User's guide ncr 5954 - Office Equipment & Supplies
How do i install 7167 printer ncr
Welcome to Fixya
Connect the ccommunication cable to your computer. Connect the cash drawer cable to the printer and cash drawer. After all cable are connected, install the drivers disk that came with it. Please click here.
Thank you for using Fixya!
Aug 09, 2011 | NCR 7167 Thermal Printer
I know there is a set of bar codes you can scan on the NCR 7875
Yes sir, I think NCR refers to them as "hex tags" but anyways one of the hex tags is labeled "Diagnostic" I think that is the one that will tell you the current settings. I found the tags on the manual for a different model (pages 282-296 on the pdf in the first link). After you get the tags printed from this link just use the manual for 7875 (second link) model to know what sequence to scan these tags good luck! http://ncrpr.ncr.com/web/rsdmkt/dealerReady/docs/User_Guides/HighPer_Scanner-User-Guide.pdf
https://docs.symbol.com/manuals/3765801a.pdf
Apr 03, 2010 | NCR 7875
How to do nPr or nCr on TI-30x Solar (scientific calc.)
If you have an older version on the TI30x Solar (not TI30Xa or newer) then you must use a different key sequence for nPr/nCr.
52 [2nd][x/y] 5 [2nd][nCr] gives 2598960 (the x/y button is above the Pi symbol on my version).
8 [2nd][x/y] 3 [2nd][nPr] gives 336
This took me forever to find out, so hopefully it will help someone!
Jan 27, 2010 | Texas Instruments TI-84 Plus Silver...
Combinations graph
you need to follow your user guide for calculaing nCr function
Nov 14, 2009 | Texas Instruments TI-84 Plus Calculator
I need to change an NCR 7875 - 2000 from lbs to kg Regards Peterm
Firstly you will need NCR Scan Tags. You can download from
You will have to print out the Scan Tags which start at page 281 and you will also need the correct weights; 0kg, 2.5kg, 5kg and 10kg.
Then follow these steps and be sure to scan tags in correct order:
1. Reset
2. Default
3. Program mode
4. Hex 3
5. Hex 0
6. Hex 1
7. Push the calibrate button under weighing tray
8. Place the correct weights in order. It will ask for the weights in order.
9. Calibration complete
Jun 05, 2009 | NCR 7875
Printer does not respond, and we restarted it and it still does the same thing
Whats the brand and make of the printer and are there any error lights being displayed ?
also try this solution it may solve your problem:
Click start > click run
in the Run window type cmd
hit enter
now a black DOS window will appear
now type
net stop spooler
wait 10 seconds
now type
net start spooler
it should look like this :
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\NCR>net spool stop
The syntax of this command is:
NET [ ACCOUNTS | COMPUTER | CONFIG | CONTINUE | FILE | GROUP | HELP |
HELPMSG | LOCALGROUP | NAME | PAUSE | PRINT | SEND | SESSION |
SHARE | START | STATISTICS | STOP | TIME | USE | USER | VIEW ]
C:\Documents and Settings\NCR>print spool stop
Can't find file spool
Can't find file stop
C:\Documents and Settings\NCR>net print spool stop
NET PRINT
\\computername\sharename
[\\computername] job# [/HOLD | /RELEASE | /DELETE]
C:\Documents and Settings\NCR>net stop spooler
The Print Spooler service was stopped successfully.
C:\Documents and Settings\NCR>net start spooler
The Print Spooler service is starting.
The Print Spooler service was started successfully.
Anymore information would be great
Thanks
Aug 18, 2008 | Office Equipment & Supplies
26 people viewed this question
jasbo
jasbo
