Question about Canon P23-DHV Calculator
How do you load paper into a canon adding machine P26-D?
I do not understand how to load the paper into the adding machine.
5 Suggested Answers
SOURCE: installing new paper in canon p26-dh ii
looked over P1-DHV Calculator found slot on top back middle of machine where paper goes in easy then up into machine with paper feed
Posted on Jan 06, 2010
SOURCE: How do you load the printer paper in P26-DH III
The feed slot is located in the rear of the unit. You don't feed the paper down from the top-there is a paper slot in the rear; just cut the paper at a 90 degree angle and feed it into the rear slot-very easy. I tried to feed it down from the top for twenty minutes and then discovered the other slot. Good luck
Posted on Mar 22, 2010
SOURCE: p26-dh III - I am also unable to load the printer
It is necessary to feed the paper through a slot on the back of the printer in the dark gray area. Feed a single paper through and push the FEED button. When you see it appear, feed the paper through the clear serrated slot on the top cover over the printer.
Posted on Mar 31, 2010
SOURCE: how do i put recept paper in my canon p26-dh 111
how to replace the ink roller on a Canon P26-DH 111
calculator?
Posted on Sep 25, 2011
Paper won't feed into slot on Canon P26-DH 111
Could not find anything directly about a Canon P26-DH III calculator but, here are steps I found for a similar model. Please let us know if this does the trick for your situation or not. Thanks & Good Luck.!
Installing a Replacement Roll
Move the power switch in the upper right corner of the calculator to the "Off" position. (or wherever it may be on your model)
Push the wire roll holder back so it protrudes from the back of the calculator. Place the replacement roll on the holder so the paper's end extends from the bottom of the roll.
Cut the paper's end diagonally and insert it into the slot in the back of the calculator.
Step
Move the power switch to the "PRT" position to turn on the calculator.
Oct 14, 2017 | Canon Office Equipment & Supplies
How to reload paper on MX 850
I do not understand your question. Have you never loaded paper into this machine?
The MX850 has two paper inputs.
You can either load paper into the rear feeder or slide out the cassette from under the machine and use that?
Aug 23, 2011 | Canon Office Equipment & Supplies
How to load paper to my Canon P23-DH V adding machine
Follow the illustrated instructions on page 3 of the manual:
http://downloads.canon.com/cpr/software/calculator/P23-DHV-(USA-HWB).pdf
Apr 21, 2011 | Canon P23-DHIII Calculator
How do you load the adding machine paper on this calulator #P23-DHV Cannon
Paper loads into slot at end of machine. After inserting end into the slot (at rear, near power cord connection) press feed button until paper advance thru top.
Jul 05, 2010 | Canon P23-DHV Calculator
P26-dh III - I am also unable to load the printer paper. I can't figure out how it is to be fed in.
Mar 18, 2010 | Canon P1-DHV Calculator
Loading paper into the Canon P170-DH Desktop adding machine
Rather than try to describe the process in words ("lift up the arm, then feed the paper through..."), I'll point you at the illustrated instructions in the manual at the manufacturer's web site: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=349&modelid=9785
Mar 03, 2010 | Canon P170-DH Calculator
Jan 30, 2010 | Canon P1-DHV Calculator
How do i put recept paper in my canon p26-dh 111
calculator?
Jan 23, 2010 | Canon P1-DHV Calculator
Installing new paper in canon p26-dh ii
Jan 05, 2010 | Canon P1-DHV Calculator
How do I load the paper for the canon P23-DH V adding machine?
Follow the illustrated instructions in the manual here: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Nov 29, 2009 | Canon P23-DHV Calculator
Canon P23-DHV Calculator Logo
70 people viewed this question
old marine
old marine
