 Suggested Answers
SOURCE: Changing names assigned to extension numbers
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
Posted on Mar 24, 2009
cnavarro
  • 2460 Answers
SOURCE: need to change extension numbers
Guessing you mean add or change extension numbers under the buttons, since you don't "add" or change extension numbers on the phone. From your set, press program dial 99 and the button you want to program. then , dial 1+ ext number and press STORE.
Do that for all the buttons you want to change then pick up the handset and drop it back down to exit programming.
Posted on Apr 11, 2013
Light indicating an extension is in use not lit up
The light is either not programmed, or the extension is disconnected.
In the first case, press PROG the button and dial 1 plus the extension number and ENTER. In the second case, the digital phone has to be in place and idle before the light will go out.
Apr 22, 2014 | Panasonic KXDT343 Phone
Changing the Time Displayed
Press intercom and dial 101, see which extension rings. That's 101
Mar 17, 2014 | Panasonic KXDT343 Phone
Relocate Extension to New Handset Location
Walking extension
dial*727 extn number then the pin
Feb 10, 2014 | Panasonic KXDT343 Phone
How do I page or intercom all extensions?
The code to page all extensions depend on the phone system (PBX Model ) you are using.What phone system are you using?
Feb 07, 2013 | Panasonic KXDT343 Phone
How do i change the names on the extensions on my kx-dt343 so when i hit the button to call that line it shows the right name?
From the phone connected to extension 101, press PROG and dial **1234 If the display responds Sys Prog #, then dial 004 and enter. It's the menu to assign names to extensions. You can sort of follow along and use the arrows, the keypad, and the ENTER and SAVE buttons to step through the names and change them.
Carl
Aug 25, 2011 | Panasonic KXDT343 Phone
How do I toggle between day & night mode on the KXDT343
Toggle? What happens when you dial *7800 *7801 and *7802 from extension 101?
If you're manual switching, 7800 and 01 may "sort of" do the same thing. It's designed to drop the system back into the former mode waiting for the clock. 1 should be day absolute and 2 night.
Carl
Jun 08, 2011 | Panasonic KXDT343 Phone
How do I change the time on my Panasonic KXDT343?
1. From extension 101, press the PROGRAM key.
2. Then, using the number pad, dial *#1234 (Display shows SYS-PRG #).
3. Using the number pad 000.(Display: 000 DATE / TIME)
4. Press the SP-PHONE key (Display example:'93 Jan. 1 FRI).
5. Press the SP-PHONE key again (Display example: 12:00 PM 24).
6. Enter the new hour using the number pad.
7. If you need to adjust the minutes press the FWD/DND key.
8. Enter the new minutes using the number pad.
9. If you need to adjust the AM/PM press the FWD/DND key.
10. Press the AUTO ANSWER/MUTE key to select AM or PM.
11. When finished entering the new time press the AUTO DIAL/STORE key.
12. Press the HOLD key.
13. Press the PROGRAM key to exit programming.
Jan 11, 2011 | Panasonic KXDT343 Phone
We've just had new Panasonic KXDT343 phones installed and the individual extensions do not light up when incoming calls are received. How to fix this? When on the other side of the office I have no way of...
Programming. An out of the box TDA system has only one phone programmed to ring, extension 101. The rest have to be put into ICD groups to "flash" or ring when a call comes in. That should have been done by the installer.
Carl
Nov 30, 2010 | Panasonic KXDT343 Phone
How do I turn on my message waiting light?
Why would you want to? Technically, I can turn on someone else's MW light in 2 ways, by calling them and dialing a "4", or by dialing *701 plus their extension number. That also means the equipment that's turning the MW lights on your phone has to do the same thing.
Before you ask, pressing the MESSAGE button and looking at the display where a soft key lets you CLEAR the message works, and *700 plus your extension clears ALL messages.
Carl
Oct 26, 2010 | Panasonic KXDT343 Phone
We are having difficulty when trying to intercom an extension when pushing the extension button from the receptionist desk. Please advise how we can program this button so that we do not have to dial the...
From that phone press PROGRAM and the button. What does the display say? If it doesn't say Ext XXX, then dial 1 plus the extension and STORE.
You should be able to read all the buttons and what is under them by just pressing them. Nothing changes until you press ENTER or STORE.
Carl
Sep 13, 2010 | Panasonic KXDT343 Phone
Panasonic KXDT343   Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
