Question about Kenmore Dishwashers
My dishwasher won't drain, and leaked out onto my hardwood floor!
Originally, my dishwasher had become clogged from the cascaid gel pacs. Once the buildup was removed, it drained fine for awhile...now it's again holding water and it leaked onto my hardwood floor! Could the hose be clogged preventing it from draining?
I ordered a new hose and the problem is fixed! I probably could have just simply taken the old hose off and flushed it out; but the powdered solution, that is supposed to dissolve, had solidified and clogged the hose in several places. Strangely, it had also made like a filmy flap at both openings. Gross!
Posted on Jun 29, 2009
Periodically (once daily?) leaks up to one quart water onto floor.
This is a very common problem when the condesate drain behind the rear of your freezer wall becomes clogged with ice or other matter. If this is happining only under ther refrigerator it would indicate a drain pipe missing the condensate tray or the tray itself is cracked or leaking. Click here for moer= Leaking Refrigerators Just what may be happing and then here=> Leaking Refrigerators
Please read all the information because all leaking refrigerators act differently. I will be here should you have more questions, Thank You, Sea Breeze
Aug 29, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
My dishwasher is leaking onto my kitchen floor.
This is most likely either due to a clog in the drain line or the seal around the sump being at fault. It depends where your unit is leaking from. If you remove the bottom kick plate from the unit you should be able to see where the water is leaking from if it is in the middle of the unit most likely you would have to replace the sump and sump gasket if it is off to the side of the sump then it might be the drain pump being clogged or blocked with something that is makeing it leak. If you have any further questions message me back and Thanks again for using Fixya
Rick
Jun 11, 2011 | Kenmore 15529 Built-in Dishwasher
GE Monogram bottom freezer leaking water from left side onto the freezer floor and onto hardwood floor of the kitchen . Already tried totally defrosting freezer and that did not solve problem. Help!!
ck the drain in the back of freezer . it may be pluged and when it goes into defrost cycle you get about a cup of water on the floor . if there ice on bottom of freezer then the drain is iced over . some models require a drain heater to prevent this . mm hope this helps ..
Oct 14, 2010 | GE Monogram ZICS360NR Bottom Freezer...
Dishwasher not draining
Thanks for writing to Fixya.com.
To fix a dishwasher that will not drain, remove any clogs that are blocking the drain line by pouring a paste of baking soda, vinegar and water down the drain, and then pouring boiling water to clear the clog. Repeat the process several times to remove a severely clogged dishwasher drain. Thanks for contacting Fixya and please accept the solution if it has helped you.
May 15, 2010 | GE 24 in. Profile PDW7800 Built-in...
Water is leaking from the front of the refrigerator freezer side onto hardwood floors it looks like it is comming from the back what would be the cause
Either the drain line is clogged and the condensation cannot drain to the pan to evaporate, or the door seal is not sealing properly allowing to much air (with humidity) into the unit creating to much condensation and overflowing the pan.
First locate the drain hole and line and make sure they are clean and clear. If you poor an 8 oz glass of water through it, it should drain out to the pan if it is clear.
If you find no clog inspect the door seals for cuts tears or any place that is not sealing properly.
Oct 12, 2009 | Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
GE dishwaher leaks with standing water in bottom
Check to make sure regular dish soap did not end up getting inside the dishwasher. This will create a lot of suds that will overflow onto the kitchen floor. Standing water from not draining can mean the drain hose is clogged somewhere or the check valve has something caught in it. If you remove the front kick plate, you will be able to check those.
http://tclaundryrepair.com/
Feb 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
165 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
