Question about Frigidaire Washing Machines
My frigidaire washer stops mid cycle when washing heavy things. Also smells like something is burning.
Model atfb6000es0 stops working mid cycle when washing heavy items. What parts do I need?
  • Frigidaire Master
  • 5,323 Answers
NOT SURE BUT SEEMS LIKE MAYBE UR MOTOR COUPLER MAY BE GOING OUT
Posted on Mar 31, 2015
SOURCE: Frigidaire Washer Model FWT647GHSO
I had the same problem with my FWT647GHSO front loader shaking, the bearings in the outer rear drum were gone, I repair machinery for a living not appliances ( except my own ) and the job took me close to 4 hours to complete, it is working well now but I did notice some hairline cracking on the yoke that holds the inner basket so I guess it's time to start saving my pennies for a new one :( too bad the inner drum is ~$200.00 or I would endure the 4 hours labor again to replace that as well. Best of luck
Posted on Mar 24, 2009
SOURCE: washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Posted on Apr 21, 2009
Jimster
  • 240 Answers
SOURCE: Mid-cycle my washing machine stopped working.
Could be one of three issues, timer, capacitor, or the most like canidate the motor assm. Usually 90% of the time, its that motor. Those motors are pretty expensive (part number 389248) and you need to replace motor coupler (part number 285753A) when you change it.
Posted on Apr 26, 2009
  • 72 Answers
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Posted on Jun 19, 2009
  • 38 Answers
SOURCE: burning smell during spin cycle on frigidaire washing machine
Open lid as you would load clothes and hold the inner drum with all the holes in it. Give it a manual turn left, then right. If it spins in both ways the main bearing is gone. This is not a DIY because the new bearing has to be pressed on at a machine shop, or an appliance repair shop.
Posted on Dec 29, 2009
My whirlpool ultimate careII quiet wash washer stopped working in mid cycle. It won't agitate, drain, spin, fill with water, nothing. The washer makes a humming sound and an electrical burning smell.
If your smelling electrical burn.. It's most likely to be the motor is bad.. Or just stuck, new washers made today are DC motors and contain a circuit board in the motor.. And are not serviceable.. Just replace them..
Dec 02, 2016 | Whirlpool Washing Machines
Affinity stops in the middle of a cycle a just shuts off no signal or anything?
use the following steps. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
May 23, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer heavy duty cycle issue
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
God bless youcb4af627-0171-42f5-ad0a-5f8e85e72ae0.gif6634bf88-8eca-4d0f-b59c-0e8829e5d59d.gif419f93c3-fea0-4d93-af85-2e59d98d88e0.gif
May 23, 2013 | Whirlpool AWG320 Front Load Washer / Dryer
Frigidaire gallery stackable heavy duty washer stopped spinning and there was a electrical burning smell. what is this?
the problem will be in the motor. most of the time if burning smell comes due to coil burn only please change the motor
Dec 23, 2009 | Washing Machines
Maytag washer sounds like a jackhammer when rinsing - this is a new thing with all loads. Yesterday it shut down mid cycle while still full of water and we smelled a burning rubber smell. Any ideas?
There is only one belt on the machine (the burning rubber smell, probably). Sounds like something is wrong with the clutch /drive mechanism. Unless your an accomplished DIY'er, it sounds like a job for the Maytag Man.
Sorry.........................
Sep 15, 2009 | Maytag PAV2300 Top Load Washer
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
Apr 20, 2009 | Kenmore 22942 Top Load Washer
Stops washing mid way of cycle
Remove the two screws at the bottom corners. Lift the bottom front out and down to release the top clips. Inspect the belt for wear.
If you need further assistance, let me know
Regards,
reg501
Jul 04, 2008 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
