Question about Rheem GN65-360: 65-GALLON, 360,000 BTU, NATURAL GAS, LO NOX WATER HEATER, 8" VENT
Heigth? height & width ?
IF LENGTH and WIDTH are given How to find Hight
Never. Even if it a regular shape.
Oct 18, 2016 | Miscellaneous
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
What is the weight? Could it be lifted into a car?
Just Google the model and you will see specs like this. This one would be a two man job to lift!
Product details have been supplied by the Manufacturer, and are hosted by a third party. Overview
  • .w480.jpg"> The Ezee Life EZee Rovers electric mobility scooters are the only mid-size folding scooter on the market, providing a sporty yet strong design which makes it ideal for indoor or outdoor use. The 15.5 miles cruising range means it can keep up with you all day long! This sleek electric 4 wheel scooter is one of the safest rides on the market and includes tail lights, turn signals, headlights, and running lights to make sure you stay accident free. The amazing four point seat structure means 45% more stability on inclines. All of these safety features and a luxurious Memory Foam seat too? You can trust Factory direct, your Toronto source for Medical supplies for the home, for value and friendly service.
Scooter Features {"tourViews":[{"viewImage":{"runtimeSrc":{"height":566,"width":673,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ae68ba00-d064-4981-9b9d-06def45f5de8.jpg.web.v1.jpg"},"src":{"height":566,"width":673,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ae68ba00-d064-4981-9b9d-06def45f5de8.jpg"},"sources":[{"height":566,"width":673,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ae68ba00-d064-4981-9b9d-06def45f5de8.jpg.w960.jpg","profile":"W960"},{"height":403,"width":480,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ae68ba00-d064-4981-9b9d-06def45f5de8.jpg.w480.jpg","profile":"W480"},{"height":201,"width":240,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ae68ba00-d064-4981-9b9d-06def45f5de8.jpg.w240.jpg","profile":"W240"}]},"hotspots":[{"hotspotX":0.30357142857142855,"captionFromAttr":"Control Panel","direction":"left","description":"Functionality Description<br/>1. Operating Key Main On/Off switch (power source) for the Rover. (Remove the key when the scooter is not in use)<br/>2. Operating Lever (Left/Right) Moving the lever controls the speed. To drive forward, pull the right lever toward you and push the left lever away from you. Releasing the lever will bring the scooter to a gradually stop. To drive backward, pull the left lever towards you.<br/>3. Horn Pressing the button sounds the horn.<br/>4. Manual Speed Adjuster. The maximum speed is 11 km/h. Rotating the button to the lower speed (turtle icon) will reduce the speed, for slower, gentle operation.<br/>5. Turn Signal Operates the turning signal lamps<br/>6. Hazard Lights Signal Operates the emergency warning lights.<br/>7. Speed Selector Switch Set the switch to the lower speed (turtle icon) position for slower operation.<br/>8. Battery Charge Indicator Shows the state of the battery whenever the scooter is operation.<br/>9. Operation Indicator Shows operational faults<br/>10. Lights Switch Turns the front and rear headlights on and off.<br/>11. Hand Grips Flexible hand grips for comfortable hand support.<br/>12. Tiller Handle Adjusts the tiller to your preferred position.","hotspotY":0.11063829787234042,"media":{"runtimeSrc":{"height":275,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ac075d88-39d2-4863-b141-d04b43047afc.png.web.v1.400.jpg"},"src":{"height":275,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ac075d88-39d2-4863-b141-d04b43047afc.png"},"type":"IMAGE","sources":[{"height":662,"width":960,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ac075d88-39d2-4863-b141-d04b43047afc.png.w960.jpg","profile":"W960"},{"height":331,"width":480,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ac075d88-39d2-4863-b141-d04b43047afc.png.w480.jpg","profile":"W480"},{"height":165,"width":240,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/ac075d88-39d2-4863-b141-d04b43047afc.png.w240.jpg","profile":"W240"}]}},{"hotspotX":0.425,"captionFromAttr":"Tiller","direction":"right","description":"Tiller for folding control panel for easy storage/transportation","hotspotY":0.11914893617021277},{"hotspotX":0.6035714285714285,"captionFromAttr":"Locking Handle","direction":"left","description":"Locks front and rear compartments (located under