Question about Bakers & Chef's Foodservice Film -12in x
How do you set up the box to cut film
I can not set up to cut film
    Top Expert:
  • 49,276 Answers
Then you are rather du mb
Posted on Sep 26, 2016
Nikon d40x exposure problem
I assume that this is a film camera that has light meter.
It could be that the camera is set to a different film sensitivity than the actual film.
For example, the film is 400 ASA but the camera is set to 100 ASA.
The sensitivity rating of the film is written on the film box and on the film cartridge. Make sure you set the film ASA number on the camera too.
Aug 24, 2013 | Pentax Photography
How do I know which ISO to set with the shutter speed?
ISO is the speed rating of the film. Both the film box and the film canister should have the ISO rating printed on them. Normally you would just use that number, unless you specifically want to push- or pull-process the film.
Jan 20, 2011 | Vivitar V3800N Zoom 35mm SLR Camera
Laminating film wrapped around back rollers. How can I get it off.
There should be a reverse function for this reason.
Cut the film off where it's going in, with enough to hold onto.
Run motor in reverse and pull on cut off end. Pull hard to unwind from rollers.
If there is no reverse setting, then just pull hard with no motor, to pull rollers in reverse.
Note there is no indication of the brand or model involved. This is a general comment.
Hope it helps.
Jan 18, 2011 | Computers & Internet
I didnt use all of my film but i pressed the rewind button and when i turned it on the film rewond on its own. what do i do?
Nothing. You pressed the rewind button and the film rewound: it didn't do so "on its own", it just did what you told it to.
Get it developed and put another film in and don't make the same mistake twice.
You can buy a film leader retriever which fishes out the end of the film from the canister enabling you to reload it, but you need to remember exactly which frame you were at. To get it back to the correct position you then set the camera to fully manual and using the fastest shutter speed and smallest aperture, leave the lens cap on and cover the viewfinder and away from bright light you fire the shutter until the counter reads one lower than you were last at (if your frame counter counts down to zero shots remaining). If the subsequent shots don't register exactly with the old shots, the automatic film processing machinery will likely cut into some frames when cutting the negs into strips. You'll also find that a leader retriever costs more than another roll of film and can take some skill to use.
In summary, your Minolta 7000 is behaving exactly as designed and the cheapest fix is to just drop in a new roll of film.
Sep 20, 2010 | Minolta Maxxum 7000 35mm SLR Camera
I wouldd lkie to change thhe film
Buy the film set and simply follow the installation instructions on the box. If you put it opposite, there will be no prints...
Mar 31, 2010 | Sharp UX P100 Plain Paper Thermal transfer...
After develop the pictures i found that some images are completely blank and the images are cut into half. Half develop and half not. what the cause of it?? thanks
Might be film coming loose when inserting in loading spool and skipping when winding forward after making a shot. Could try bending first 1/2" of film tongue before inserting in slot in windup spool so that it won't slip out and be sure film sprocket holes are engaged with film transport sprockets and a bit under tension when loading film before closing camera cover. Your 'half-frame' problem might be that you are shooting at a 'flash' shutter setting of 1/60 when not using flash.
Oct 08, 2009 | Canon EOS 5000 35mm Film Camera
Film advance lever
Your camera is cocked but since the shutter is not working you cannot release it and hence your film advance mechanism does not work. ME-super will work without batteries in full manual mode so set your shutter to B and try to release it. If the shutter will not release in B mode then the shutter/mirror box will need servicing : rubber components in the mirror box mechanism have perished and need replacing. After that your camera will be fine for another couple of years.
Sep 18, 2007 | Pentax ME Super 35mm SLR Camera
Panoramic pictures??
A panoramic photo on 35mm film is just cutting off the top and bottom. even if you can't set the camera that way, you can ask your local photo store to print any shot that way for you. Usually 2x the price of 4x6.
Sep 13, 2007 | Minolta Freedom Zoom 115 QD 35mm Point and...
No pictures at all, at it's best just blury colours
got my developed film back and all I got were pictures seperated into 4 boxes with one colour a box. can you explain more can you look at the negatives and see whats on them. try a sunny sixteen rul on a sunny day with sun high in sky set camera aperture to F16 if you are using ISO100 film set the camera shutter to 1/100th ISO 200 = 1/200th etc take a picture of a stationary subject - like a brick wall whats the make and model of the camaera
Apr 13, 2007 | Lomo Action Sampler Kit Camera 35mm Point...
Bakers & Chef's Foodservice Film -12in x Logo
116 people viewed this question
Top Bakers & Chef's Home Experts
john h
Tom Chichester
Are you a Bakers & Chef's Home Expert? Answer questions, earn points and help others
