Question about Sony Bravia V-Series KDL-52V4100 LCD TV
Won't turn on
Standby light is blinking two time
SOURCE: red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Posted on Feb 09, 2009
  • 51 Answers
SOURCE: The tv turns off automatically & standby light blinks 4 times
4 blinks is bad backlight inverter. Download the service manual here:
http://rapidshare.com/files/208591107/KDL40S2000_L5_sm.pdf
Posted on Aug 22, 2009
Kensolutions
  • 455 Answers
SOURCE: sony 3 lcd rear projection tv hd w/ wega gate.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Posted on Jun 12, 2011
  • 66 Answers
SOURCE: my Sony 32inch is blinking in standby mode and won't turn on
Sorry to tell you this i have the same TV.I have just checked the manual it says TO count how many times the light flashes in 3 second intervals.Then turn the tv off and un plug it from the mains.Sorrry then you will have to ring the Sony service centre and explain the problem.
Posted on Aug 17, 2012
spr1949
  • 1182 Answers
SOURCE: Tv won't turn on. Blinking in standby in red. Won't start
This is an indication of protection error and might require attention of a qualified service technician.
JVC LT46J300 Blue Light blinking TV won't come on all of a sudden
These blinks to standby light are fault indications, called blinking codes. From the number of blinks occur at one time switch on, you can get an idea about the faulty circuit stage inside it. Count it. Visit this site. It has details about blinking codes to many brand televisions.http://electronicshelponline.blogspot.com/Pull up older posts there, either by its left side bar, or see it in Timslide option
Jun 24, 2013 | JVC LT Televison & Video
My Sony tv won't switch of standby just flashes
How many times do this standby light flashes at one time switch ON? Count this and make sure, how many times it blinks. These blinks are fault indications. From these number of blinks, you will get an idea about the faulty section circuit inside it. It will narrow down the troubleshooting. If you wish to get more details about Sony Blinking Codes; check this link.
Feb 17, 2013 | Televison & Video
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
My Sony 32inch is blinking in standby mode and won't turn on
Aug 17, 2012 | Sony Bravia XBR KDL-32XBR4 32inch LCD HDTV
Sony tv won't turn on, light in standby blink three times
that is a master control board failiure, it is caused by having your TV on all the time, when the TV gets warm, you need to shut it off and let it cool down(that caused your problem) call sony and order a replacement part, it will take you about 20-40 minutes to install yourself.
Jul 19, 2012 | Televison & Video
Sony wega kd 34xs955 won't turn on blinking standby/timer
The blinks of standby LED to Sony TVs are fault indications. You must count its number about how many times it blinks at a time. You can get more details abut the blinking codes and the fault. Visit this site "Electro-help" is the site name. Search it by google search. You can locate it, either at the bottom of the first search page, or at the top of the second. It is an electronics equipments repair help site in English.
Blinking codes and fault detection methods are described in detail here.
Jun 18, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Standby light blinks twice approx every 2-3 seconds tv won't turn on
Visit this site 'Electro-help" for details. Type in the site name either to Google or Yahoo search box, and click search. It has all details about tthis fault, and repair.
May 11, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony kv36xbr800 won't turn on -standby blinks 2 times pls help
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Apr 22, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
MY LCD PHILLIPS MODEL 42PFL3704D/47
Good day!!!
if you have power problem without blinking lights or standby lights (red) the possible problem is power supply board..However if the TV have blinking or standby light but won't turn ON..there are multiple cause of that and need further troubleshooting..
Mar 11, 2012 | Philips 42PF9431D/37 TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Bravia V-Series KDL-52V4100 LCD TV Logo
19 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
