Question about Husqvarna 42" Primary Deck Drive Belt Cz4217 ()
Husqvarna zeroturn turn key nothing happens - Husqvarna 42" Primary Deck Drive Belt Cz4217 ()
2 Suggested Answers
  • 2239 Answers
SOURCE: husqvarna riding mower
The ignition switch takes the coil grounding wire to earth to cut the motor, so there is either a problem with the ignition switch or a break in the earth wire ( check the conections down by the engine ) to check the system run the machine with the deck engaged lift yourself out of the seat, if the engine stops it will be more than likly the ignition switch playing up, if it does not shut down there is a wiring issue.
Posted on Jun 21, 2012
Belt keeps popping off wheni engage the blades on rz4621 husqvarna zeroturn
Belt tentioner probably worn out and wobbling. It don't take much to throw a belt.
Jun 15, 2015 | Husqvarna Garden
What can I try next? My husqvarna RZ4623 wont start. Nothing when the key is turned.
Is the small wire, coming from the Ignition Key, Getting 12V to the Relay when you turn the Key? Were Mice chewing on your wires?
Jun 25, 2014 | Snapper Husqvarna RZ4623 46" 23HP Kohler...
Husqvarna yth1848xp wont turn over
Are you getting 12 volts to the starter? It sounds like one of the safety switches (seat switch) may be killing the circuit. The seat switch cannot simply be jumped. And check the 20 amp fuse.
May 30, 2014 | Husqvarna Garden
No drive forward or reverse
check the tension on the drive belt if it's still there...check your dump valves. then check fluid level.
Nov 23, 2013 | Husqvarna 155HP DualHydrostatic 42" Cut...
I have a husqvarna 42'' cut lawn mower. I can't
Test the small lead on solenoid for volts when you turn the key. The small lead is what jumps the two switch leads together internally with key in start position.You should be getting 12 volts or so on this small lead, if you have nothing there, check the key switch. Sounds like the key switch isn't sending power to solenoid. Also, check all grounds. Good luck
Sep 05, 2013 | Garden
My husqvarna i wont suhts off when i turn key nothing happens
remove the upper cover from the engine and see f a mouse chewed threw the small wire at the coil that goes to the switch
Jun 20, 2012 | Garden
Husqvarna YTH Lawn Mower will not start
try wiggling the plug while turning the key.
you may have loose terminals inside the plug
May 05, 2009 | Husqvarna Garden
Husqvarna 42" Primary Deck Drive Belt Cz4217 () Logo
22 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
