Question about Pioneer DVD-V555 DVD Player
Dvd tray will not open
Dvd tray does not open when open button is pushed
My dvd does not play in laptop due to digital copyright problem. what can i do to fix this? no dvd wil play
Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
Press the "Eject" button on your DVD player to open the DVD tray. Set the DVD into the tray, and push the "Eject" button to close the tray. Press the "Play" button on your DVD player, and the DVD will play. b> On a DVD Drive on a Computer Press the "Eject" button on your DVD drive to eject the DVD tray. Set the DVD into the DVD drive, and push the tray in to close it. Click the "Start" tab on your computer's home screen to open the "Start" menu. Click on "My Computer" to open it. Click on the DVD drive to open the DVD. Click on "Autoplay" to play the DVD.
Jan 28, 2013 | Compaq Computers & Internet
My dvd wont play on laptop
b> Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
MY BUTTON IS STUCK ON THE DVD-ROM TRAY. WHAT DO I DO?
if you look on the drawer for your dvd drive, you will see a little hole.If you push a pin in the hole the drawer will open.
Aug 20, 2012 | Computers & Internet
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
My dvd drive won't open.
In the front of the loading tray you will see a small pin hole, get a fine jeweler screwdriver or a needle push in until you hear click the door will pop open allowing access to your cd/dvd disc, if the driver won't work it will probably have to be replaced.
Feb 01, 2011 | Dell Computers & Internet
When the open/close button is push , the DVD tray open and it close immediately without pushing button.The tray won't stay in the open positions.
check the close circuit switch inside the system. its maybe stuck, try to wiggle it a bit and it might work again.
the switch is at the end of the tray when it is closed, its a small black push botton swith.
be careful not to fry it when installing a new part
Aug 26, 2010 | JVC HR-XVC16B DVD Player / VCR Combo
My husband always operated the DVD player. He has died and now I'm at a loss what to do. I rented a DVD at the video store. I tried to put it into the tray on the DVD player. I had to pull the tray...
Hi, Very sorry for your loss. As always the first step is to make sure the player is connected to the wall outlet and turned on. To put a disk in the DVD you should push the "Eject" button to open and close the tray it looks like a home(a triangle over a dash) on the front side of the box down left corner of the tray. You have the same button on the remote marked "Eject". Push either once, put the disk with the shiny side down on the tray and push the Eject button again to feed the tray back into the player. Usually the disk starts automatically and you will see a menu on the TV with alternatives like "Play the movie", "Setup", "Scenes",... you may highlight the "Play the movie" alternative, using "Up", "Down", "Left" and "Right" and then press the "OK" button. Or just push the "Play" button either on the box or the remote control. If you click "Here "you can download the manual in PDF form. To open it in your pc you'll need "Adobe Acrobat Reader" (or any other PDF reader) installed.
I will gladly answer your questions Best Regards Bruce
Aug 23, 2010 | Amphion Mediaworks S99 DVD Player
under teh machine there is an opening near the tray. Look inside adn you will see a small white tab. Use a small tool to reach in their and push it to the other side. That will open the tray.
Sep 08, 2009 | Philips DVDR985 DVD Recorder
DVD Tray is locked
Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
Jan 18, 2008 | Sanyo DWM-390 DVD Player
Disk holder will not open when open/close button pushed
a switch outside or inside is broken, dirty, or somewhat that get inside a switch.
Jan 13, 2008 | Emerson EWD2203 DVD Player/VCR
Pioneer DVD-V555 DVD Player Logo
12 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
