Question about Harman Kardon AVR 525 Receiver
How do I fix the sound is coming from comast cable box with harmon kardon 525
Drummernick
  • 440 Answers
SOURCE: hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Posted on Feb 11, 2008
renx
  • 71 Answers
SOURCE: No audio from TV on Harmon Kardon AVR35 Receiver
I am attaching some pictures that will show a couple of wiring schemes based on the type of home theater you have. If you have questions with the set up of your HK receiver, please reply with those questions prior to rating your help.
Posted on May 05, 2009
SOURCE: Harmon Kardon Receiver BUZZ
My receiver started having same problem after about 2 years from install. Any ideas?
Posted on Dec 26, 2009
mlapres
  • 757 Answers
SOURCE: Harmon Kardon AVR 235 no sound
Ensure that your speakers are connected to the terminals that you have your speaker selector switch turned to.
Then check that you have your device, whether it be a CD or DVD player, or turntable, plugged into the correct input and that you also have the correct input selected on the receiver.
Posted on Dec 30, 2009
  • 9 Answers
SOURCE: Just bought a Sharp LED TV and there is a slight
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Posted on Jan 31, 2011
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
I have a harmon kardon and I cant hook up sound to my tv
you can alternatively hook RCA cables to the cable box/satellite receiver or to the dvd/Blueray player
Oct 15, 2013 | Harman Kardon AVR 330
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
Do you know if the harman/kardon avr125 reciever is 3d capable?thanks ..mrmitchfinance@yahoo.com
Actually Home theater sound, is 3D. (Three Dimentional) Your receiver, using surround speakers reproduces 3D sound.
i.e. It is Left to Right, and Front to Rear. Thus it's 3D. If your get a 3D TV, your sound will be just fine because it doesn't come from the set. The sound SOURCE is the DVD player, CD player or Cable Box. If you use digital audio outputs (optical cable or orange colored RCA cables) from these items connected into the Harmon-Kardon, your will get the full Home Theater sound. The Harmon Kardon does not have HDMI inputs however it will not need them for the purposes of sound. Your Receiver is a high quality unit. If you want the thrill of 3D TV, go ahead and get one. After you have set it up, if you then decide you want to go to 7.1 or some other SOUND upgrade, go ahead. One thing you should know, is that there is not a whole lot of audio quality improvement available after 5.1. Unless you have a very large living room. The real quality counts when choosing the speakers and sub woofer that go into the system, not the amount of speakers you have.
I have done a number of high end home theater installations and the experience of hearing the systems (mostly 5.1) has been a thrill for the owner.
I hope this helps you,
Best Regards,
Mark
Jan 20, 2011 | Harman Kardon AVR 125 Receiver
Problems with setting up Harmon Kardon AVR 146????
in what display i need to put reciver when i use the optical digetal
Oct 19, 2009 | Audio Players & Recorders
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
Best picture and sound
connect coaxial cable connector from your cable service company to cable box-----in jack.
2-using coaxial cable connect cable box out to tv-vhf/uhf jack.
connect projection tv audio out (var-fix)jacks to avr 230 line in.
Aug 22, 2008 | Audio Players & Recorders
Harmon Kardon Sound Sticks
Hello there
First things First:
1) check cables, and the input cable to your PC.
2) Check for right voltage, may be somethings is chargind a lot**
3) Power regulator on the Speakers is damage.
4) RMS your Spks, for replace. or warranty.
5) try in another computer. ( if apply)
Jan 23, 2008 | Harman Kardon SoundSticks II Computer...
Harman Kardon AVR 525 Receiver Logo
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
