Question about my3gb.com
What to insert in the field extra domain? - my3gb.com
Create mailboxes In yahoo mail
Enter the email address you'd like to create in the "Email Address" field. You may also enter a display name in the "Name" field. Then click the Next button.
If you will use only POP (Post Office Protocol) to access this new email, you can select the second option; you won't need a Yahoo ID to activate the address.
On the invitation page, enter the email address to send the invitation to.
Be sure to assign mailboxes at your domain only to people you trust. Yahoo maintains a strict policy against spam and abuse and will suspend domain names that are associated with these types of behavior.
You are responsible for actions taken by anyone using an email address associated with your domain. If anyone using your domain is found to have violated the Yahoo Terms of Service in conjunction with a Business Mail plan, Yahoo reserves the right to suspend the domain and deactivate any mailboxes associated with it.
Feb 26, 2015 | Apple iPad Tablets & eReaders
Tip
Editing DNS Records with GoDaddy For Your Kajabi Account
Note: GoDaddy is used as an example how to edit DNS Records because their user interface is easy to work with. As each provider has a different way of doing this, you may need to contact their support center specially if you are not comfortable editing DNS Records. Just show this article to them and they should be able to figure it out.<br /><br />Before anything else...<br /> <ul> <li>A Host Record is used to map the domain name to the IP address of the host that serves your website.</li> <li>CNAME Record is an alias of another address (www.example.com is an alias of example.kajabi.com).</li></ul>Let us continue...<br />For using a Custom Domain name with your Kajabi account, only two steps are needed for this to work.<br /> <ul> <li>Step 1: On your end (this is done at your domain provider/registrar). (3) A Host Records that points to our IP addresses (75.101.145.87, 75.101.163.44 and 174.129.212.2) and (1) CNAME Record for 'www' that points to your Kajabi site (example.kajabi.com) must be created. Details found here.</li> <li>Step 2: On our end configuration is automatic after adding your domain (www.example.com) in the Custom Domain field under the Project Settings tab.</li></ul><br /><utube src="oIUZY67iv-Q"><br /><br />Wait! I already have an existing site.<br /><br />The following guide below is provided for those who ONLY want to add their Kajabi site as a Sub-Domain to an existing site.<br /><br /> <ul> <li>Step 1: On your end (this is done at your domain provider/registrar). Create a CNAME Record (ex: 'members', 'portal', etc.) and point it to your Kajabi site (example.kajabi.com). Details found here.</li> <li>Step 2: On our end configuration is automatic after adding your domain (members.example.com) in the Custom Domain field under the Project Settings tab.</li></ul><br /><utube src="0V7G4UBq0yA">
on Mar 22, 2011 | Computers & Internet
Tip
How to Add a Computer Domain
A computer's domain is the specific network group to which it is assigned. The domain name determines which computers on the network can readily access the PC, as only computers assigned to the same domain will be able to interface with the computer without hassle. Adding the computer to a domain is done by changing the Workgroup setting within the operating system.
  1. Step 1 Right-click "My Computer" and select "Properties."
  2. Step 2 Click on "Advanced Settings" if you are using Vista or 7. Skip this step if you are using XP.
  3. Step 3 Click on the "Computer Name" tab.
  4. Step 4 Click the "Change" button.
  5. Step 5 Enter in the name of the domain to which the computer should be added into the "Workgroup" field. Press "OK."
on Mar 25, 2010 | Computers & Internet
I have a dell all in one 2135cn . and its giving me the erro smb logn error 031-522. how do i fix that?
Make Sure you have the correct IP of the computer you want to scan to and that it is on the same network. Also Make sure on the Login Name field you ONLY have the Login Name of the computer you want to scan to. if login name to computer is "Peter" use only "Peter" and do not add the Domain\Peter. Aldo make sure the are no extra spaces (Like I had) and the Password and Login names are correct. Remember this fields are case sensitive.
Hope this Helps
Sep 15, 2010 | Dell 2135cn All-In-One Laser Printer
Can't get back to Hyrule Castle
If your in Zora domain travel down the strem and follow it till you see a house on water. go into the opening on the oppisit end and you end up in hyrule field. If your in lake hylia then you must pay the guy in pink to be blsted out of a cannon to a building filled with cuccos. Down the ladder there's a door that leads to hyrule field.
