Question about Toshiba Satellite U205-S5057 Laptop Universal AC Adapter 15-17v (AC22VPNW8V3B2)
Location of cmos battery location in the toshiba u205-s5057
2 Suggested Answers
Ezrahite
  • 2632 Answers
SOURCE: I am trying to locate
Welcome to Fixya. Please refer to the image below on the location of the cmos battery.
Please also refer to the link on how to disassemble the laptop
How to take apart Toshiba Satellite U205
Thanks for using Fixya
Posted on Apr 21, 2011
Satellite u205-s5057 freezes up when online.
Sounds like a bug. Download and install CCleaner and Malewarebytes from CNET. Run CCleaner first, both the Cleaner and Registry, then Malewarebytes on a Quick Scan. If there is a Java or Adobe Flash bug in the laptop, Malewarebytes will find them.
Your not done yet!
Download TDSSKiller for Kaspersky. You can find it on Google and at CNET. Run TDSSkiller and make sure there are no root kits. When you are done with that, make sure you have all your Microsoft, Java and Adobe Updates then Run a Full Scan with Malewarebytes.
Please post how this works out for you.
Jan 18, 2014 | Toshiba Satellite U205-S5057 Laptop AC...
SATELLITE U205 ....IS ITPOSSIBLE TO BOOT FROM AN EXTERNAL USB DVD DRIVE
Shut your computer down and remove the power cord.
Replace the power cord and press the "Power" button to restart it.
Watch the screen carefully for a message about computer setup.
Most computers use one of the function keys, which are aligned across the top of the keyboard, to access the computer's setup utility, but each manufacturer uses a different key.
For instance, HP computers generally use the F1 or F10 keys, while many Dell computers use the F12 key.
Press the appropriate function key to enter the computer's setup program, then scroll through the list of options until you see "Boot Order."
The exact location of the boot order option varies from manufacturer to manufacturer, but it is often located under the Advanced menu.
Highlight the "USB Devices" option and press the up arrow key until that device is first on the boot order list.
This will force the computer to look at the external DVD drive first when it boots up.
Use the "Esc" key to exit the setup menu. Choose the "Save settings and exit" option and allow the computer to reboot.
It will now boot from the external DVD drive.
Hope this helps
Sep 26, 2012 | Toshiba Satellite U205-s5057 12" 1.66 Ghz...
Toshiba u205 - SD card won't stay in reader
Just buy an external SD card reader that plugs into one of your usb ports. You should be able to get one at any local pc shop or best buy.
Aug 17, 2012 | Toshiba Satellite U205-S5057 Laptop DC Car...
Recovery cd- toshiba u 205-s5021the computer dont accept my fingeprint and no password
Remove/replace the CMOS battery from the motherboard to reset the password.
Nov 03, 2009 | Toshiba Satellite U205-S5021...
Bios does not save any changes that are made toshiba sat.
Changes to Boot Order only last as long as the next boot, you have to press F12 every time to alter boot sequence.
Oct 06, 2009 | Computers & Internet
Laptop Won't Turn On (Toshiba Satellite U205-S5057)
Try a new power adapter before you try the other expensive tests and repairs. The adapters are notorium about failing after being used continuously . If you can check the outgoing voltage at the tip where it fits into the DC jack on the laptop would be good. Match the output to the rated voltage needed to peoperly power the laptop.
Sep 07, 2009 | Toshiba QOSMIO F15-AV201 Notebook
Toshiba U205-S5057 won't charge
the spark damaged possible follow component:
1) the fuser near the Jack socket on motherboard which is DC input fuser, change it as same current one if it is danaged
2) if the fuser at good connection, so there is a protect circuite failure which near the jack, but need to repair by a technician
most your symptom is occured like 1)
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 28, 2009 | Computers & Internet
How to install toshiba satellite u205-s5057 memory
There is an access panel on the bottom of the laptop remove that and just insert the stick of ram. Make sure that you are grounded when holding the ram as you can shock it with static electricity.
If you need further assistance don't hesitate.
Thank you,
Lee
Jun 18, 2008 | Toshiba Computers & Internet
Hard Disk Sound
A little noise is normal while the HDD is working. Use the warranty if it is too loud.Extra loud is usally a sign of failing HDD.
Sep 17, 2007 | Toshiba Satellite U205 Notebook
Toshiba Satellite U205-S5057 Laptop Universal AC Adapter 15-17v (AC22VPNW8V3B2) Logo
141 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
