Question about Ovens
How to turn demo mode off kitchen aid double oven KeMS 309, 379
2 Suggested Answers
Powerman
  • 68 Answers
SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Posted on May 03, 2007
Omega double wall oven model E88 stuck in demo mode and won't disable
Suggest you contact the manufacturer. There is little information on the web
Aug 04, 2016 | Ovens
Eecrolux combination wall oven / microwave is in demo mode model# ew30mc65jb
Good Morning Rolf, thanks for your post!
Based off the information you have provided your Electrolux wall oven/microwave combination is stuck in demo mode. The best way to remove demo mode from your wall oven/microwave combo is to hold the oven light button and the on/off keys at the same time and you should be able to toggle in and out of demo mode. Hopefully this is helpful. -Matt
Mar 09, 2015 | Electrolux 30" Built-In Double Electric...
Kitchen aid KEBC278KSS stays on
can u plz tell in detail dat which typ of pin or plug does ur mp3 player hav?
Jan 12, 2013 | KitchenAid Architect Series KEBC278KSS...
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Our kitchen Aid Superba Double Oven makes noises when we turn it on and also as it cools down. It sounds like a fan-type noise. How can we fix it?
We had the same problem. It is the fan in one or both of the ovens. we had a repairman come out because the ovens have to come out of the wall. It was a quick fix.
Oct 04, 2009 | Jenn-Air Electric Double Oven
Kitchen Aid Double Convection Oven blows circuit breaker
the kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
Feb 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Kitchen aid kebc278 dual ovens don't work
yes once of the door switches is broken you could jump out the switch
Oct 05, 2007 | Frigidaire FEB30S6D Electric Single Oven
Ovens Logo
41 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