seat)","hotspotY":0.4595744680851064,"media":{"runtimeSrc":{"height":206,"width":375,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/a32d15d8-19b4-4dd7-b627-12becbeee426.jpg.web.v1.jpg"},"src":{"height":206,"width":375,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/a32d15d8-19b4-4dd7-b627-12becbeee426.jpg"},"type":"IMAGE","sources":[{"height":206,"width":375,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/a32d15d8-19b4-4dd7-b627-12becbeee426.jpg.w960.jpg","profile":"W960"},{"height":206,"width":375,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/a32d15d8-19b4-4dd7-b627-12becbeee426.jpg.w480.jpg","profile":"W480"},{"height":131,"width":240,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/a32d15d8-19b4-4dd7-b627-12becbeee426.jpg.w240.jpg","profile":"W240"}]}},{"hotspotX":0.3107142857142857,"captionFromAttr":"Headlight","direction":"left","hotspotY":0.37872340425531914},{"hotspotX":0.7428571428571429,"captionFromAttr":"Folding Seat","direction":"right","hotspotY":0.14468085106382977,"media":{"runtimeSrc":{"height":275,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/3e2b704b-e52d-4363-8c67-1c5c29195a08.jpg.web.v1.400.jpg"},"src":{"height":275,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/3e2b704b-e52d-4363-8c67-1c5c29195a08.jpg"},"type":"IMAGE","sources":[{"height":662,"width":960,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/3e2b704b-e52d-4363-8c67-1c5c29195a08.jpg.w960.jpg","profile":"W960"},{"height":331,"width":480,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/3e2b704b-e52d-4363-8c67-1c5c29195a08.jpg.w480.jpg","profile":"W480"},{"height":165,"width":240,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/3e2b704b-e52d-4363-8c67-1c5c29195a08.jpg.w240.jpg","profile":"W240"}]}},{"hotspotX":0.6678571428571428,"captionFromAttr":"2 x Battery Packs","direction":"right","hotspotY":0.3148936170212766,"media":{"runtimeSrc":{"height":352,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2fe77d5a-30d0-485e-8060-96533c35f6be.jpg.web.v1.400.jpg"},"src":{"height":352,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2fe77d5a-30d0-485e-8060-96533c35f6be.jpg"},"type":"IMAGE","sources":[{"height":845,"width":960,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2fe77d5a-30d0-485e-8060-96533c35f6be.jpg.w960.jpg","profile":"W960"},{"height":422,"width":480,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2fe77d5a-30d0-485e-8060-96533c35f6be.jpg.w480.jpg","profile":"W480"},{"height":211,"width":240,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2fe77d5a-30d0-485e-8060-96533c35f6be.jpg.w240.jpg","profile":"W240"}]}},{"hotspotX":0.8142857142857143,"captionFromAttr":"Rear Signal Lights","direction":"right","hotspotY":0.502127659574468,"media":{"runtimeSrc":{"height":352,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2b6bcc6f-1794-4469-95ac-a0ec9819e7c0.jpg.web.v1.400.jpg"},"src":{"height":352,"width":400,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2b6bcc6f-1794-4469-95ac-a0ec9819e7c0.jpg"},"type":"IMAGE","sources":[{"height":845,"width":960,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2b6bcc6f-1794-4469-95ac-a0ec9819e7c0.jpg.w960.jpg","profile":"W960"},{"height":422,"width":480,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2b6bcc6f-1794-4469-95ac-a0ec9819e7c0.jpg.w480.jpg","profile":"W480"},{"height":211,"width":240,"src":"/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/2b6bcc6f-1794-4469-95ac-a0ec9819e7c0.jpg.w240.jpg","profile":"W240"}]}},{"hotspotX":0.30714285714285716,"captionFromAttr":"2 Front Wheels","direction":"left","hotspotY":0.7617021276595745}]}],"ipiCompatible":false} ?environment-id=live&enable-reporting=true&suppress-site-prefs=true&showtabs=false&wc-target=mobile&show-tabs=false&from-pp=true" data-wc-rel-click-name="eliminate-zoom-report" wcobj="http://media.webcollage.net/rwvfp/wc/cp/17997184/module/factorydirectmedical/_cp/products/1393268580619/tab-c8335942-6d2b-4e43-9380-42f8f1405660/tour" wcobj-height="450" wcobj-id="wct-6283c5c4" wcobj-type="video/x-tour" wcobj-width="800"> .w480.jpg" alt="Product Tour"> > Click to Start Features
  • Battery Light Indicator
  • Keyed Ignition
  • Delta Tiller
  • Full Light Package
  • Deluxe Memory Foam Seat
  • 12 inch Pneumatic Easy Ride Tires
  • Adjustable Tiller
  • (Virtual Adjustment)
  • Folding Tiller
  • Folding Frame
  • Light Weight Alloy
  • Speed Control
  • Reverse
  • Ultra Lightweight
  • Easily Folds
  • Fits In The Trunk Most Any Car
  • Rear Wheel Drive
  • Car Charger
  • Electronic Automatic Brakes
  • 375 lbs weight capacity
Sep 21, 2015 | Health & Beauty
How to enlarge a picture that is scanned or copied? When i scan or copy a picture it is too small and I want to enlarge it in order to view it better.
