Question about Olevia 742I 42 in. LCD TV
Diagram of 42 in Olevia flat screen tv power board
SOURCE: OLEVIA 540-B11 42" LCD-Inverter supposedly shot craps
Hi , I had the same problem but a got the power inverter from somebody, here in denver for $260 brand new , if somebody needs this part, contact me and I will send the information , also please write the part number
Sergio
Posted on May 29, 2008
SOURCE: olevia 26" flat screen
screen suddenly shut off. blue light in the right hand corner stays on but there is no picture
Posted on Jan 20, 2009
SOURCE: Olevia 42"
Olevia LCD 542I - Had the same issue for a week until the tv would not turn on anymore, after several attempts it came back on. A few days later the tv turned off then only the standby light was on, then lost the standby light as well. After researching the problem it could be in two areas, either the power supply or main board. Removed the back and found the power supply had several capacitors that were bulging on the top and appeared the fluid was leaking, all signs of a failed part, removed the PS and replaced four capacitorst that had shown some issues. If you can removed the PS and check for a number on the board, mine was FSP271-4F02, and find someone who has some electronic circuit capablilty, the issue may be resolved at a fraction on the cost of a new power supply.
Posted on Apr 23, 2009
  • 45 Answers
SOURCE: 42" TV has sound but no pictures
yea it sounds like a main-board or inverter board.. sounds like the panel of the television is loosing power and you are still getting sound..
Olevia did go out of buss.. but i know this 3rd party repair center called Amergence technology is offering to repair Olevia's. But the thing is that the whole television will have to get service they don't sell parts so you might want to give them a call and get an idea on the repair quote.. 866-965-3842
Posted on Jul 29, 2009
  • 16 Answers
SOURCE: Tv wont turn on
Replaced two N-Channel Mosfet transistors(FQPF13N50CF-ND) and some faulty electrolytic caps in the power supply. I found the Mosfets online at Digi-Key. Mosfets are difficult to read. Only one read bad but I replaced both because they are in the same circuit. Set works great now.
Posted on Mar 30, 2010
How to remove the wiring harnesses from their connectors on the 42" Olevia TV
Exactly what harness are you trying to remove?...are you referring to the flat ones that go from the TCON to the panel? or the ones that connect the power supply to mother board
Aug 02, 2017 | Olevia Televison & Video
How do I fix my OLEVIA 42" flat screen??? Power light comes on the fades
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 28, 2014 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
My olevia 242-s11 want turn on changed power supply and main board whats next
Two things, assuming you installed a working power supply and main board, check to make sure the kill switch is in the "On" position. If my memory serves me correctly, this set does have one. Are you sure you have a working outlet? power cord? When you say the set won't turn on , are you referring to the entire set or just the screen?
Jan 03, 2013 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Hi, My Olevia 42 inch, model342-B11, has a problem with its picture. At first I had vertical lines running down the screen, then it turned into small squares. What do you think is wrong with it?
Parts are hard or impossible to find for this brand but it sounds like the "main" board which processes all signal in and out of the display.
Apr 30, 2012 | Olevia 742I 42 in. LCD TV
Olevia tv has no power
Check ur power source?Yes,tries tv unplug,replug back like an hour later,by letting tv resetting itself back to factory setting,see if u get power back?Same problems,than ur tv power supply board is the cause and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power suuply board for the replacement.
Feb 12, 2011 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
My 42 inch olevia 242fhd-t11 tv just shut off and will not come back on.. The blue led light will not come on either... Also was having intermittent sound issues for the last couple of days prior to it not...
I just repaired this identical problem on the same model TV. You have a bad power supply (also known as an SMPS). The board is model FSP271-4F02, and is about $75. Unlike the main board for this TV, you can find the power board relatively easily. Try shopjimmy, for example. Replacing the board isn't too difficult if you have a reasonable mechanical ability, have some tools, and are careful.
Jun 12, 2010 | Olevia LT42HVi 42 in. LCD Television
Tv will not turn on have power going to the unit
The power LED indicator light on the front of screen panel flashes?Mean the power supply board is dead,that the board where the power a/c cord go into it.Replaced the power supply board will solved this problems.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 02, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Flat screen tv, power works but it shows a continuous blue screen
Yes,Ur Main Tuner signal board is dead.Replaced this Tuner signal board will solved this problems.Tries these websites Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner Siginal board for the replacement.
Mar 17, 2010 | Olevia LT42HVi 42 in. LCD Television
Olevia 42'' flat screen TV
I'm looking for a logic board for a olevia 540i 42 inch
Nov 13, 2008 | Olevia MN-20LCDTV-SN 20 in. EDTV-Ready...
Sergio
Dec 22, 2007 | Olevia LT42HVi 42 in. LCD Television
Olevia 742I 42 in. LCD TV Logo
82 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
