Question about JVC Televison & Video
User manual for jvc iart tv - JVC Televison & Video
5 Suggested Answers
  • 7 Answers
SOURCE: NO CABLE CONNECTION WORKS.
Not at all sure so this might tick you off but how many coax connectors on back of set is there are a red and green one plug into the red one then make sure that in your menu settings you have your TV set to that input connector not video1, HD, sat etc.. take your time you are probably missing something.
Posted on Feb 24, 2009
romsky79
  • 822 Answers
SOURCE: JVC iart Pro - Image dissapeared... still have sound
cold solder crt socket and mainboard.
Posted on May 30, 2009
toolkits
  • 1099 Answers
SOURCE: i have a JVC IART television and i had to transpor...
hello,
the problem is a colour patches , you can solve this by using a big size magnet like that in an audio speaker to remove the colour patches.
you do this when the television is power on, and gently moving the magnet towards the screen of television.
hope this will help...
Posted on May 23, 2010
gopakumarg43
  • 74136 Answers
SOURCE: i have a 32" tv jvc iart and horizontal white
Hello
You are seeing vertical retrace lines. This faut is due to the vertical output section inside your TV. To rectify this fault, you must open your Tv. Just open it after unpluging it from the wall power socket. Locate the vertical output section on the printed circuit board.
It is easy to locate. You can see four wires goes from the deflection yoke; the coil fitted around the neck of the picture tube. Out of which two of them will be thick, usually red and blue coloured, and the other two will be thin. These two thin wires are for vertcal scanning. Just follow these two thin wires, and you will reach a point where these four wires are pluged onto the main circuit board, very near to the LOT. Upside down the printed circuit board, and follow the print of that two thin wires, and you will reach to the vertical output section of your Tv.
Before doing anything, just look for any loose soldering or bad solderings there. It is very difficult to find out loose solderings, as thay will be microscopic, I advice you to resolder most of the soldering points there by applying a little more solder; without making any solder short. Resolder all the pins of the vertical output IC, and see the effect.
If this does not help, replace the two or three electrolytic capacitors, at about 1000MF to 2200MFD there, with same capacity and voltage ratings. Make sure about their polarity, as electrolytic capacitors have both positive and negative terminals like torch cells. Note the polarity when resoldering them out of the board. This must solve ypur problem.
If you need anymore asistance, feel free to contact me through Fixya. OK
Wish you sucess.
Posted on Dec 11, 2010
VC IArt tv doesn't show picture and the power button flashes
There is shorted component/s in the power regulator section to your TV. Check and replace them.
May 07, 2012 | JVC AV-27D302 27" TV
How do program my jvc 32 iart remote control
full instructions are in the owner manual, if do not have that Google the model number and "manual"
Apr 08, 2012 | JVC Televison & Video
I have a jvc iart television and i had to transport to my apartment now i have green and red colors in each corners.. How do i remove those colors??
hello,
May 21, 2010 | JVC AV-27F802 27" TV
Blue lines arc down from the top of the screen on JVC IART TV model number AV-65WP74. Is it worth fixing? Thanks
Yes it is worth fixing . You can fix it yourself for about $ 21 . You need to replace the convergence I.C. chips , The part # is STK392-310 . you need two of them . You can get them from bluestar-online.com . They are about 6 bucks a piece and about 10 for shipping .
May 13, 2010 | JVC AV-65WP74 Rear Projection Television
Blue grid lines of color convergence seems to be stuck in a postion: 1 grid box to left. tried to manually set but no luck. (JVC IArt bbe 74")
The AV48WP74 - AV65WP74 convergence repair kit from www.tvrepairworld.com should fix that issue the kit contains the parts and the CD with detailed instructions.
Nov 17, 2009 | JVC AV-65WP74 Rear Projection Television
Jan 28, 2009 | JVC AV27F476 27" TV
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Oct 17, 2008 | JVC AV-32820 32" TV
PLURED PICTURE
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 23, 2008 | JVC AV-48WP74 48" Rear Projection...
Jvc television want come on
Reset is done by unplugging the ac cord for a time,then plug
back in...............Please verify model number off sticker on the
                            rear of your tv...let me know.....T.
Oct 22, 2007 | JVC AV-56WP30 56" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
