Question about Gateway MS2285 15.6in Laptop X2 2GHz 4GB 500GB DVDRW
Remove password bios gateway ms 2285
I can't go to the bios
Geekman
  • 32281 Answers
SOURCE: Gateway MX6030 bios/boot password reset
How long did you leave the battery out?
To discharge the BIOS you need to short out the battery contacts, or disconnect the battery for 1/2+ hours.
If this does not work the it is near impossible to remove because the password would be stored on an EEPROM chip.
Check with Gateway, they might suggest a motherboard replacement just like IBM.
Posted on Jan 19, 2009
Digglesby
  • 71 Answers
SOURCE: don't remember password on bios of a gateway solo
Simplest is to remove the battery for a while so the password is lost.
See the TechRepublic article at
http://articles.techrepublic.com.com/5100-10878_11-1032878.html
Posted on Nov 19, 2009
prasant1990
  • 59 Answers
SOURCE: Reset Bios Password
At command prompt type debug
you will get a - prompt where you can type the fallowing (<enter> means hit enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password crack - works 9.9 times out of ten
This is a password hack but it clears the BIOS such that the next time you start the PC, the CMOS does not ask for any password. Now if you are able to bring the DOS prompt up, then you will be able to change the BIOS setting to the default. To clear the CMOS do the following:
Get DOS prompt and type:
DEBUG hit enter
-o 70 2e hit enter
-o 71 ff hit enter
-q hit enter
exit hit enter
Restart the computer. It works on most versions of the AWARD BIOS.
Flashing BIOS via software
If you have access to the computer when it's turned on, you could try one of those programs that remove the password from the BIOS, by invalidating its memory.
However, it might happen you don't have one of those programs when you have access to the computer, so you'd better learn how to do manually what they do. You can reset the BIOS to its default values using the MS-DOS tool DEBUG (type DEBUG at the command prompt. You'd better do it in pure MS-DOS mode, not from a MS-DOS shell window in Windows). Once you are in the debug environment enter the following commands:
AMI/AWARD BIOS
O 70 17
O 71 17
Q
PHOENIX BIOS
O 70 FF
O 71 17
Q
GENERIC
Invalidates CMOS RAM.
Should work on all AT motherboards
(XT motherboards don't have CMOS)
O 70 2E
O 71 FF
Q
Note that the first letter is a "O" not the number "0". The numbers which follow are two bytes in hex format.
Using the jumpers
The canonical way to flash the BIOS via hardware is to plug, unplug, or switch a jumper on the motherboard (for "switching a jumper" I mean that you find a jumper that joins the central pin and a side pin of a group of three pins, you should then unplug the jumper and then plug it to the central pin and to the pin on the opposite side, so if the jumper is normally on position 1-2, you have to put it on position 2-3, or vice versa). This jumper is not always located near to the BIOS, but could be anywhere on the motherboard.
To find the correct jumper you should read the motherboard's manual.
Once you've located the correct jumper, switch it (or plug or unplug it, depending from what the manual says) while the computer is turned OFF. Wait a couple of seconds then put the jumper back to its original position. In some motherboards it may happen that the computer will automatically turn itself on, after flashing the BIOS. In this case, turn it off, and put the jumper back to its original position, then turn it on again. Other motherboards require you turn the computer on for a few seconds to flash the BIOS.
If you don't have the motherboard's manual, you'll have to "brute force" it... trying out all the jumpers. In this case, try first the isolated ones (not in a group), the ones near to the BIOS, and the ones you can switch (as I explained before). If all them fail, try all the others. However, you must modify the status of only one jumper per attempt, otherwise you could damage the motherboard (since you don't know what the jumper you modified is actually meant for). If the password request screen still appear, try another one.
If after flashing the BIOS, the computer won't boot when you turn it on, turn it off, and wait some seconds before to retry.
Posted on Jul 07, 2010
SOURCE: gateway solo pro 9300 bios password is not remove
can this laptop (gateway solo 9300) connect to internet with comcast DSL somehow?
Posted on Sep 07, 2010
maxcarson
  • 7627 Answers
SOURCE: default password for gateway NT6452 bios
Only you have the password. You could do a system recovery.