Oct 04, 2009 | Nintendo The Legend of Zelda: The Twilight...
Tip
CREATING TRUST RELATIONSHIP BETWEEN TWO WINDOW DOMAIN(2003 server)
Using two domains for example Domain X and Domain Y.
You can create a two-way trust with domain-wide authentication.between the two domains if they belong to the same organisation depending on the imformation that you want to share or use between the two domains .you do this on an established domain controller for each domain.
  • STEPS
  • .On the server where you have domain controller for example on Domain X ,log on as an administrator then go to >Start >Administrative Tools >Active Directory Domains and Trusts.then Right-click on Domain X, go to > Properties. >click on "Trusts" tab. then > New Trust. click - [Next].
  • In the name field type the second domain to trust thats domain Y, in this case then click >next to continue
  • then Select the Direction of the Trust. either two way trust or one way but in this case its a two way then Click [Next].
  • In "Sides of the Trust", select the "This domain only" bullet. then [Next].
  • Set the Authentication level to "Domain-wide Authentication". then [Next].
  • you will be prompted to Enter a Trust Password twice. also Remember to make it strong enough to comply with password criteria in your domain security policy.
  • Click [Next] - [Next] - [Next].
  • Select the "No" bullet to the Outgoing Trust Confirmation - [Next].
  • Select the "No" bullet to the Incoming Trust Confirmation - [Next].
  • Click [Finish] - [OK].
  • Log off of DomainX ,
  • ON THE SECOND DOMAIN (DOMAIN Y) YOU PERFORM THE BELOW STEPS
  • Then .Login to DomainY using Administrator account.
  • go to > Start > Administrative Tools ->Active Directory Domains and Trusts.
  • Right-click on Domain Y, and select Properties. click on "Trusts" tab. Click the [New Trust...] then [Next].
  • in the Name field type domain X to indicate the domain to trust, then click [Next].
  • Select " the Direction of the Trust. in this case its a two way trust then Click [Next].
  • In "Sides of the Trust", select the "This domain only" bullet. Tthen Click [Next].
  • Set the Authentication level to "Domain-wide Authentication". then Click [Next].
  • you will be prompted to Enter a Trust Password twice.dont forget to use the same Trust Password that you used previously in the step above then Click [Next] - [Next] - [Next].
  • Select the "Yes" bullet to the Outgoing Trust Confirmation - [Next].
  • Select the "Yes" bullet to the Incoming Trust confirmation - [Next].
  • to finish Click [Finish] - [OK].
  • Then Log off of DomainY.
on Dec 30, 2009 | Computers & Internet
How do i change the configuration from domain to work group
even if you mistakenly joined a domain you can still log in through your existing id and password.
Once your press CTRL+ALT+DEL, you will see a login window with three fields namely: user id, password and Domain.
In the log in screen use the drop-down menu in front of Domain (which shows your new domain- most likey MSHome) and choose 'this computer'. After this, enter your old/existing user id and password and hit enter.
Please proceed to your system settings and change your domain back to Workgroup. Restart PC.
Sep 30, 2009 | Dell Inspiron 1420 Notebook
How do i publish my site? I have VodaHost as my hosting but I can't seem to get the two to connect
this is very simple, once u finish all works like domain registratin,web design...finaly u have to reach a hosting company to host ur site/publish ur site if u need any hosting assistance have a look at this http://www.tucktail.com/
Aug 26, 2009 | Cosmi Perfect Website Creator (ROM03919)...
I need the domain and password to use on a Motorola Q to access internet can you help???
in the username field type yournumber@mycricket.com type your 10 digit cell number where the words "your number" are
In the password field type cricket
leave the domain name field (blank)
this solution helped me solve my problems
good luck
Jun 22, 2009 | Motorola Mobility Moto Q
Sir , how do i change the workgroup for win xp 64 bit
right click on my computer --> properties --> computer name --> change the name of the workgroup there and apply and ok ( you may need to reboot for it to take effect )
If you are joining a domain ( windows domain ie with a server ) then select domain and enter the Fully Qualified Domain Name in the text field
Apr 17, 2009 | Microsoft Windows XP Professional SP2C for...
my3gb.com Logo
Top my3gb.com Computers & Internet Experts
David Payne
David Payne
Are you a my3gb.com Computer and Internet Expert? Answer questions, earn points and help others
