Question about Whirlpool Washing Machines
What size is my whirlpool washer model # gsq9611kqo
What is the size for whirlpool estate model ETW4400Q0
I can't find an ETW44ooQ0. Most Whirlpool model numbers have 3 letters, 4 numbers, 2 letters and a number. I did find a Whirlpool Estate washer, ETW4400WQ0, with a 3.2 cu. ft capacity. See the specifications here: http://www.estateappliances.com/shopping/Specs.asp?Model=ETW4400WQ&Appliance=10100&BaseModel=ETW4400WQ&SpecModelNo=ETW4400WQ .
I hope this helps. Please check your model number if this isn't the right model and add a comment correcting the model number for additional information.
Jun 25, 2017 | Whirlpool Washing Machines
What is the capacity of whirlpool model #LA5558XTW2
This is a direct drive model washer tub size is large capacity but any washer to stop from overloading is loose laid cloths 3/4 of tub any washer to work properly
Dec 19, 2016 | Whirlpool Washing Machines
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool washer model # WED9270XW1? If yes, what stacking kit do I need to use? Can I stack a new whirlpool washer model # WFW72HED
As we could see new one are not compatible with older one as size and dimension of new washer are changed but in case you could try .It is simple just try compatibility of your older washer stack kit with new one in most new model
Oct 14, 2014 | Whirlpool 8541503 Duet Stack Kit 8541503
WHAT IS THE CAPACITY SIZE OF MY WHIRLPOOL DUET WASHER MODEL NUMBER GHW9100LW2?
3.8 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 05, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Washer model # LSN1000KQ0 overfilling
did you plug the hose back into the water level switch, double check to see if it is plugged, if it is your water level switch might be defective. trouble shoot by taking the front panel off... turn on the washer by using the timer, set water level to small...on the bottom of the tub housing there should be a nipple where the clear hose connects onto.....follow the clear hose from the switch down to the bottom of the tub.........disconnect the clear hose on the bottom of the tub.....plugg the nipple with your finger.........gently blow into the hose with your mouth.......but make sure the water level in the tub is at least at half way full...and the washer is on and filling up with water ...after you blow into the hose the washer should agitate.......if it does agitate your water level switch is defective...connect hose back........get your model number and source for the switch.........
Apr 10, 2010 | Whirlpool Washing Machines
I have the kenmore 90 series top load electric washer. Model #110.92291100. I am trying to find out if it's a 3cubic or a 4cubic size. I am replacing it and I want the exact same size. It says Heavy Duty...
I couldn't find the exact size using the model number provided... i would bet that it's a 3.5 - 4 cu.ft. model... My suggestion is to get something other than a GE washing machine... Go with a Kenmore, Whirlpool or Maytag
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
What cu. ft. size is my Whirlpool top loading washer model # LSQ9549LWO?
hi there. the best way to determine this is to measure the inside length, height and width and you will get cubic feet. Just be sure to convert each measure to feet. For instance 2 feet 4 inches = 2.33 feet.
Jul 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