Posted on Dec 13, 2012
Bio master password gateway 56NR I don't,I can't have access to the bio,please help!
You may be able to reset it by removing and shorting the contacts in the CMOS battery or installing a jumper on the reset pins. How to Remove BIOS Password Using The Jumper Settings Password Recovery
Oct 22, 2017 | Gateway Computers & Internet
Erazing bios password for ms-10041
Hello try to remove the cmos battery, for 30 minutes:
This will clear the bios password.
Good luck
Mar 02, 2013 | Averatec MS-10041 OEM 6200 Motherboard Mfr...
How do i reset bios password on gateway zx 4970g
REMOVE BIOS PASSWORD
PC BIOS toolkit is a password removal/decrypt and BIOS settings modification/backup/restore.
http://www.syschat.com/download120.html&act=down
CMOSPwd - CMOS password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
Using a computer with Internet access, download the files from these WEB sites and create a bootable CD disc to run them.
Feb 27, 2013 | Gateway One ZX4970G-UW308 All-In-One...
Bio's Password reset for gateway 98 desktop
BIOS passwords can be reset or removed in two ways:
1. using software 2. using hardware.
1. Software removal method - Here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
CmosPwd - Cmos password recovery tools
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
2. Hardware Removal method :
- First you need to open the case.
- Then find the cmos battery (It will look like a nickel sized silver disk located on the motherboard).
- Remove the cmos battery for 30 seconds and then put it back in. You may have to tweak the bios settings afterward, but the password will be gone.
Good Luck!
Aug 14, 2012 | Gateway Computers & Internet
I forgot my gateway model ML6230 bios password, i need a new password for it (reset the password).
A method you can try if you don't have a password reset software is by removing the CMOS battery. Remove the CMOS battery then turn the computer on. The system BIOS will be reset and password will be removed. Then you can put the battery back in. Click on this link for the Gateway ML6230 Notebook PC Manual. Check page 36 for CMOS battery removal instructions.
http://support.gateway.com/s/Mobile/Q106/Oasis/8511725_Service.pdf
Mar 21, 2011 | Gateway ML6230 Notebook
Need password
you can remove that BIOS battery and you must to insert new one of battery BIOS. Usually you can use CR2032 battery. You can buy in eletronic shop. And now, you can enter your BIOS and set them all.
Oh yeah, definitely there is three password in computer from BIOS.
One, come from BIOS password, if you want to enter and make a setting for BIOS;
Two, come from Harddisc password, if you give a password to your HDD;
Three, come from operating system, like a Windows, Linux, ...etc.
Where is password for your question?
Sep 06, 2009 | Gateway GT5220 PC Desktop
How can i redeem my gateway laptop password without the floppy disk
Hi!! Usually GATEWAY passwords are storedin eeprom memories that has to be read or writen to remove / bypass the BIOS password!!! Password generate a hash code that will appear after 3 wrong password attempts and it has a 5 digit decimal format "xxxxx" You can get the hash code by pressing F2 or F10 when you turn on the laptop to enter Bios and then when password prompt appears hit F12 to get the hash code. I got My Gateway Bios password Unlocked at http://www.laptoprebirth.com They can calculate a master password with the hash code. Hope it helps
Jun 19, 2009 | Gateway M280E
I lost my BIOS password
You will have to contact Gateway (or the manufacturer of the laptop) and ask them what you need to do to remove the bios password. Without an exact model number no one here can provide you with a 3rd party solution.
Most laptops made in the last few years require you to send the laptop back to the manufacturer and provide proof you are the origional owner of the laptop to remove a BIOS password as many BIOS passwords set up to prevent data theft.
Jan 19, 2009 | Gateway Computers & Internet
Jan 19, 2009 | Gateway MX6030 Notebook
Gateway solo pro 9300 bios password is not remove
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.This is a better way
Dec 15, 2008 | Gateway Solo 9300 Notebook
Gateway MS2285 15.6in Laptop X2 2GHz 4GB 500GB DVDRW Logo
60 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