hi
Open an image. Go to the Image Menu and select Image Size. This is where you can change an image’s resolution and print size (width and height). The following Image Size dialog box will appear:
Notethat the width and the height of the image as you view it on yourmonitor is not necessarily representative of the image’s actual widthand height—i.e., the size it would print out at (print size).Average monitor resolution is 72 dpi. If you view a 72 dpi image at100% in Photoshop, chances are that it will appear on your screen inits actual print size. However, this is not true when viewing a 300 dpiimage. A 300 dpi image viewed on-screen at 100% will be enormous. Don’tget tricked into believing that what you see on your monitor is whatyou’ll get when you print or place the image into another application.The best way to determine what your image’s actual print size will beis through the Image Size dialog box.
When the Resample Imagebox is checked, any changes you make to an image’s width or height willnot change the image’s resolution, and as such, any changes you make toan image’s resolution will not affect the image’s width and height.Keep in mind, however, when you increase width and height, orresolution, with the Resample Image box checked, you are adding pixelsto your image. These pixels don’t actually exist so Photoshop mustcreate them. As such, you will succeed only in degrading the quality ofyour image.
If you want to increase an image’swidth and height, or resolution, then uncheck the Resample Image box.Now any changes you make to the image’s width and height will changethe image’s resolution, and vice versa:
  • If you decrease resolution, the width and height will increase.
  • If you increase resolution, the width and height will decrease.
  • If you increase the width or height, the resolution will decrease.
  • If you decrease the width or height, the resolution will increase.
Thebest way to increase the width and height of a scanned image is to scanthe image in at a high resolution (about twice what your finalresolution should be), and with the Resample Image box unchecked, decrease the resolution. Once the image width and height is where you want it, you can then check the Resample Imagebox and type in the resolution you want if the resolution is too high.At this point, as long as you don’t increase resolution, or width andheight, your image quality will not suffer.
Aug 07, 2010 | HP Officejet 5610 All-In-One InkJet...
Starrett heigth gage instructions
Here is a link to starrett's how to read a vernier height gauge article
http://www.starrett.com/download/251_p122_125.pdf
Give them a call the parts department is very helpful and reasonably priced.
978-249-3551
Dec 27, 2009 | Starrett Measuring Tools & Sensors
======== Exception Information
install Microsoft Runtime SDK 6.0 or up version first then run and install again your program.
Aug 10, 2009 | Systran Business Translator 6.0 Euro Full...
Toshiba TZ50V51 50 in. Rear... Problem:
I would need to know just the width and heigth of the viewable screen area in order to help you out.
Aug 17, 2008 | Toshiba TZ50V51 50" Rear Projection...
Size
Are you asking for Dimensions of the unit Quasar HQ2081QH 8000BTU Width 18.5 in. Depth 20.69 in. Height 13.88 in. Quasar HQ2101SH 10000btu Width 22.06 in. Depth 23.84 in. Height 14.78 in. Quasar HQ2121 12000BTU Width 22.06 in. Depth 23.84 in. Height 14.78 in. and the 5200BTU Quasar HQ2052UH Width 18.56 in. Depth 14.5 in. Height 12.28 in.
Aug 23, 2007 | Quasar HQ2052UH Air Conditioner
Rheem GN65-360: 65-GALLON, 360,000 BTU, NATURAL GAS, LO NOX WATER HEATER, 8" VENT Logo
27 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Gene Haynes
Tom Chichester
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
