Question about Staples SPL120 Basic Calculator
Staples calculator will not show decimals - Staples SPL120 Basic Calculator
Why are totals rounding off
In the product details of this calculator, it states that there is a "decimal point selector." This is normally a slider starting with the letter F followed by the numbers 0123 etc. It is probably on 0. You can set the number of decimals to whatever you want, or use F for full numbers. For example, if you set this to 2, you should always get 2 decimals.
Good luck,
Paul
Apr 07, 2016 | Staples SPL-P100 Printing Calculator
How to change decimal point
If you want all entries and answers to have two numbers after the decimal, you should have a lever or slide that shows F,6,3,2,1,0. Some also show Add. Set the lever on the 2 or add. F means floating decimal. the others indicate how many numbers after the decimal.
Oct 30, 2014 | Sharp EL-1701C Calculator
How to fix decimal on BD-6355MT calculator? It used to work before but it stoped.
Same just happened to me. Remove the 2 little screws and then carefully prize open the calculator. Remove battery and leave out for some time. It will then reset to default and your calculator will work as before.
Sep 15, 2011 | Staples SPL120 Basic Calculator
My screen shows no decimal just a comma..help me get my decimal back....thank you
To switch the radix mark between European and US modes, turn the calculator off, press and hold the decimal point key, press and release the ON key, then release the decimal point key.
Feb 21, 2011 | HP 12c Calculator
Ok so i got this new calculator the staples BD-6410 and I am about to loose my mind. When i put in 2.5 "squared" i get 25/4 how do i get it NOT to give me a fraction but a decimal????
above the DEL key, you should have a button S (2 sided arrows) D. press that, and it will give you the decimal value. If you know how to use this calculator, it is a great help in almost any math course.
cheers
Jan 07, 2011 | Texas Instruments TI-89 Calculator
Change decimal placement on calculator
pressing the tab button displays the number of decimal places 0, 2, 3, 4, A, F on the bottom of the screen.
Jun 22, 2010 | Office Equipment & Supplies
Only shows 1 decimal place!!
Press 2ndF TAB and then a digit specifying the number of digits you want after the decimal point.
May 23, 2010 | Sharp EL-501WBBL Calculator
Show more decimals
Press 2nd [FORMAT], type a digit representing the number of digits you want after the decimal point (or 9 for floating), then press ENTER 2nd [QUIT] to get back to calculating.
May 20, 2010 | Texas Instruments BA-II Plus Calculator
EL-1197PIII Sharp Calculator
move switch for decimal places to "add",or to number "2" for 2 fixed decimal places
Feb 28, 2008 | Canon LS-100TS Calculator
Staples SPL120 Basic Calculator Logo
63 people viewed this question
Top Staples Office Equipment & Supplies Experts
 Bob Buchholz
Bob Buchholz
ray gallant
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
