Question about Measuring Tools & Sensors
How much 2 cycle oil do i add to one gallon of gas in a fl20 poulan weedeater?
  • 115 Answers
Usually it is a 40:1 ratio . the ratio should be printed on gas cap for one gallon 40:1 would be about 3 oz.
Posted on Jul 08, 2009
Need gas and oil mixture for 25 cc ut 08083 blower
Two-cycle engines use a mixture of oil and fuel to power and lubricate the engine. Homelite blower engines use a ratio of 50 parts gasoline to 1 part two-cycle engine oil. Two-cycle engine oil is commonly sold in 2.6-ounce containers; add it to 1 gallon of gas to achieve the 50:1 ratio. Two-cycle engine oil for outboard motors is not compatible with Homelite blowers.Use premium fuel,the blower,weedeater,etc. will last much longer!
Oct 31, 2015 | Garden
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
What is gas to oil mix ratio on weedeater string trimmer
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Fl20cc poulan weed eater how much 2 cycle oil to a liter
Poulans are 40:1 Therefore you should add (3 oz.) of 2 cycle oil to one (1 U.S. Gallon) of gas.
Jim
Jul 31, 2011 | Garden
Did not get an owners manual with my 33cc gastrimmer need to know the gas oil mixture .
40:1 = 3.2 oz of 2 stroke oil for every gallon of gas
Link to manual is below http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
May 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the fuel to oil mixture ratio for my gas featherlight weedeater?
That oil/fuel mixture would be 50-1 or 2.8 ounces per gallon...
heatman101
Sep 08, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
What ratio gas to oil do I mix?
Use 3.2 oz of 2-cycle oil to one gallon of gasoline. If you use 3.3 up to 4 oz you would be okay nut it may smoke a little. Sorry to hear about your husband. Good luck...Lee
Jul 29, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
Jun 12, 2010 | Poulan Pro Chain Saw 46cc 20"
How much oil do I mix with gas for my poulan SV22 weedeater
2001 and up the manual says 40:1 (I gallon premium fuel to 3.2 ounces of quality 2-cycle oil).
Lou
Jan 16, 2010 | Garden
Measuring Tools & Sensors Logo
530 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
