Routers
Problem for Routers
Generic problem for all Routers
Need directions for router
By musicnracing on Jun 23, 2009
When ever i go to play my psp or xbox 360 online it will say dns error on the psp and on the xbox that my router is not automatically assigning an ip adress even though its all put on auto. But heres the thing i tried reseting the router and it worked for 2 days before going back to saying the problems above. Please help!
Sincerely, Musicnracing
Best Solution
posted on Jun 23, 2009
Very Helpful)
j_erwint
Rank: Wiz
Rating: 83%, 21 votes
Maybe you havent configured it right, to do that you must set enable your router into dhcp mode to automatically assign an ip address. Configure your router manually (things needed: computer/ laptop, ethernet cable or cat 5 will do), to do that you must first look for your router's ip address look for your manual. After that connect your computer/laptop to your router using ethernet cable, and open internet explorer/firefox and enter your router's ip address. You will be ask for a usernme and password, just enter the default ( common default: username:admin, pasword: leave it blank. note: depends on manufacturer), there you can configure your router manually. Just go to internet setup and you can enable dhcp there. Goodluck, just give it a try. Hope it help.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Helpful)
dj daddy1
Rank: Guide
Rating: 86%, 10 votes
call belkin support and enable a feature on router which is called DMZ and assign a static ip on x-box
Was this helpful?
Yes
No
Solution #3
Helpful)
Wiired
Rank: Wiz
Rating: 83%, 67 votes
Perform a factory reset of the router. Locate the reset button on the back of the unit. Hold it in with a paper clip for 15-30 seconds then release. Reboot the router and it will be back to factory default. Log into the device, and check the firmware. Look online to make sure that you have the current version, and update it if you do not.
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
Hi there, First of really thanks for the support you are providing.. let me come to the point... (More)
Answer
my router keeps automatically resetting itself
Answer
3G-6200n cannot connect to my broadband
Answer
I continue to get kicked off prior to playing NCAA FOOTBALL 10.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 3677
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
