120 ml=how many oz - Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
120 milliliters is about 4.06 US ounces or about 4.22 UK ounces.
Posted on May 13, 2014
How much freon does a 2002 Chevy Tahoe take with a 4.8 v8.The system has already been evacuated and is ready to be recharged.
Should have a sticker on the radiator core support that shows how much it takes . But if your's is missing here
Refrigerant System Capacities
Application
Specification
Metric
English
PAG Oil GM P/N 12378526 for United States
PAG Oil GM P/N 88900060 for Canada
Accumulator Replacement
-ml*
- oz*
* Add 60 ml (2 oz.) of PAG oil, plus the equal amount of oil drained from the accumulator.
Compressor Replacement
60 ml
2 oz
Condenser Replacement
30 ml
1 oz
The Delphi replacement compressor is precharged without PAG oil.
The Denso replacement compressor is precharged with 237 ml (8.0 oz) of PAG oil.
Evaporator Replacement
90 ml
3 oz
Evaporator, Rear Replacement
90 ml
3 oz
If more than the specified amount of PAG oil was drained from a component, add the equal amount of oil drained.
Total System PAG Oil Capacity
240 ml
8 oz
Total System PAG Oil Capacity with Rear A/C
330 ml
11 oz
R-134a
Refrigerant Charge
0.8 kg
1.8 lb
Refrigerant Charge Utility with Front and Rear A/C
1.2 kg
2.7 lb
Refrigerant Charge Suburban with Front and Rear A/C
1.4 kg
3.0 lb
Mar 15, 2017 | 2002 Chevrolet Tahoe
WHAT IS THE OIL TO GAS MIXTURE IN OIL TO GALLONS
Mixing
RatioGAS:OIL UNITED STATESOIL per 1 U.S. GALLON Gasoline
(128 oz.) *INTERNATIONALOIL per 1 IMPERIAL GALLON Gasoline
(160 oz.) *INTERNATIONALOIL per 1 LITER Gasoline
(metric) 32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
May 04, 2015 | Garden
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
Jan 01, 2015 | Weedeater Garden
If I have 300 grams of milk how do you convert that into oz's
The metric system is easy in one aspect. 1 ml = 1 gram. If you are looking for liquid conversion you have 300 ml of liquid. 100 ml is 3.4 oz so you have about 10 oz of milk.
Oct 10, 2014 | Coffee Makers & Espresso Machines
What s the A/C compressor oil capacity in 2003 dodge durango with rear A/C
If it was shipped empty just add the amount that's stamped on the compressor. But most of the ones that I have seen where shipped wet/ full . to check get a beaker and simply remove the plugs and drain the oil into the beaker. when the system is opened it is recomended that you replace the RECEIVER DRYER also. if the compressor is damaged internally then you need to replace the EXPANSION VALVE also. hope this helps
_____________________________________________
Refrigerant Oil Capacities
Total System Fill - Front A/C Only 5.07 fl oz (150 ml) Total System Fill - Front and Rear A/C Only 7.40 fl oz (220 ml) Receiver/Drier 1.0 fl oz (30 ml) Front Evaporator 2.0 fl oz (60 ml) Rear Evaporator 1.0 fl oz (30 ml) Condenser 1.0 fl oz (30 ml) Compressor drain and measure the oil from the old compressor
Jun 28, 2014 | 2002 Dodge Durango
Convert milliliters to ounces
I assume, the "oz" is a "US fluid oz", other countries use different definitions.
1 ml = 0.0338140 US fl. oz.
By multiplying both sides of the equation by 120 you get:
120 ml = 120 * 0.0338140 US fl. oz. = 4.05768 US fl. oz.
If you ask because of a cooking recipe, round it down to 4.
Mar 19, 2014 | Office Equipment & Supplies
Convert 3.4 ounces to mills
There are two different fluid ounce units,
  • 1 Imp.fl.oz. = 28,4130642624675 ml (cm³)
  • 1 US fl.oz. = 29,5735295625 ml (cm³)
Depending on which of the two units you refer to, you'll get
  • 3,4 Imp.fl.oz = 96,6044184923895 ml
  • 3,4 Us.fl.oz = 100,5500005125 ml
Jan 07, 2011 | Office Equipment & Supplies
Does any of you know how many milliliters are in an ounce?
Here is a quick conversion chart:
100 ml = 3.3 or 3.4 oz
50 ml = 1.7 oz
30 ml = 1 oz
15 ml = 1/2 oz
10 ml = 1/3 oz
7.5 ml = 1/4 oz
5 ml = 1/6 oz
3.7 ml = 1/8 oz = 1 dram
Note that all of these are approximate; strictly speaking, 1/2 oz is 14.787 ml.
A standard perfume sample is in a 1/32 oz (1 ml) vial.
Nov 23, 2010 | Health & Beauty
.4oz what is the diff
oz is unit of mass and ml is unit of volume
if we talking about liquids with specific gravity of 1 like water and drinks (almost) then
each oz is 28.4 gram and equal 28.4 ml of water or drink
so 0.4 oz would be
.4 * 28.4 =11.36 ml
37 - 11.36 = 25.64
Aug 20, 2010 | Office Equipment & Supplies
24 people viewed this question
jasbo
jasbo
